For Sale 105 Oil Pump - Alfa Romeo Bulletin Board & Forums
 1Likes
  • 1 Post By Gordon Raymond
post #1 of 7 (permalink) Old 09-05-2018, 11:03 AM Thread Starter
alfa_corsa's Avatar
Send a message via Skype™ to alfa_corsa
105 Oil Pump
Brand new, never installed, purchased from Classic Alfa. For 1600cc Alfa engines.
$200 + shipping from Northern California
IMG_9785 by gearheadexchange, on Flickr
IMG_9784 by gearheadexchange, on Flickr
-tj
57 1900C SS (10321) Carrozerria Touring (in process)
59 Giulietta Spider Veloce (05431)
66 Giulia Sprint GT Veloce (242922) Reborn
95 Ducati 916
92 Ducati 900SS
91 Ducati 851
66 Ducati Mach 1 Replica
alfa_corsa is offline
post #2 of 7 (permalink) Old 09-05-2018, 07:53 PM
veloce430's Avatar
Does it have helical or straight cut gears?
veloce430 is offline
post #3 of 7 (permalink) Old 09-05-2018, 09:19 PM Thread Starter
alfa_corsa's Avatar
I have no idea. I didnít know there was a choice.
TJ
95 Ducati 916
92 Ducati 900SS
91 Ducati 851
post #4 of 7 (permalink) Old 09-06-2018, 09:24 AM
Gordon Raymond's Avatar
It's not so much a choice. Most current aftermarket pumps have 9 tooth straight cut teeth. These are not ideal for engines that run faster than stock 2L FI engines, for a number of design / engineering reasons. They are FINE for their intended application. Most of the older higher speed engines and race engine builders prefer the 9 tooth helical pumps, which are no longer made as a quality, after-market product. Below are 2 photos. the first shows a straight cut 2L pump bottom. Note the LARGE live center lathe cut in the main shaft. This can be used to identify a straight cut gear pump without disassembly.
The second photo shows on the left, a main shaft without the LARGE live center cut and 9 tooth helical drive gear. The right in the second photo shows the 2L main shaft end with live center, and straight cut 9 tooth drive gear. These visual clues will give you an idea which pump you have.
Should you need more oil pump information, contact me by PM with your e-mail contact information.
dbest likes this.
Gordon Raymond
Now:
Gordon Raymond is offline
post #5 of 7 (permalink) Old 09-06-2018, 09:30 PM Thread Starter
alfa_corsa's Avatar
Very interesting, thank you for the lesson!
I'm curious to know which one I have. I bought it about 10 years ago, from Classic Alfa I think. I'll take a peek and make a photo.
-tj
95 Ducati 916
92 Ducati 900SS
91 Ducati 851
post #6 of 7 (permalink) Old 09-07-2018, 08:52 AM
You are better off not removing the bottoms on Alfa pumps for ID unless you plan on having them rebuilt. Once the running gear set has been set-up correctly, its best not to disturb that setting. Most pump identification can be made without disassembly. It become easier when you look at different variations every day for 50+ years!
Gordon Raymond
Now:
post #7 of 7 (permalink) Old 09-07-2018, 04:41 PM
Andrew's Avatar
TJ, PM sent. Don't disturb it! I'll take it.
Andrew
Andrew is offline
