Best wheels for GTV-6 - Page 10 - Alfa Romeo Bulletin Board & Forums
 73Likes
post #136 of 277 (permalink) Old 06-04-2012, 03:58 PM
Originally Posted by xander18 View Post
I recalled your username, I just didn't want to oust your cover! I did, the overheating was just a loose fan connection. After a little off site consultation from Glennco to make sure I wasn't about to blow anything up I was back on the road.
If you want to grab some measurements I would be curious about that. Circumferences will be the most accurate measurements for that stepped down portion and we can do some math from there. I don't know if this something I would jump at, especially as I don't have a lathe big enough, but I was curious at the possibility. If they're close and the material is there then you have the best of both worlds. However you run the risk of ruining a rim or weakening the rim where it counts.
I did some googling and the size of that rim is 365mm, or 14.37". It looks like it would have to get turned down to a 14" rim unless they measured from some weird diameter.
I'll make a note to myself to go take some measurements in the AM. I have some 15" wine glasses right next to the phone dials. So, I can give you both to work with.
Oh no... my cover is blown! Now the KGB, CIA, and al queida know where my kids go to school. Time for a new alias. The witness protection program is not going to like this very much :- )
planetmojo is offline
post #137 of 277 (permalink) Old 06-04-2012, 04:28 PM
xander18's Avatar
I would do the analysis on that, maybe even do some finite element analysis for the lightened rim to make sure that it's structurally fine, but I would probably advise you ask a machine shop about that job. It's a very quick and not at all hard task to do, I could give you an engineering print to give them. The folks of the 'BB might appreciate the option of running the metric rims with ordinary tires.
xander18 is offline
post #138 of 277 (permalink) Old 06-04-2012, 06:44 PM
I had abandoned that option for myself a while back. Once I had heard that it was not possible.
But I'm willing to pitch in the dimensions, to revisit this as a possibility. If my rough scaling show some promise, I could loan an extra rim to get more exact on. Details on the back side of the rim might make it, or break it, too?
post #139 of 277 (permalink) Old 06-05-2012, 11:30 AM
Hi Xander,
I found a few moment to break out a couple of wheels to measure. I tried to be as accurate as possible, given my tools. Here are some numbers to play with:
A) Max OD on the face of the rim
B) The diameter that steps down inboard of the max OD, where the ID of the tire would sit
C) Circumference that describes 'B'
D) Diameter that defines the internal walls inside 'B'/'C' (there is a generous draft angle in the holes on the metrics, here [10-15 degrees, perhaps]. Not as much draft on the 'wine glasses').
Metric TRX rims:
A) 15.38"
B) 14.294"
C) 45.09"
D) 13.865"
Speedline 15" 'wine glasses':
A) 16.31"
B) 14.69"
C) 47.00"
D) 14.46"
When you compare the math on diameter vs circumference... I did not make that calculation. So, hopefully those come out close.
Remember, in geometry class, they taught you that Pi R square. Not true!...
Pi R round... Cake R square. :- )
Cheers,
Peter
post #140 of 277 (permalink) Old 06-05-2012, 02:59 PM
Xander...
I tried to respond to your question via e-mail... but the edu address got returned, twice.
Do you have another address I could use?
Cheers,
Peter
post #141 of 277 (permalink) Old 06-10-2012, 07:15 AM
Renaldo's Avatar
Any idea what these are?
Another variant on the 5 star pattern but I like!
Ron
______________
67 Duetto - Angelina
84 GTV6 - 'Alvetta' - 3.5L 24v + Corvette C5
95 164LS - Black Bomber - 6sp w/Q2 LSD - for sale!
16 Caddy ATS-V w/6sp MT
Renaldo is offline
post #142 of 277 (permalink) Old 06-10-2012, 02:34 PM
That there is one sexy lookin GTV6 up above!
Fun is more important than speed!
budgy is offline
post #143 of 277 (permalink) Old 08-07-2012, 11:15 AM
16" AR wheels on GTV6
This is my '83 GTV6 which has had a full restoration and is expected to be "on the road" Mar '13.
