Electrical Issue - Alfa Romeo Bulletin Board & Forums
 1Likes
  • 1 Post By EdBorto
post #1 of 9 (permalink) Old 03-27-2019, 04:07 PM Thread Starter
Electrical Issue
I'm having some issues with my electrical. Is it possible that the amp meter is fried? I have the wiring diagram and where I used to get running pump and starting etc I get nothing at all now. I did have some smoke from behind the left binnacle but couldnt get the cover off quick enough to diagnose. If the amp meter is fried I'm assuming that could kill all the flow to the rest of the car? I have nothing..no lights etc. Thanks
Sent from my SM-N960U using Tapatalk
Peteydaddy is offline
post #2 of 9 (permalink) Old 03-28-2019, 12:51 PM
Electrical Issue
I am not the right person to answer because my AMP always works well, but considering you are waiting for a response, here is my contribution based on Papajam diagram:
Be sure your #6 fuse on fusebox B is ok and then check if you have +12V to ground in both AMP meter terminals with the ignition switch in start. If you have voltage in both terminals your meter is ok. If you have voltage in the black and nothing in the red, meter coil is open. Disconnecting both wires and with a continuity test you can doublecheck the open condition. Meter coil can be rewired but you need to check the overcurrent source that causes the coil to open before fuse #6 opens. If you have nothing in both wires, you will need to check your black wire all the way down to the starter and ignition switch, including the +battery connection. I will not adopt the old school method of short circuit the AMP meter terminals with a screwdriver to see what happens because it could damage something else.
EdBorto is offline
post #3 of 9 (permalink) Old 03-29-2019, 04:55 AM Thread Starter
Thank you. Looks like the amp is shot. I'll be on the hunt for a replacement if anyone has one. It may need to be the whole unit/speedo... Thank you!
post #4 of 9 (permalink) Old 03-29-2019, 05:27 AM
Electrical Issue
On ebay you can find ironblock´s ad at https://www.ebay.com/itm/Alfa-Romeo-...frcectupt=true
IRONBLOCK likes this.
EdBorto is offline
post #5 of 9 (permalink) Old 03-29-2019, 08:04 AM
www.haeckner-shop.com has replacements ——look into his online shop —-Alfa Montreal Amperemeter —- price on request
BKMONTREAL is offline
post #6 of 9 (permalink) Old 03-29-2019, 03:37 PM Thread Starter
Originally Posted by BKMONTREAL View Post
www.haeckner-shop.com has replaceplacements ——look into his online shop —-Alfa Montreal Amperemeter —- price on request
Excellent thanks this helps!
post #7 of 9 (permalink) Old 03-29-2019, 04:07 PM
just 've recognized that Haeckner homepage has no English version , so please go on as follows :
1.) Online shop
2) Karosserie/body
3) weitere Alfa Klassiker/ more Alfa vintage cars
4) Karosserie Montreal / body Montreal
5) scroll to Instrumente/ instruments
and u will find at least the Amperemeter and or others ;-)
post #8 of 9 (permalink) Old 03-30-2019, 05:12 AM Thread Starter
1.) Online shop
2) Karosserie/body
Thank you this is very helpful!
post #9 of 9 (permalink) Old 04-01-2019, 12:40 PM
IRONBLOCK's Avatar
Kevin, you may be able to buy an amp meter from Planet105 on eBay in Australia, too. He's had quite a few NOS gauges but I don't see any now. You can contact him through this link:
https://www.ebay.com/itm/Alfa-Romeo-...wAAOSw4YxanHm1
PM replied to...
Mark
IRONBLOCK is offline
Similar Threads
88 Spider fuel pump electrical issue Lee A Spider - 105 & 115 Series (1966-1994) 13 08-06-2016 02:23 PM
big electrical issue.. no power.. anywhere? rustysrustyduc Alfetta & GTV6 (1972-1986) 7 05-10-2011 07:52 PM
86 Spider - electrical issue trojwl Spider - 105 & 115 Series (1966-1994) 18 03-10-2011 03:00 PM
86 Spider electrical issue trojwl Electrical, Chassis & Lighting 3 03-10-2011 07:35 AM
'78 Spider Electrical Issue beltgunz Spider - 105 & 115 Series (1966-1994) 2 12-16-2010 07:56 AM
