Inside Superleggera - Adventure in time - Page 9 - Alfa Romeo Bulletin Board & Forums
 43Likes
post #121 of 216 (permalink) Old 01-18-2019, 02:31 PM
Hi Chris,
I had the same problem, I used some examples of wiring schemes and made some myself.
Would you like me to post them here for you, or do you have a good example?
Just curious, you say that you are aware that the original wires were black cotton, those wires are available from different sellers, very good quality, modern standard, why do you then choose to make them in plastic? Or is this just a test cable and will you make the black version later?
Goofymike is offline
post #122 of 216 (permalink) Old 01-18-2019, 11:42 PM Thread Starter
pescara's Avatar
Hello Mike,
Thank you but for instance I manage the wiring. Because I make some some improvements and / or modifications, some "upgrades" if you want.
For the wires, I have all in "old cotton" design (but coloured) except for two or three in actual slim plastic (there was a lot of waiting at the supplier for some colors). They will be invisible anyway.
And I think I found a solution for the rear filament with turn lights and brakes
5I have to do some tests now...
Chris, in love with Alfa from...'68, but it wasn't always reciprocal !
pescara is offline
post #123 of 216 (permalink) Old 01-19-2019, 12:01 AM
I missed the fact that you were looking for a solution for the rear lights, both brake and turn signal.
Best aftermarket solution is from https://www.autoelectricsupplies.co.uk/product/167
Works great
post #124 of 216 (permalink) Old 01-19-2019, 04:45 AM
PS70's Avatar
Hello Chris,
Originally Posted by pescara View Post
I have already asked, but I would like to know what is the wiring diagram to be able to operate the rear turn signals and stop lamps on the same filament, giving priority to turn signals ? (like the classic ford mustang, for example).
A take the assumption that you are able to provide a stop signal and an alternative turn signal.
I spend a lot of time to imagine the diagram (I'm not an electrician) but I suppose this will work :
Relay are "Changover contact". May be a resistor on the turn signal will be needed ?
I send you details by mail.
PS70 is offline
post #125 of 216 (permalink) Old 01-19-2019, 06:00 AM
PS70's Avatar
Works great
Didn't see this reply.
Much more easier than my solution with 6 (2x3) relais
PS70 is offline
post #126 of 216 (permalink) Old 01-19-2019, 07:42 AM Thread Starter
pescara's Avatar
Hi Serge,
Thanks for your info.
I imagined a system with 3 relay with 5 pins. I think it's work. I will try yours as well.
But, maybe the solution indicated by Mike is the simple one...
Chris
pescara is offline
post #127 of 216 (permalink) Old 01-19-2019, 08:23 AM
Hi guys,
Buying the lucas is the best, easiest way.
If you do want to do make this yourself, let me know, I can sent you the drawing to make it yourself, probably cost you 15 euro for the 3 relais you need.
Mike
post #128 of 216 (permalink) Old 01-19-2019, 09:01 AM
PS70's Avatar
Hello Mike,
I don't want to make this by myself but I would be curious to see you drawing in order to compare to what I imagine.
PS70 is offline
post #129 of 216 (permalink) Old 01-19-2019, 09:33 AM
Hi you would need the normal turn signal relay and 2 DPDT relays, those are available from any electronics shop at a few euros.
DPDT is ‘Double Pole Double Throw’, quite easy and cheap.
Good luck Mike
post #130 of 216 (permalink) Old 01-19-2019, 10:19 AM
Danny Wilde's Avatar
Perfectly Mike.
70' Ghibli SSS (one-off - featured in Octane UK #183 + Octane Deutschland #38)
63' 2600 Touring H-Top S.1
64' 2600 Touring H-Top S.2
74' Montreal
66' Moretti 1100R
76' Fiat 130 Coupé
68' Datsun Roadster 2000 Racing...
16' 991 GT3 RS soon...
Danny Wilde is offline
post #131 of 216 (permalink) Old 01-19-2019, 11:47 PM
PS70's Avatar
Thank you Mike !
DPDT Relay are great (I do not know).
PS70 is offline
post #132 of 216 (permalink) Old 01-21-2019, 09:05 PM Thread Starter
pescara's Avatar
body, what kind of wire ?
The alu body of the 1900 is finished by a wire running all the way through the car.
Do you know what kind of wire must be used ? The wire must made to last long with aluminium I suppose ?
pescara is offline
post #133 of 216 (permalink) Old 01-22-2019, 02:39 AM
Chris what about using stainless steel, I assume there to be less galvanic reaction and therefore less potential for rust? I guess it would be harder to bend to profile but if it was pre-rolled to shape not so hard.
Tim
exhausted is offline
post #134 of 216 (permalink) Old 01-22-2019, 08:15 AM Thread Starter
pescara's Avatar
Yes Tim, it's a nice idea. I think I will use that.
I will protect by an application (maybe epoxy) to limit direct friction with aluminum.
Chris.
pescara is offline
post #135 of 216 (permalink) Old 01-22-2019, 10:09 AM
tubut's Avatar
It appears bare aluminum grounding wire is available in a number overall outside diameters (for example, see this seller in China). I found it by entering "bare aluminum" in the search box of this site. Note that some sellers have 1m minimum orders, while others have 1km minimum order.
-Ruedi
[SIZE="1"]'63 2600 Touring Spider (AR 191437, the car that started the 2000/2600 International Register, reassembly in progress)
ex-'65 2600 SZ (AR 856043, the car in my avatar, sold as resto project to Austria)
Maintainer of a private 2600 SZ register (not the one in the Netherlands).[/SIZE]
tubut is online now
