2000 fog light&indicator lenses reproduction - Page 2 - Alfa Romeo Bulletin Board & Forums
 3Likes
post #16 of 21 (permalink) Old 12-23-2017, 06:51 AM Thread Starter
Send a message via Skype™ to franjo mokina
Thanks!
Franjo
http://www.alfafranjo.com/
franjo mokina is offline
post #17 of 21 (permalink) Old 12-23-2017, 08:59 AM
tubut's Avatar
Originally Posted by franjo mokina View Post
Fixed,i wish you all the best in 2018.
Divotandtralee-good idea about LED bulb! What standard are original bulbs?
Good job, Franjo!
FYI, most period flasher relais have timing intervals are driven by the current of the bulbs. This is why the timing interval changes (faster clicking) if a bulb is burnt out. Hence, converting the direction indicator light (blinker) to LEDs with less power consumption than bulbs would have the same effect as a burnt out bulb and owners would have to change the flasher unit to a solid state version if one decides to go with LED.
-Ruedi
[SIZE="1"]'63 2600 Touring Spider (AR 191437, the car that started the 2000/2600 International Register, reassembly in progress)
ex-'65 2600 SZ (AR 856043, the car in my avatar, sold as resto project to Austria)
Maintainer of a private 2600 SZ register (not the one in the Netherlands).[/SIZE]
tubut is offline
post #18 of 21 (permalink) Old 12-23-2017, 10:41 AM Thread Starter
I am not good in electric stuff...only foglight need LED bulb.Is there the same colour tone and brightness LED bulb available for foglight and technically-will that work without any additional gismos?
Franjo
post #19 of 21 (permalink) Old 12-23-2017, 12:05 PM
VabeneGTV's Avatar
Resistors placed in line to an LED will cause an LED to flash normally Regrettably I don't know the correct resistance, but I'm sure the correct values are easily obtained via a search online.
VabeneGTV is online now
post #20 of 21 (permalink) Old 12-23-2017, 01:00 PM
tubut's Avatar
Nope, they would have to be in parallel with the LEDs, not in-line (which would make matters worse and dim the LEDs).
-Ruedi
tubut is offline
post #21 of 21 (permalink) Old 12-23-2017, 01:07 PM
tubut's Avatar
The fog light bulb was rated 45W. It can be substituted by a LED without problems.
The parking light/direction indicator light is dual-filament bulb rated at 5W/20W.
franjo mokina likes this.
-Ruedi
tubut is offline
