May the circle remain unbroken - 10204 01488 - Page 56 - Alfa Romeo Bulletin Board & Forums
 208Likes
post #826 of 914 (permalink) Old 05-04-2019, 05:49 PM Thread Starter
Push hard and live
DPeterson3's Avatar
What a bummer of a day...
What appeared to be a magically good wiper motor and system, has just gotten worse and worse. At this point, the motor seems completely dead. But, maybe it's my switch? I can't find any schematic for which color wires connect to which other color wires to turn on hi/low/return-park, so can't be sure if its the fresh motor or my old switch that died. Everything worked great, but something was dropping current to ground.
Jay suggested I switch the two wires on the foot pump. I've pulled the foot pump/switch out, and checked every variation of connection. As near as I can tell, it's a switch. Neither connector is also connected to ground. Plus, if the red wire were somehow dumping to ground causing the current drain, it would also trigger the motor to run. Red Herring, I think.
When I finally got to the head-exploding point, I shifted to the driver's door window installation. Made good progress. The felt sliders are glued into their guides, and should be ready to install tomorrow. Also did some research on shifting away from AN fittings back to the original hot-water manifold for the front of the engine. I think that'll look nice.
deepblue likes this.
Don P
Carson City, NV
Past Alfas...
Current Alfas
Oops. Add to the "present" list, 10204 01488, 2000 Touring Roadster project
And past...
1946 Luscombe 8A
And present...
64 Mooney M20E ("Rambo". My faithful steed for over 40 years) Over 55 years old, and just returned from a trip to Argentina in him
Newest in the fleet
2010 Triumph Thunderbird
DPeterson3 is offline
post #827 of 914 (permalink) Old 05-04-2019, 06:24 PM
deepblue's Avatar
Sometimes just when your head is going to explode, new possibilities emerge. Not FUBAR just a SNAFU.
DJ
deepblue is offline
post #828 of 914 (permalink) Old 05-05-2019, 10:48 PM Thread Starter
Push hard and live
DPeterson3's Avatar
Check, check
Did the prescribe “bench check” on the wiper motor. Going back for rework. Getting it out won’t be fun.
Did the mod on the heater-water feed tube. First OE piece I’ve cut to make work. Feels sort of “Blue Velvet-ish”. Here’s the trans picks. In a day or two I’ll have the final installation photos.
Don P
Carson City, NV
Past Alfas...
Current Alfas
And past...
1946 Luscombe 8A
And present...
Newest in the fleet
post #829 of 914 (permalink) Old 05-06-2019, 04:47 AM
divotandtralee's Avatar
Since the 102 crowd might not have enough input from a limited population, you might find this applicable to your car.... it's all electrons chasing electrons in the end and they don't identify with what car it is in. FYI, + or - ground could matter though, as I recall.
https://www.alfabb.com/bb/forums/giu...io-wipers.html
https://www.alfabb.com/bb/forums/giu...tor-folly.html
Sorry if this adds more confusion to the mix. I hope not.
I do know the floor switches are very finicky by the way they are constructed so don't rule out it could be the core of the problem.. The dash switch not so much. ON or OFF
divotandtralee is offline
post #830 of 914 (permalink) Old 05-08-2019, 03:11 AM Thread Starter
Push hard and live
DPeterson3's Avatar
Two steps forward...
We got the tank sealed, tested, and installed. Heater water manifold modified, repowdered, installed, and tested. Wiper motor out, diagnosed, and returned to rebuilder for rework.
Seat back received from Jay. Now to make a jig to build up some new seat backs.
Got left window regulator fully installed, lubricated, andready. Guides have their felt installed, and are ready to go into the door.
Need to find a better air filter element. The one from CA won’t do.
Johnny has started on the rear seat surround.
Don P
Carson City, NV
Past Alfas...
Current Alfas
And past...
1946 Luscombe 8A
And present...
Newest in the fleet
post #831 of 914 (permalink) Old 05-08-2019, 04:30 AM
Baldwin Filter has a great website to help size what you want.......You plug in the dimensions and they come up with a solution. Baldwin Filters E-Catalog
You might have to double up on the cartridge to get the fit. That's what AR did on Spica Spiders. You can also use foam gaskets to make up for variances. I've never had to do that. The Giulietta Normale is on the shelf and fits perfectly out of the box, just as an example. You would never find it searching by application ( AR Giulietta) on their website but you can by dimensions.
post #832 of 914 (permalink) Old 05-08-2019, 12:23 PM
IRONBLOCK's Avatar
Bottom breather...
You are making great progress on the Touring Roadster! I have purchased two of these modern foam air filters from C.I. for my air filter canisters and they fit and work pretty well -even better with the modification you suggested to the air filter canister bottom. The filter comes with a can of spray oil that you treat the foam with.
https://www.centerlinealfa.com/catal...750-101-veloce
Name:  Air Filter Canister Two-Liter Mod.jpg
Also, if anyone needs one or two of these veloce air hoses, I still have a few in-stock...
https://www.centerlinealfa.com/catal...ke-hose-veloce
$85 delivered in the contiguous 48 states or $85+actual shipping overseas. They fit the Veloce, the 102 Berlina or the elbow can be cut off to fit the Touring Roadster. Send a PM if interested.
