Vic Autosports sells a hot cam for the V6 engines that they say is a big upgrade over the factory S cams. From thier catalog:
MODEL VALVE TIMING LOBE CENTER DURATION @ .050" OVERLAP LIFT APPLICATION PART # PRICE
V6 2.5 & 3.0 32-64/50-20 106º/105º 283º IN 52º 11.50mm IN Welded camshaft 14-3835 465.00
(See footnotes) (at .050) 254º EX (at .050) 10.80mm EX Hot performance
V6 2.5 & 3.0 33-74/67-30 - - 287º IN 66º 10.10mm IN New camshaft 14-3863 685.00
(stock 164 S cams) at 0 clearance 277º EX 6.40mm EX Street performance
Cam number 14-3835 is a serious performance
camshaft. The valve lift of this cam exceeds the limits of the
stock valve train. The cylinder head, adjacent to the valve
tappets, must be machined to allow the cam to clear the
aluminum head casting. Stock valve springs will not work,
you must use our Heavy Duty Springs to avoid high speed
coil bind. Modified fuel injection is required for optimal
performance. If you are serious about your car’s
performance, this is the cam you need.
Has anyone used these cams?
