2600 Spider brake line fittings - Alfa Romeo Bulletin Board & Forums
 2Likes
  • 1 Post By PS70
  • 1 Post By PS70
post #1 of 11 (permalink) Old 04-18-2019, 07:36 AM Thread Starter
alfa123ca's Avatar
Hi all, I am considering changing the brake lines on my 63 front disc brake rear drum brake spider. Does anyone have a list of the fittings needed for the brake lines themselves?
Cheers, John
alfa123ca is offline
post #2 of 11 (permalink) Old 04-18-2019, 10:50 AM
PS70's Avatar
John,
Is that what you need ?
Milanoguy likes this.
Last edited by PS70; 04-19-2019 at 10:17 AM. Reason: Update : I and J + translation + thread count
PS70 is online now
post #3 of 11 (permalink) Old 04-18-2019, 04:18 PM
tubut's Avatar
This is a great list, Serge!
I think this should become a sticky thread.
-Ruedi
[SIZE="1"]'63 2600 Touring Spider (AR 191437, the car that started the 2000/2600 International Register, reassembly in progress)
ex-'65 2600 SZ (AR 856043, the car in my avatar, sold as resto project to Austria)
Maintainer of a private 2600 SZ register (not the one in the Netherlands).[/SIZE]
tubut is offline
post #4 of 11 (permalink) Old 04-18-2019, 11:32 PM
PS70's Avatar
Thank you Ruedi,
So I have completed the chart : translation of some French words and meaning of I and J.
Best thing should be to have the same for 2000 and 2600 with 4 discs as well.
For the 2000 I have done the work but as I have adapted front discs, it is not correct :
PS70 is online now
post #5 of 11 (permalink) Old 04-19-2019, 03:46 AM
Redmerlin's Avatar
Small world - I have just taken the servo out of my 2600 spider and was considering putting a bypass pipe in so I could drive the car while it was being rebuilt.
The two fittings on top of the servo routes B and C have a different sized fitting . Needing a 11mm and 12mm spanner to remove. Is this is what is referenced as filet B input 7/16 C output 3/8 ?
Redmerlin is offline
post #6 of 11 (permalink) Old 04-19-2019, 07:49 AM
tubut's Avatar
No. These references are to thread diameter (all Girling stuff is Imperial, although I'm pretty sure Alfa made the brake lines and fittings in-house). What needs to be added is thread count. For example, I don't remember if it's 7/16-20 or 7/16-24 an will have to dig up a list I found on the Internet some years ago.
-Ruedi
tubut is offline
post #7 of 11 (permalink) Old 04-19-2019, 08:55 AM
PS70's Avatar
To explain my drawing : the fluid goes from the reservoir to the calipers and pistons.
On one tube, imput is always the entry of the tube and output the exit.
So on tube B for example, the imput is on the master cylinder and the output is on the servo (which is in fact the imput of the servo = very confusing)
From my point of view (but my memory can be wrong) the 2 fitting on the servo should be the same : diameter of the tube = 8/16 - Form = F - Diameter of the fitting = 3/8
Ruedi is right : thread count is needed. I should have it. I come back ...
PS70 is online now
post #8 of 11 (permalink) Old 04-19-2019, 09:01 AM Thread Starter
alfa123ca's Avatar
Thanks Serge, yes that is what I needed!
Cheers, John
post #9 of 11 (permalink) Old 04-19-2019, 09:15 AM
PS70's Avatar
Good !
Just updated with thread count.
alfa123ca likes this.
PS70 is online now
post #10 of 11 (permalink) Old 04-19-2019, 09:34 AM
PS70's Avatar
Updated once again. On Master Cylinder we have 2 mals but clearly I have a doubt on the fact that both are 7/16x20. May be it is 7/16x20 + 7/16x24 (or 3/8x24). The 2 tubes have different diameter (In = 1/4, Out = 3/16)
PS70 is online now
post #11 of 11 (permalink) Old 04-19-2019, 10:19 AM
PS70's Avatar
Sorry, don't take into account the last post. All is clear now on the drawing online upstairs.
PS70 is online now
Similar Threads
Emergency Brake Handle Mounting Problem - 2600 Spider adamsdf 1900, 2000 & 2600 (1950-1968) 9 05-01-2014 12:22 PM
brake fittings, brake nuts - review GTD Giulietta & Giulia (1954-65) 15 11-01-2013 10:00 AM
brake line fittings size radibob GT (1963-1977) 1 05-30-2012 11:47 PM
Wanted: Rigid brake line for 89 Spider rzeigler Alfa Romeo Parts For Sale & Wanted 3 11-20-2008 07:09 AM
Brake line flares and fittings - '67 105 Single Circuit brakes w/ Booster jarrington Suspension, Steering, Brakes, Wheels & Tires 0 05-28-2008 09:45 PM
