Sperry Valve Works header - Alfa Romeo Bulletin Board & Forums
post #1 of 6 (permalink) Old 01-08-2012, 08:48 AM Thread Starter
Arrow Sperry Valve Works header
Folks interested in going together to have 10 sets of updated Sperry Valve works headers made at cost + tooling should private message me. The originals had (4) 27 inch primaries into a 3 inch collector the tubes were held into the collector by fasteners as shown and are well known to the Alfa community. I have a set (as shown) that I can use to duplicate the tubing runs from and plan to update as follows: 3 steps on the primaries 1.50 to 1.63 to 1.75 inches into a 2.5 inch V-band flange collector that is held in place by behive springs on all tubes. This updates the tubes to a Burns Stainless Steel spec. (please read the attached article). They will be fabricated from TIG welded mild steel and will have to have finishes applied by you as a secondary operation. Please note the weld quality of the tubes in the photos. The location of the collector exit and the v-band allows for other exhaust treatments as it turns to go under the car and as the header is a modular design it can be easily modified to suit very specific applications. Fabrication will take approximately 1 month and has to start in February if it's going to happen, which means all in, in January. The price will be $700.00 a set. You should appreciate this for what it is: a significant value play. Please private message me with questions and when you are ready to commit. Thank you for serious posts and inquires only.
See attached dyno sheet for test results with Mike's engine and these headers.
Happy Motoring.
b
awesomeBLT is offline
post #2 of 6 (permalink) Old 01-08-2012, 09:32 AM
geh458's Avatar
The Sperry header was good, I had one on the GTV I use to have, here's a picture.
Gifford
'72 Super --> SOLD, '67 GTV --> SOLD
geh458 is offline
post #3 of 6 (permalink) Old 01-08-2012, 10:08 PM
that would be a very tight fit in a spider, my 2 peice header take a bit of ' wiggling' to get it in.
anyone can buy a Porsche, only Drivers drive a Alfa Romeo
bianchi1 is offline
post #4 of 6 (permalink) Old 08-05-2012, 07:44 PM
did you ever get these together? i would be interested in a couple of them.
Bill
'64 Giulia Spider Normale, '67 Boattail, '67 Stepnose
proval1 is offline
post #5 of 6 (permalink) Old 08-05-2012, 09:07 PM
wow!! 13 to 1 compression...
bianchi1 is offline
post #6 of 6 (permalink) Old 08-06-2012, 02:23 PM
aldo's Avatar
WooooHo.
Over 200 horses for 700 dollars... sign me up if these will fit an S4.
Ciao tutti
93 Spider (red)
87 Milano (not red)
aldo is offline
