1984 Maratona "Ran when parked..." - Page 33 - Alfa Romeo Bulletin Board & Forums
 759Likes
post #481 of 1093 (permalink) Old 08-06-2018, 04:48 PM
Jim G's Avatar
Originally Posted by horsewidower View Post
I would suggest that if you plan to do this, you treat your old seals as if you have to reuse them. I did purchase a set of the "rear seals" for the GTV6 (apparently no such thing) when we measured things up at the NAPA store. They are just a scosh too small at the outside diameter, I considered sticking them in with some Locktite sleeve product.
Always an interesting journey.
Yes there are rear seals. They are the stub axle seals on the transaxle. You have to pull the rear rotors off. Then pull the stub axle out. Press of the retaining ring then press off the bearing and seal assembly. Knock the bearing and seal out of the retainer. Install new ones and reassemble.
horsewidower likes this.
Jim G is offline
post #482 of 1093 (permalink) Old 08-06-2018, 04:57 PM Thread Starter
horsewidower's Avatar
And THAT is why I'm still learning. Thanks.
But wait there's more: View my 164LS thread:
You didn't...oh yes I did II. 1995 164LS 5 speed, awesome when it runs!!!
Musings on shop related items:
horsewidower is online now
post #483 of 1093 (permalink) Old 08-06-2018, 10:14 PM
Del
"front wheel bearing seal"
Is this the same seal as for the front hub axle of the Milano? Just had one of those replaced a couple of months ago, as somehow it became buggered and made a skritching noise as the wheel rotated.
Del
Seattle
1989 Milano, Shankle Sport
1991 164S, stock
1994 164LS (~Q)
1972 Morgan 27
previously owned since 1964:
Del is offline
post #484 of 1093 (permalink) Old 08-07-2018, 11:59 AM Thread Starter
I don't know the answer to that question, Del. It's a great question, but I'm clueless. I may own four Alfa, but I'm still a rookie.
post #485 of 1093 (permalink) Old 08-07-2018, 01:08 PM
Del
Looking at the ePer for the Milano/75, I see one seal on the stub shaft, pn 60521293. Don't know if that is similar to the one on the GTV6, the eper doesn't cover that car.
Del
Seattle
1991 164S, stock
1994 164LS (~Q)
1972 Morgan 27
Del is offline
post #486 of 1093 (permalink) Old 08-07-2018, 01:25 PM Thread Starter
Thanks! I'll see what I can find with that Part Number.
post #487 of 1093 (permalink) Old 08-10-2018, 09:59 AM Thread Starter
SMH...
At some point you either get angry, or...laugh. Great big belly laugh...a guffaw even.
The Lovely Donna let me know that I'd received a package at our front gate. I was excited. Finally some seals that are supposed to work. These came from the supplier via an order through Summit. The 494117s. Small box, but much packaging. I knew that things probably weren't quite up to snuff with the seals themselves when they were in two entirely different sized boxes, even if they were marked with the same label. Inside each box was a seal that looked completely unlike the one in the other box.
I was so flummoxed that I forgot to take a picture, I'll do that tonight.
Last edited by horsewidower; 08-10-2018 at 10:01 AM. Reason: Correct PN, or not...
post #488 of 1093 (permalink) Old 08-10-2018, 10:30 AM Thread Starter
Looks like the Amazon purchase has made it to the Wilton Post Office. Hopefully I can get there and see what that purchase produced.
post #489 of 1093 (permalink) Old 08-10-2018, 11:11 AM
AlfafaninNY's Avatar
Watching this closely . I am doing the same thing pretty soon.
Joe C . Brooklyn NY
1986 GTV6
AlfafaninNY is offline
post #490 of 1093 (permalink) Old 08-10-2018, 12:27 PM
Spitfire's Avatar
In case you’re down a bit, here are a bunch of other seals that aren’t working...
On the plus side, according to another thread, the value of your car is up.
Good luck. Looking forward to seeing it hit the road!
Del and horsewidower like this.
John
1991 Alfa Romeo 164L, 1993 Ford 5.0L Mustang
Spitfire is offline
post #491 of 1093 (permalink) Old 08-10-2018, 01:56 PM
Alfisto Steve's Avatar
GTV6/Milano front and rear axle/hub seals
Originally Posted by Del View Post
Looking at the ePer for the Milano/75, I see one seal on the [front axle wheel hub], pn 60521293. Don't know if that is similar to the one on the GTV6, the eper doesn't cover that car.
FYI rear stub axle oil seals in transaxle were 60521230 for GTV6 and now 60521231 same as Milano.
Front axle hub wheel bearing inner grease seals are 60521293 for both GTV6 and Milano.
There was a 60500731 two front wheel bearings and axle shaft grease seal kit at one time.
Virginia Beach, VA
My Maintenance Sticky:
Alfisto Steve is offline
post #492 of 1093 (permalink) Old 08-10-2018, 04:44 PM
Del
Difatta web site says they've got a few of the front. Don't know if that is up to date though.
Del
Seattle
1991 164S, stock
1994 164LS (~Q)
1972 Morgan 27
Del is offline
post #493 of 1093 (permalink) Old 08-10-2018, 05:18 PM Thread Starter
LOLOLOLOLOLOLOLOLOLOL
sigh...sob
LOLOLOLOLOLOLOLOL
Send the guys with the white jacket...
I just opened the Amazon package.
SMH
Time to pour a couple margaritas and mellow a bit.
Del, thanks for that tip. I might also try Jon Norman in Berkeley.
post #494 of 1093 (permalink) Old 08-10-2018, 05:18 PM
Member
@Spitfire - That's awesome. Thanks for the laugh.
Del, horsewidower and Spitfire like this.
-Chuck
Racso is offline
post #495 of 1093 (permalink) Old 08-10-2018, 06:00 PM
Del
Enjoyed the picture. Where was it taken?
The seals look just like the small sea lions (way smaller than our West Coast sea lions, maybe 1/4 the weight) we walked around on the beaches in the Galapagos Islands when we were there. You could walk right up to them, and they just sort of stared at you for a couple of seconds, and then went back to sleep. Clearly they are not afraid of the great predator, lol.
Del
Seattle
1991 164S, stock
1994 164LS (~Q)
1972 Morgan 27
Del is offline
