How to remove gearshift lever? - Alfa Romeo Bulletin Board & Forums
post #1 of 7 (permalink) Old 03-10-2017, 05:19 AM Thread Starter
Hi,
Does anyone know how too remove the chrome part of the gearshift lever so I can install the inner shift boot? I tried unscrewing it and prying it with no success. Thanks for any help!
Chris
JDGE70 is offline
post #2 of 7 (permalink) Old 03-10-2017, 06:33 AM
Edgar Bortolini's Avatar
Hi Chris, I have this drawing and have no idea who made it. Hope it helps.
Ed Bortolini
72 Montreal - Arancio Metallizzato - Finally Ready
68 GTV Veloce - bianco spino - under restoration
97 V6 - 3.0 Spider - rosso 130
Edgar Bortolini is offline
post #3 of 7 (permalink) Old 03-10-2017, 06:06 PM
Chris, mine wouldn't come off either, by twisting or pulling. But I tried again the other day and a combination of the two did the trick! The internal rubber bits are pretty tight. I suggest to try it while the engine/tranny are cold; so the shift lever is as contracted as possible. Every little bit helps!
John Pergolizzi
San Diego
jtperry8sf9 is offline
post #4 of 7 (permalink) Old 03-13-2017, 05:45 AM Thread Starter
thanks for the info...I'll keep trying
Chris
JDGE70 is offline
post #5 of 7 (permalink) Old 03-13-2017, 06:09 AM
IRONBLOCK's Avatar
Chris, I replaced both my inner and outer shift boots, only removing the shift knob, which you can wiggle and pull straight up off the gear shift lever. The inner shift boot came from Classic Alfa with a bit of a disclaimer about whether it would fit a Montreal or not.
The rubber boot was a very tight fit! I boiled a bowl of water, threw the shift boot in the hot water and ran out to the garage with it. On about the 5th attempt, I got lucky and the boot slid over the transmission.
Mark
IRONBLOCK is offline
post #6 of 7 (permalink) Old 03-13-2017, 02:20 PM Thread Starter
Got the boot on by using spray silicone and some muscle. Can't believe the boot fit over the lever. But it works perfectly. Thanks for the suggestions.
Chris
JDGE70 is offline
post #7 of 7 (permalink) Old 03-15-2017, 08:11 AM
IRONBLOCK's Avatar
Chris,
Glad to hear that things worked out for you. I never thought to use silicone on the gear shift lever (and tower?). Hot water works miracles for tight tubes, hoses and stiff rubber parts.
Mark
