Hard Start in Hot Sun - Alfa Romeo Bulletin Board & Forums
 4Likes
post #1 of 35 (permalink) Old 04-18-2016, 06:46 PM Thread Starter
Its back.......GTV6 hard start after sitting in hot sun. Had problem a couple of years ago, went through everything, replaced all vacuum hoses, ignition wires, cap rotor, plugs. Issue resolved, it came back unexpectedly the other day. The car had sat in parking lot for two full days under a car cover in hot sun. Had to crank like crazy, then it started, idling super rough but straightened out in minute or two. This on a car that can be relied on for a first turn start every time. No performance issue once underway. Please, any wit, wisdom or suggested ideas about cause from the on-line crowd?
Thank you in advance,
8oclock
8oclock is offline
post #2 of 35 (permalink) Old 04-18-2016, 07:12 PM
bill2000's Avatar
8oclock
I vote for humidity trapped under the cover messing with your electrics
If by chance you can't afford LSD, buy yourself a color TV. - Godard
1982 GTV6
1973 GTV2000
1971 Karmann Ghia Vert
1982 Land Cruiser
1988 Land Cruiser
bill2000 is offline
post #3 of 35 (permalink) Old 04-19-2016, 03:21 AM
SamW's Avatar
I have the same issue with mine, I drove it to work the other day and got in at the end of the day and had to crank a while before it fired. I was leaning towards something like the thermo time switch getting hot and not firing the CSI, or maybe the other way around, firing the CSI when it is not needed.
'86 GTV6 - No Name
'89 Spider Quad - Red
'86 Spider Quad - Silver - SOLD
'89 RC30
SamW is offline
post #4 of 35 (permalink) Old 04-19-2016, 06:53 AM
MALDI's Avatar
I have the same problem: a true cold start is fine, a true hot start is fine, but the in-between temperatures (like sitting in the hot sun) requires extra cranking. I was think my aux air valve may need adjusting...
MALDI is online now
post #5 of 35 (permalink) Old 04-19-2016, 09:51 AM
I have the same problem. If I unplug the cold start injector, it fires right up, so I am thinking that the cold start injector is firing when it doesn't need to.
Michael Conrey
Allentown, PA
Michael Conrey is offline
post #6 of 35 (permalink) Old 04-19-2016, 01:43 PM
sriswit's Avatar
Michael Conrey
Allentown, PA
This would explain why I also smelled a hint of gasoline in the air.
65 TI, 74 GTV, 86 GTV6, and 91 Spider
sriswit is offline
post #7 of 35 (permalink) Old 04-19-2016, 01:56 PM
Also worth checking to see if your coil or ballast resistor might be overheating. You might not be getting enough juice to the plugs to fire it up.
'82 GTV6
chairmankaga is offline
post #8 of 35 (permalink) Old 04-19-2016, 04:49 PM
Yeah I've had the same problem with difficult starting after parking in the sun on very hot days. So it looks like it is likely due to the TTS and CSI. If it is then it seems there are a few options:-
- the TTS gets hot and the CSI doesn't fire when it should
- the TTS stays cold and the CSI fires when it shouldn't
- the TTS is broken and triggering at the wrong temperature (would contribute to the above).
- it is a design fault
I always just put it down to the weather! No seriously, I thought it was due to the plenum getting hot, but armed with this knowledge I'll take a proper look next time - or ignore it and just keep cranking the engine on hot days.
tpalfa is offline
post #9 of 35 (permalink) Old 04-20-2016, 06:48 PM Thread Starter
Thanks everyone for the helpful suggestions. The CSI is checking out properly but a connector to one of the tabs on the coil seems to have been loose producing very low spark. Seems like the fix for now.
Again thanks for the interest and replies.
8oclock
8oclock is offline
post #10 of 35 (permalink) Old 04-20-2016, 07:21 PM
Del
I remember that with my GTV6's and Milano, you couldn't touch the throttle when the engine was cold lest you blow the plenum off (nah, don't ask me how I know this), but when it was hot, you could feather the throttle to enable a quicker hot start, according to Alfa.
Do you do this when the engine is still hot?
Del
Seattle
1989 Milano, Shankle Sport
1991 164S, stock
1994 164LS (~Q)
1972 Morgan 27
previously owned since 1964:
Del is online now
post #11 of 35 (permalink) Old 04-21-2016, 04:28 AM Thread Starter
GTV6 Starting Routine - over 29 years of driving the GTV6 I have developed the fail-safe habit of never touching the accelerator before or during the start hot or cold. I do turn the key on and wait 10 seconds or so for all the electrons to get lined up (or something like that, cosmic energy too!) then a quick crank, shut off, then second quick crank that always starts the car. Again, I do this cold, warm or hot, perhaps with a bit more precision when its cold. I've never blown a plenum off or anything dramatic like that. I often have wondered where that issue comes from. My guess is that drivers are used to carbureted or Spica equipped cars that do like an inch or two of pedal. I now drive a Spica car too and its an art to get the right amount of throttle to the system especially on a re-start when the engine is hot.
Thanks again for everyone's responses, I'll post a short post mortem when the issue is definitively settled.
8oclock
8oclock is offline
post #12 of 35 (permalink) Old 04-21-2016, 04:38 PM
ToonRboy's Avatar
Send a message via Yahoo to ToonRboy Send a message via Skype™ to ToonRboy
Just goes to show you that end-users often cloud the problem with superfluous information (hot sun). I learned this in Information Technology support roles. People say the dangdest things that if you give any heed, will lead you down Alices rabbit hole! Example: "Computer just shut off when the lightening struck (but noone else affected & no power loss). Turns-out user kicked the surge strip power switch...Lol
ToonRboy is offline
post #13 of 35 (permalink) Old 04-21-2016, 05:34 PM
Del
Is that a useful comment?
Del
Seattle
1991 164S, stock
1994 164LS (~Q)
1972 Morgan 27
Del is online now
post #14 of 35 (permalink) Old 04-21-2016, 05:43 PM
@ToonRboy are you saying that it isn't normal for GTV6's to be hard to start after they are parked directly in the very hot sun? Say over 40C/104F? This is the sort of temperature where mine sometimes doesn't start easily and based on some of the responses it seems that I am not Robinson Crusoe. I know that the TTS changes state at around 40C which seems to provide a hint. If a hard start in these conditions is abnormal then maybe I'll bother trying to fix it. I know mocking others is an artifice meant to get people to bite, but I am only looking for useful information and like to sort the wheat from the chaff.
tpalfa is offline
post #15 of 35 (permalink) Old 04-21-2016, 06:04 PM
Del
I can only speak from my own personal experience with my two GTV6's and the Milano, for which all three do exhibit this trait, and that according to Alfa, a slight feathering of the throttle with a hot start will speed the starting process, the problem caused by a slightly incorrect intake mixture under those particular conditions due to the overall design parameters of that injection system. Using the throttle is a problem only with a stone cold start.
We have always lived with it since the cars were new, and otherwise have no problems. The 164s have a more precise system and don't seem to have this problem.
nemesis likes this.
Del
Seattle
1991 164S, stock
1994 164LS (~Q)
1972 Morgan 27
Del is online now
