Alfa Nord 2000 Engine Freshly Built: - Alfa Romeo Bulletin Board & Forums
 2Likes
post #1 of 21 (permalink) Old 06-18-2019, 07:00 AM Thread Starter
I have up for sale is my freshly build 2000 alfa nord.. Originally a SPICA injected engine out of my 79 Alfetta. I am going a different direction with my project so I am putting up for sale.
Taken down to a bare block and cylinder head, the following have been replaced and performed:
- Pistons upgraded to motronic 10.5:1
- Rod and crank bearings upgraded to king bearings
- Spruell Motorsports windage tray and block girdle.
- Rebuilt and upgraded oil pump
- Weiss chains, upgraded material
- New OE ring set.
- Balanced OE rod and piston set
- Spruell Motorsports oil passage restrictors
- Cylinder head resurfaced and valve seat reground for all new stainless valves
- All valve guides have been replaced @ high lift cam spec
- Intake and Exhaust cams replaced with high lift 11.1mm cams
- Stiffer valve springs
- Euro intake manifold port matched to head
- Alfaholics extended carb mounts port matched and blended to runner and head diameter.
- Weber DCOE 40 freshly rebuilt
- Centerline electronic distributor, plug wires, and new plugs
- NEW water pump, thermostat, engine mounts, all seals and gaskets replaced.
- complete blueprint of ENTIRE engine with full documentation and receipt.
There is much more involved to the work and parts on this engine. Please call with any and all questions on this. I am asking $3400.00 for everything here.
Cheers,
Thank You,
Ryan
720.937.3607
stefmiesterb and triz like this.
RChapman is online now
post #2 of 21 (permalink) Old 06-18-2019, 07:04 AM
Does the crankshaft have a pilot bearing, is it bored for a bearing?
Chas H is offline
post #3 of 21 (permalink) Old 06-18-2019, 07:07 AM Thread Starter
It is not bored for the bearing at this point but this is something that can be done with the crank in the engine if being used in anything outside of a transaxle car.
post #4 of 21 (permalink) Old 06-18-2019, 07:35 AM
Richard Jemison
Alfar7's Avatar
What?
I ain`t buying such info!
Richard Jemison
RJR Racing
Same with stupid"
Alfar7 is offline
post #5 of 21 (permalink) Old 06-18-2019, 07:48 AM Thread Starter
There was a member who had posted a while ago about a specialty tool/drill jig (custom made) to bore the crankshaft for the pilot bushing. There has also been talk of others doing the same work with the crank installed as well as removed. This is not something that I have seen in person but it seems these steps have been crossed in the past. Sounds pretty cool
post #6 of 21 (permalink) Old 06-18-2019, 07:52 AM
Richard Jemison
Alfar7's Avatar
Post?
Send us a link to those post please.
Richard Jemison
RJR Racing
Same with stupid"
Alfar7 is offline
post #7 of 21 (permalink) Old 06-18-2019, 08:17 AM Thread Starter
I cannot post links at this time but if you google "alfetta crank pilot bushing drill" the first link has multiple threads concerning this. Interesting read for sure.
I may be able to PM them if you would like?
Cheers,
post #8 of 21 (permalink) Old 06-18-2019, 08:33 AM
Here's a link to a 12 year old post offering a special tool to drill the crank in situ. I wouldn't rely on this ad as proof it can be done.
https://www.alfabb.com/bb/forums/eng...le-jig-cl.html
Chas H is offline
post #9 of 21 (permalink) Old 06-18-2019, 08:48 AM
Somer's Avatar
That appeared to be a one off tool copied from something else. Ever see another? I'd like to see a link too.
Somer is offline
post #10 of 21 (permalink) Old 06-18-2019, 08:17 PM
slowcreek's Avatar
Where are you located?
It's Giuseppe's giubos, not Guido's guibos, on my 78 Alfas
slowcreek is offline
post #11 of 21 (permalink) Old 06-18-2019, 09:00 PM
He's in Littleton, Colorado (suburb of Denver)
6alfas is online now
post #12 of 21 (permalink) Old 06-18-2019, 09:07 PM Thread Starter
About 15 miles SW of downtown Denver.
post #13 of 21 (permalink) Old 06-19-2019, 09:47 AM Thread Starter
IT seems as though i cannot send PM's either. I need 5 more posts i guess. If you have any questions and would like to chat further you can text me at this time.
Cheers,
Ryan Chapman
720-937-3607
post #14 of 21 (permalink) Old 06-19-2019, 07:09 PM
1alfanatic's Avatar
This is a "Screaming" Deal, this is worth twice that. The Crank can be Drilled with a carbide bit, (with skill), I've done it before. Bob Lesher
“One must keep working continuously; otherwise, one thinks of death.”
Enzo Ferrari
1alfanatic is offline
post #15 of 21 (permalink) Old 06-19-2019, 07:49 PM
Richard Jemison
Alfar7's Avatar
What?
Guys! You don`t "Drill" holes in a crankshaft for bushings. Drilling is sloppy metal removal.
You "drill" a pilot hole then bore the finish size.
Richard Jemison
RJR Racing
Same with stupid"
Alfar7 is offline
