Montreal roll center - Alfa Romeo Bulletin Board & Forums
 1Likes
  • 1 Post By conedriver
post #1 of 12 (permalink) Old 07-03-2019, 10:46 PM Thread Starter
Does anyone have information about the front and rear car roll centers?
EdBorto is offline
post #2 of 12 (permalink) Old 07-04-2019, 05:07 AM
Push hard and live
DPeterson3's Avatar
Without special linkage, such as sliding block or displaced Watts, the rear roll center of a live rear axle is always at the center of the bell housing, exactly at the level of the axles.
Don P
Carson City, NV
Past Alfas...
Current Alfas
Oops. Add to the "present" list, 10204 01488, 2000 Touring Roadster project
And past...
1946 Luscombe 8A
And present...
64 Mooney M20E ("Rambo". My faithful steed for over 40 years) Over 55 years old, and just returned from a trip to Argentina in him
Newest in the fleet
2010 Triumph Thunderbird
DPeterson3 is offline
post #3 of 12 (permalink) Old 07-04-2019, 05:47 AM
conedriver's Avatar
Since a Montreal chassis is basically that of a 105, handling comments should be similar:
I respectfully suggest the rear roll center is at the point where the T-Arm attaches to the differential; several inches higher than the center of the bell housing. Then, the front roll center is considerably lower resulting in a roll axis tilted downward toward the front.
Alfar7 likes this.
George Schweikle
Scuderia Non Originale
conedriver is offline
post #4 of 12 (permalink) Old 07-04-2019, 06:54 AM
Richard Jemison
Alfar7's Avatar
Roll Center
George is correct.
In fact the front roll center on the 105/115 chassis as is on the Montreal the roll center is right at ground level, and cars lowered by using shorter springs are typically below ground level.
Both front and rear can be raised significantly with correct modifications.
Richard Jemison
RJR Racing
Same with stupid"
Alfar7 is offline
post #5 of 12 (permalink) Old 07-04-2019, 07:03 AM
Push hard and live
DPeterson3's Avatar
Ah... the above is correct. I was referring to a generic live axle. The “tee arm” is a roll-Center displacing element, much like Watts or Slider.
Alfas took a road less traveled with their tee-bar, moving the RC upward. The classic method to achieve superior predictable handling is to have low roll centers front and rear. However, this requires either or both stiff springs and/or roll bars. The high center in the rear allows soft rear springs for a pleasant street ride while minimizing body roll, even without an anti-sway bar.
Don P
Carson City, NV
Past Alfas...
Current Alfas
And past...
1946 Luscombe 8A
And present...
Newest in the fleet
post #6 of 12 (permalink) Old 07-04-2019, 05:52 PM Thread Starter
Roll Center
Ok guys thank you very much! Understood the full concept of an inclined roll axle, low front and up rear. Moving forward - does anyone knows the average weight in each wheel? And how about the approximate CG position? Is it in the firewall section or in the front seat position?
EdBorto is offline
post #7 of 12 (permalink) Old 07-04-2019, 07:46 PM
Alleggerita's Avatar
Why would you even think about raising the rear roll center?
Originally Posted by Alfar7 View Post
George is correct.
Alleggerita is offline
post #8 of 12 (permalink) Old 07-04-2019, 08:42 PM
Stiffer sway bars emulate raising the roll center-increasing weight transfer to the other end of the car. The upper arm Alfa uses at the rear was OK back in the 50s. It's a real hindrance to good handling with current tires and increased engine power.
Chas H is offline
post #9 of 12 (permalink) Old 07-05-2019, 06:02 AM
Montreal #8787, a non-air conditioned car. Weighed with full fuel tank, spare tire and toolkit. Total weight 2,873 lbs (2,773 net of fuel). LF-802, RF-807, LR-627, RR-637.
DWR46 is offline
post #10 of 12 (permalink) Old 07-05-2019, 06:14 AM Thread Starter
Roll Center
That´s it. Thank you!
EdBorto is offline
post #11 of 12 (permalink) Old 07-05-2019, 06:58 AM
Richard Jemison
Alfar7's Avatar
Roll centers
You wouldn`t. I should have used "changed or improved" rather than raised relative to the rear.
The target is roll centers front and rear that are close to the same so tire loads have less rear to front weight transfer during cornering to improve lateral grip.
Typically race prep`d (done correctly) has the rear roll center around the center to botton of the axle tubes, easy to achieve with a Panhard set up. The old Sliding Block wasn`t as effective, read Jon Norman`s article in Alfa Owner earlier this year on handling with the Sliding Block Vs a Panhard on the same GTA.
Richard Jemison
RJR Racing
Same with stupid"
Alfar7 is offline
post #12 of 12 (permalink) Old 07-06-2019, 07:19 AM Thread Starter
Roll centers
I was looking at a youtube video of a Zagato Alfa where the owner figured out the roll center. Nice vídeo. Also I was looking at my GTV 1750 under restoration rear suspension which is very similar to the Montreal. After driving my Montreal about 100 miles since restoration, mainly in urban streets, I noticed there is something so bad in terms of cornering. It seems I will loose the entire rear axle. The GTV 1750 does not have this effect. Why such big difference between the two cars? Or there is something wrong with my rear suspension? It´s all stock.
EdBorto is offline
