Blue gauge face replacements? - Alfa Romeo Bulletin Board & Forums
 2Likes
  • 1 Post By planetmojo2
  • 1 Post By f4driver
post #1 of 8 (permalink) Old 05-12-2017, 05:02 PM Thread Starter
Does anybody know of a source making replacement gauge faces and needles? I'd like to convert the black GTV 6 gauges to Alfetta blue and my needles have a weird droop to them down towards the gauge face.
scott
'84 GTV6/'75 Alfetta GT *long* term project
scootergeek is offline
post #2 of 8 (permalink) Old 05-12-2017, 05:42 PM
Maybe Palo Alto Speedometer?
lewong is offline
post #3 of 8 (permalink) Old 05-12-2017, 05:55 PM Thread Starter
Hey look at that, right on their page: "Custom work includes color face conversions."
Thanks.
cheers,
scott
post #4 of 8 (permalink) Old 05-13-2017, 07:11 AM
On your 'drooping' needles... that's actually more normal than weird. Depending on how warped yours have become, there are a few quick fixes. If the needle is just a bit warped but still threatening to drag against the dial face, you can carefully wiggle the center of the needle upward with your fingernails to remove it from its shaft. When you press it back on, don't push it all the way down.
If it has warped beyond what the quick fix can cure, you can remove it and carefully sand the back side of the tip with some light sandpaper grades in the 300-400 grit ranges to make it flatter on the dial side. If the warping is even worse than that, the cure seems to be to carefully trim a bit off the tip of the needle with finger nail clippers, and clean that up with fine sandpaper.
Some needles become warped into a pretzel shape... Then you need to go looking for fresh needles.
Many speedos that no longer work are due to warped needles dragging against the dial face. The lightest touch of the needle to the dial face can prevent the needle from moving properly.
Peter
scootergeek likes this.
planetmojo2 is online now
post #5 of 8 (permalink) Old 05-13-2017, 01:42 PM
Look at "droopy needle fix" by 1984 Maratona..date 12/10/2010
Good directions to fix needles..took me less than an hour to do both and can't tell from new
all the best
Chuck
f4driver is offline
post #6 of 8 (permalink) Old 05-13-2017, 05:47 PM Thread Starter
http://www.alfabb.com/bb/forums/alfe...eedle-fix.html
Outstanding!
Thanks guys.
post #7 of 8 (permalink) Old 05-13-2017, 08:38 PM
sriswit's Avatar
scott
Just get a used set of Alfetta GT's gauges and then take them apart and swap the faces with your GTV6's gauges. The only thing not available is the face of the clock. My GTV6 has a tachometer with blue face from an Alfetta GT. I haven't done other gauges except tach.
65 TI, 74 GTV, 86 GTV6, and 91 Spider
sriswit is offline
post #8 of 8 (permalink) Old 05-14-2017, 06:13 AM
Alex's Avatar
Scott,
I have several NOS blue-faced gauges advertised on the BB here if you are interested.
Cheers,
Alex.
[FONT="Georgia"][/FONT]
to all parts I have advertised on the BB so far. Plenty more! Just ask.
Alex is offline
