Inside Superleggera - Adventure in time - Page 11 - Alfa Romeo Bulletin Board & Forums
 43Likes
post #151 of 216 (permalink) Old 02-16-2019, 06:59 AM Thread Starter
pescara's Avatar
I worked on the engine, the famous "clean" engine in this thread...
I understand that it's necessary to install the mechanical fuel pump in addition to the electric one. I thought not to put it back up and put a lid instead.
The mechanical fuel pump to act as a gas pressure regulator in this way.
Do you have any information on this ?
In this case I have to get the membrane with the central rod (yellow arrow on pÓcture) for the mechanical pump. But I would not want to buy the complete set. Someone has an info for that ?
Chris, in love with Alfa from...'68, but it wasn't always reciprocal !
pescara is offline
post #152 of 216 (permalink) Old 02-16-2019, 10:52 AM
PS70's Avatar
Salut Chris,
Do you know if the membrane can be disassociated from the set ?
If it is the case, the Citroen Traction have a quite large membrane that you could recut :
https://www.renelauto.fr/alimentatio...sence-sev.html
PS70 is online now
post #153 of 216 (permalink) Old 02-16-2019, 12:10 PM Thread Starter
pescara's Avatar
Serge,
I diidn't think about that. It's a really great idea. So simple and so obvious ! Done !
pescara is offline
post #154 of 216 (permalink) Old 02-16-2019, 12:21 PM Thread Starter
pescara's Avatar
Some works on the engine....
The internal surface condition of the engine is excellent. I leave it so.
Custom built pistons (forged aluminiium) and bored cylinders.
But not easy to work correctly without correct workshop manual. I use the 2000 and the 1900 pre 1954...
pescara is offline
post #155 of 216 (permalink) Old 02-16-2019, 12:31 PM Thread Starter
pescara's Avatar
work in progress
PS70 likes this.
pescara is offline
post #156 of 216 (permalink) Old 02-16-2019, 06:26 PM
I like those pistons, with that valve pocket design they are going to make more power nice, such attention to the details Chris big effort from you and your team, this will be a beautiful car when it is finished.
Tim
exhausted is offline
post #157 of 216 (permalink) Old 02-18-2019, 09:09 AM
GIGI 1750's Avatar
ciao Chris,
here the membrane
AR 1900 CSS'56-AR 1750 gtv'68-AR Giulia 1600TI'62-AR Brera 2.2Jts
Ex AR Giulietta SS low nose 10120.00091,Fiat 750 Zagato Targa Florio'57
GIGI 1750 is offline
post #158 of 216 (permalink) Old 02-19-2019, 08:05 AM Thread Starter
pescara's Avatar
Some work done today.
I find the trimming of the distribution very subtle on this model, compared to the series 101 and 105.
pescara is offline
post #159 of 216 (permalink) Old 02-19-2019, 08:10 AM Thread Starter
pescara's Avatar
It starts to look like an engine
We made the tools for the valve settings. It's much easier to adjust than 101 and 105 ....
pescara is offline
post #160 of 216 (permalink) Old 02-22-2019, 09:14 AM Thread Starter
pescara's Avatar
The coachbuilder said "I'm going to do some aluminum today"...
it's raw for now, it's not "ready to paint"
pescara is offline
post #161 of 216 (permalink) Old 02-27-2019, 10:14 AM Thread Starter
pescara's Avatar
I rebuilt the starter engine I will use on the car. Some pictures by short.
pescara is offline
post #162 of 216 (permalink) Old 02-27-2019, 10:21 AM Thread Starter
pescara's Avatar
Now and before ...
We sandblasted the doors structure. We found on the hinges some numbers. We think it was a way for Touring to recognize who worked on the bodywork. 2 companions on each side, two numbers on each side.
Could this possibly facilitate bodywork repairs if the car came back with an accident?
Or does someone have a better idea ?
pescara is offline
post #163 of 216 (permalink) Old 02-27-2019, 08:58 PM Thread Starter
pescara's Avatar
Coming back to the clutch system
I am looking for the part nr 15 on the picture.
If you have it, could you give me dimensions ? I will made it. I will buy it if you want to sale...
pescara is offline
post #164 of 216 (permalink) Old 03-07-2019, 12:19 AM Thread Starter
pescara's Avatar
I put back the fuel pump. Thank you Serge !
pescara is offline
post #165 of 216 (permalink) Old 03-17-2019, 11:01 PM Thread Starter
pescara's Avatar
different release bearing for clutch
Hi there,
As usual, another peculiarity of the car. The release bearing it's not the common one. The one on the market is the flat one, and I am looking for a thicker one.
I saw a thread in this forum with the correct bearing, but no soure for that.
Do you have some source for this release bearing ?
Thanks in advance...
pescara is offline