3.0 + power steering from 75 (Milano) fitted.
Wheels are from AR 916 GTV model (not in USA), 16x61/2, 5 bolt 98mm pcd with 30.5mmm offset. hub dia had to be increased by 0.5mm. Lots of room for bigger brakes.
I think these AR wheels with large disk area look a lot better than "spokey" aftermarket types.
kondor is offline
post #144 of 277 (permalink) Old 08-07-2012, 02:28 PM
araknd's Avatar
Send a message via Yahoo to araknd Send a message via Skype™ to araknd
Here's my '82 GTV6 with later model Stilauto Antares2
[SIZE="3"][FONT="Palatino Linotype"]Lance
[I]Alfa Romeo Sempre il Primo[/I]
[COLOR="Red"]1982 GTV6 Balocco (Margherita)
2015 Fiat 500 Abarth (Vitaley)
[/COLOR]
[COLOR="Black"]1982 GTV6 (gave his life for Margherita)[/COLOR]
[COLOR="black"]1977 Alfetta Sedan(sold and driven into the ground)[/COLOR]
[COLOR="Red"]1982 Spider Veloce (sold)[/COLOR]
[COLOR="red"]1986 Spider Quadrifolio (sold)[/COLOR]
[COLOR="Green"]1991 164L (transferred to a good home)[/COLOR][/FONT][/SIZE]
araknd is offline
post #145 of 277 (permalink) Old 08-07-2012, 06:03 PM
these are a style i am very keen on.
have a set similar made by speedline that were mounted to my 308 before i bought it.
would be interested in a similar wheel to ones pictured above.
anyone know the make and model?
joe
1981 GTV6 3.0L
1983 Spider
sloppyjoe is offline
post #146 of 277 (permalink) Old 08-08-2012, 07:56 AM
HeavyMetalAlfa's Avatar
Joe check out my thread "What wheels are these".
Nice car by the way, I've been watching that one for years, very glad to see it go to a great new owner!
The " Save the Rusty Alfa Society"
43 Alfas at the moment [ I think], I'll be able to tell better when the snow melts
HeavyMetalAlfa is offline
post #147 of 277 (permalink) Old 08-08-2012, 06:16 PM
thanks glen,
spend too much on correcting issues from loading in colorado onto the transport and was not expecting those costs.
but the goal over summer and into fall is to correct the very wrong things and then tackle the little things during the winter before it gets a respray.
then i need to find a terrific set of wheels to set it all off
1981 GTV6 3.0L
1983 Spider
post #148 of 277 (permalink) Old 08-08-2012, 07:09 PM
It bummed me out hearing about the bad "transport" company. I know getting money for damage from auto transport drivers is pretty well not worth the effort and negative communication and energy,,,
That said, I seriously applaud you rolling with it and embracing that great car.
You need some bits, I'll be glad to help if I can.
post #149 of 277 (permalink) Old 08-08-2012, 07:46 PM
yeah i didnt spend much time spinning my wheels with anyone.
what i will need is help figuring out the speedo on the car. i can drive very happily and easily with a rev counter. i spent so much time on track with my bike programmed to run the tack and shift lights only that is how i run my bike on the street. rev counter and feel for speed has served me well for nearly 10 years,,,,but a speedo might be a good idea at some point i suppose
ohhh and the passanger side signals do not work. both front and rear. no flasher sounds from under the dash. will begin to tackle that this week i think. hoping its a bad fuse,relay,flasher unit and not a bad steering stalk unit.
1981 GTV6 3.0L
1983 Spider
post #150 of 277 (permalink) Old 08-10-2012, 07:33 AM
GTV6 Wheels
Thought I'd chime in...Charlie at Serpent Autosport sold me some rims. they look great, I'm very happy, and Charlie is as helpful as anyone I've met. give it a shot.
Bill Bergman
[SIGPIC][/SIGPIC]
'83 GTV6 gone
'85 Veloce gone
'74 GTV sold
'89 Grad sold
GeeTeeVeeSix is offline