Name:  750 102 air duct main.jpg
Mark
IRONBLOCK is offline
post #833 of 914 (permalink) Old 05-10-2019, 05:20 PM Thread Starter
Push hard and live
DPeterson3's Avatar
I just spent 20 minutes looking, and could find no size chartson the Baldwin site.
Don P
Carson City, NV
Past Alfas...
Current Alfas
And past...
1946 Luscombe 8A
And present...
Newest in the fleet
post #834 of 914 (permalink) Old 05-10-2019, 06:37 PM Thread Starter
Push hard and live
DPeterson3's Avatar
Seat backs
First step. Build an assembly jig. After this is done (more to do, yet), build bending jigs. Order some 4130. Dust off my oxycet skills.
What could possibly go wrong?
Don P
Carson City, NV
Past Alfas...
Current Alfas
And past...
1946 Luscombe 8A
And present...
Newest in the fleet
post #835 of 914 (permalink) Old 05-10-2019, 11:16 PM
tubut's Avatar
Don, I have a hunch that there's so much to be learned from rebuilding the seat frames (or seat back) that the topic deserves a separate thread that may become sticky at some point in the future.
-Ruedi
[SIZE="1"]'63 2600 Touring Spider (AR 191437, the car that started the 2000/2600 International Register, reassembly in progress)
ex-'65 2600 SZ (AR 856043, the car in my avatar, sold as resto project to Austria)
Maintainer of a private 2600 SZ register (not the one in the Netherlands).[/SIZE]
tubut is online now
post #836 of 914 (permalink) Old 05-11-2019, 06:20 AM
You have to select "catalog Information" TAB then Size chart at bottom of drop down menu
Then select metric or Inches then .....
As an Example -- I loaded (mm's) Length 310 O.D 113 I.D. 87 and selected ROUND and then checked +/- 1.0 and came up with 24 choices with dimensions and applications and PHOTOS of the filter.. Some are for tractors .. compressors .. oil field rigs.. etc. but they might be your oyster.
post #837 of 914 (permalink) Old 05-15-2019, 10:04 AM Thread Starter
Push hard and live
DPeterson3's Avatar
In addition to the seat back going missing, and my nicely rebuilt wiper motor taking a crap, I discovered that the driver's side glass had acquired some pits and checks from just sitting on my workbench. Grrrr.
Glass company says they'll have a new one for me by Friday. Yeah. Right.
Wiper motor company promised to ship the repaired motor this past Monday, but just called this morning to confirm my address. Which was written on the label when I returned it to them. Motor needed by day after tomorrow to meet some other deadlines.
Seat back now at a local fabricator for a quote on making several Posted under a separate thread.
Oh - when son was refueling freshly sealed-up tank, he didn't notice a rubber cap was on the fuel spigot, and so deposited that into the tank. Haven't been able to find it via the filler or sender ports, so tank will be coming off again later today.
And grandson thought it would be funny to place a dead bird into his girlfriend's backpack. His two-day in-school suspension ended yesterday, but he's still restricted to base around here.
Upholsterer has now missed about his fourth "I'll have it done by Monday" promises. Too late to find another one I trust, so I'm resorting to taking him cases of beer as a bribe to get moving.
I picked a bad week to stop drinking. Again.
horsewidower likes this.
Don P
Carson City, NV
Past Alfas...
Current Alfas
And past...
1946 Luscombe 8A
And present...
Newest in the fleet
post #838 of 914 (permalink) Old 05-15-2019, 11:06 AM
horsewidower's Avatar
And here I was about to stop drinking for a week. Lesson learned.
But wait there's more: View my 164LS thread:
You didn't...oh yes I did II. Deposit down on another vehicle...stop the madness!!!
horsewidower is offline
post #839 of 914 (permalink) Old 05-15-2019, 11:31 AM
twoliterlover's Avatar
How about a bolt on piece on seat back for 3 way belt?
Don, I am frustrated in trying to do a three point seat belt on my spider. While you are making a new back for yourself (and dozens to sell others, I suspect), how about making some piece that could be screwed onto the top outer side like the piece that comes on the seat backs pf later spiders with three point? That way we who want three point belts could drill holes and screw them on and the belt over shoulder would not slip off. You are the inventive one. I know you can do it. Of course it has to be something that can be added after the upholstery is on.
twoliterlover is offline
post #840 of 914 (permalink) Old 05-15-2019, 02:32 PM
PSk
While a good idea, that seat frame has not been designed for the load you are about to put on it (when in an accident) and the seat will just fold forward. Result is you might have well just been wearing a lap belt.
At least if bolted to the B pillar it should be strong(er)
'71 1750 Series 2 GTV:
PSk is offline
