Best method for fixing the gear shift boot ? - Alfa Romeo Bulletin Board & Forums
 2Likes
  • 1 Post By AJMA11
  • 1 Post By AJMA11
post #1 of 7 (permalink) Old 08-22-2019, 06:16 AM Thread Starter
Dear folks ,
I would like to ask you about the/your best methods and or solutions and or ideas to fix a new gear shift boot.
Unfortunately almost all pins of my center console for the metallic boot-holder were broken.
Alfa Romeo Museum in Arese obviously has had the same problem, because they fixed the boot-holder of its Montreal-
exibit by drilling 4 holes in the center console for using screws.
Honestly I would like to avoid this non-orginal solution but have not the slightest ideas how to do it.
so any ideas , solutions or pics would be highly appreciated .
Thanks in advance for information
cheers
Bernhard
BKMONTREAL is offline
post #2 of 7 (permalink) Old 08-22-2019, 09:45 AM
AJMA11's Avatar
my non original but so much stronger solution !
using the existing back plate and its holes, laser cut 4mm stainless steel polished, 4mm stainless steel bolts...
Alfaboutvegas likes this.
Alain A
Alfa Romeo Montreal 1971 and 5 other non Alfa
AJMA11 is offline
post #3 of 7 (permalink) Old 08-22-2019, 11:01 AM Thread Starter
Thumbs up
Super styling and very professional indeed ! unfortunately I neither have the tools nor the knowledge to
copy it.
post #4 of 7 (permalink) Old 08-22-2019, 02:03 PM
If you can find Giorgio Penatti, he can sell you a new panel complete with a steel backing plate incorporating gear lever boot mounting. You'll have a much stronger panel than you have now, sure to last another 50 years or more.
robarbon is offline
post #5 of 7 (permalink) Old 08-23-2019, 03:44 PM
I found the best quick solution was for my upholsterer to glue it under the plate. Using contact adhesive.
It looked very professional.
SHaszz is offline
post #6 of 7 (permalink) Old 08-24-2019, 03:49 AM
AJMA11's Avatar
G. Penatti work, certainely the best (only?) choice for strong original look
IRONBLOCK likes this.
Alain A
AJMA11 is offline
post #7 of 7 (permalink) Old 08-24-2019, 10:05 AM
I developed laser cut aluminum panels and use 4 velcro fasteners to fix the gear shift booth in the back. It works fine and is very easy and quick to remove.
EdBorto is offline
