Alternator? - Alfa Romeo Bulletin Board & Forums
post #1 of 6 (permalink) Old 04-27-2018, 11:34 AM Thread Starter
plasmid's Avatar
Alternator?
Hey guys
Euro Alfetta GTV
First start after winter - started on the 2nd try, generator light went out for 3-4 seconds, then came back on and stayed on.
It's fully illuminated, not just slightly.
12.4V engine off and 12.4V engine on, up to about 4k.
Swapped the regulator, same thing.
That leaves the alternator right?
Alternator is a Magneti Marelli, probably orig.
Alternator belt looks Ok. I changed it about 3 years ago. At that time the generator light was faintly illuminated,
like you might get when a bunch of electrical things are on. Changing the belt cured it.
plasmid is offline
post #2 of 6 (permalink) Old 04-30-2018, 06:39 AM
alternator not charging. happy charging should be 13.5>14V. where are you measuring? should be measuring at battery posts... if volts good at cable ends but not posts, maybe corrosion inside clamps... clean and remeasure. if 12.4 v at posts - is just running on battery voltage.
barboncino105 is offline
post #3 of 6 (permalink) Old 04-30-2018, 10:45 AM Thread Starter
plasmid's Avatar
Yeah, it's running on battery power.
I also checked the voltage drop and it seems to be ok, so I guess that leaves the alternator.
plasmid is offline
post #4 of 6 (permalink) Old 04-30-2018, 11:11 AM
good luck.
post #5 of 6 (permalink) Old 05-01-2018, 06:28 AM
Marelli alternator unlike it's Bosch counterpart has separate brush holder and regulator. Have you checked the brushes/ slip rings? End of life brushes will give the behavior you report. I have the exploded assembly drawings for both types if of any use.
kondor is offline
post #6 of 6 (permalink) Old 05-09-2018, 02:43 PM Thread Starter
plasmid's Avatar
Sounds good. I'll PM you with my email, unless you want to post them here.
plasmid is offline
