Alfa 1900CSS new gearbox - Alfa Romeo Bulletin Board & Forums
post #1 of 8 (permalink) Old 10-27-2015, 01:31 PM Thread Starter
Hi all,
The gearbox of the alfa 1900 seems to be the weak point.
With an italien friend who knows well that kind of car, we are trying to modify the gearbox to make it silence and reliable.
The gear module need to be changed and the drive shafts and fixed gear need to be rebuild.
To get a fair price we are trying to make several gearbox with 5 gears. We would like to rebuild the one with the floashift, but we haven't got any model.
If somebody got a gearbox with the floarshift of that model that would be helpfull for us. We would need it for 2 months to make a copy of the specifics parts.
You can join me at [email protected]
vaujoyeuse is online now
post #2 of 8 (permalink) Old 01-22-2016, 03:39 PM
Hi,
I and two other alfa 1900css owners are searching for the fifth gears and reverse gears from 1900css 5-speed gearbox
rgds Franco
franco-veloce is online now
post #3 of 8 (permalink) Old 08-03-2016, 04:11 PM
Hi ,
I am still searching for the fifth gears and reverse gears from 1900css 5-speed gearbox
rgds Franco
post #4 of 8 (permalink) Old 12-16-2016, 04:07 PM
Hi All,
we are going to make NEW gears /synchro /bearings /etc
from 1900 seris 4 and 5 speed gearboxes
rgds Franco
post #5 of 8 (permalink) Old 12-17-2016, 04:52 AM
Great news
Philippe
58 Spider V, 61 SZ, 62 Sprint, 62 SS, 1900 CSS 56
philippeclaude is offline
post #6 of 8 (permalink) Old 07-05-2017, 04:41 AM
Hello Franco
Aussie calling. we have just finished restoring a 1900CSS and on driving it, found the gearbox was restored by a butcher not a technician. it needs a lot of parts including a 5th gear. we would be interested in supporting you plan.
have you made any progress Cheers Bryan
broome330 is offline
post #7 of 8 (permalink) Old 07-05-2017, 03:57 PM
Hi All,
At this moment we are making NEW gear sets for 5 speed gearbox in modern High Quality
we have NEW in modern High Quality the syncro rings for 5 speed gearbox.
and we are going to make complete conversion set for a floorshift
for rebuilding an steering shift gearbox into a floorshift .
rgds Franco
post #8 of 8 (permalink) Old 07-10-2017, 05:37 AM
il-mito's Avatar
1900 5-speed gearbox
Originally Posted by vaujoyeuse View Post
Hi all,
Hi all,
I have the same problem with my gearbox and the situation of parts is becoming worse and worse.
My recommendation now:
Bernd Salewsky in Aachen, Germany, specialized in repair and reproduction of engine and gearbox parts, took care of this problem and developed a new Gear Set. The design is done by modern construction methods, Material and Hardening process. A different pressure angle is reinforcing the root of the teeth.
A small series is already started and will be ready to order in the end of August 2017.
Of course, Bernd can not only supply the parts, but also completely repair the gearbox.
Best regards
Jürgen Döhren
il-mito is offline
