164 A/C conversion colder air MOD - Alfa Romeo Bulletin Board & Forums
 2Likes
  • 1 Post By Alfisto Steve
  • 1 Post By Roadtrip
post #1 of 11 (permalink) Old 08-18-2019, 07:32 PM Thread Starter
Alfisto Steve's Avatar
164 A/C conversion use kit 50-2551A https://www.oldairproducts.com/produ...poa-update-kit
CAVEAT: I JUST NOTICED SINCE THE ORIGINAL TRINARY switch is retained I wonder why you would even need the new low pressure switch except to plug the port. The trinary switch has both low and high pressure switches.
Here's what my friend Ralph did on his 91 164L. He sent me these pictures I may have to resize to get on here.
Deleted original POA valve body & installed new manifold kit 50-2551A. Note: the 50-2551A kit has R134a fitting The 50-2551 kit has R12 fitting so would need the NAPA steel R134a fitting added to R12 port.Pic#1
Converted to R134a. Pics#2&3
Relocated clamp & thickened bushing to accommodate configuration of new manifold. Pic#4
Had new hose made for new manifold from/to compressor with proper size fitting @ new manifold end. Pic#5
New manifold fitting accommodates 164 R12 or R134a expansion valve capillary tube. Pics#6
Plugged & capped one unused fitting on new manifold (orange cap distinguishes from blue cap low side & red cap high side). Pic#8
Installed new low pressure switch (comes with kit) circuit by added into existing harness @ red connector plug to trinary switch on receiver dryer. Pics#9
See the oldair link above to see the new manifold that replaces POA valve now on USA spec 164s.
I posted this on downloadable guides and my maintenance sticky, too.
I have seen this mod on his 164L in Orlando Viva Alfa event and at Neville's Mighty Oak event, too.
horsewidower likes this.
Virginia Beach, VA
My Maintenance Sticky:
Alfisto Steve is offline
post #2 of 11 (permalink) Old 08-19-2019, 02:25 PM
Roadtrip's Avatar
How much was he able to drop the blower outlet temperatures with this mod? Cost?
John Stewart
74 Spider
91 164S
Roadtrip is online now
post #3 of 11 (permalink) Old 08-20-2019, 04:32 AM Thread Starter
Don't know on temp but manifold part cost $95.
Cost of new hose unk. I will ask Ralph those questions. Standby to stand by.
I have bought the manifold kit from ebayer being shipped to me here in VB this week.
He just said about 49F at dash with 95F ambient. I got about 59 the other day at 87F ambient in BB1. Used to get 39 at dash with my 164B with R12.
I got about 55 at dash today in BB1 with R134a conversion going to town on interstate today. Only R134a components in BB1 are the Parker Hanneffin R134a expansion valve and the Sanden SD-7H15 compressor OEM for 94/95 24v. As for BB1 164L I have larger 24v radiator behind to original 91 condenser.
Virginia Beach, VA
post #4 of 11 (permalink) Old 08-20-2019, 09:39 AM
Del
This is interesting. Will want to know just how much diff this change really makes, not that I need it here. The 91S a/c could be a lot better, though, is not nearly as good as the LS.
Del
Seattle
1989 Milano, Shankle Sport
1991 164S, stock
1994 164LS (~Q)
1972 Morgan 27
previously owned since 1964:
Del is offline
post #5 of 11 (permalink) Old 08-20-2019, 09:46 AM
Roadtrip's Avatar
I think a parallel flow condenser helps a great deal with a R134 conversion.
Alfissimo Int. likes this.
John Stewart
74 Spider
91 164S
post #6 of 11 (permalink) Old 08-20-2019, 10:08 AM
Del
You may be correct, should be better, but when I put one of those you mentioned in, it just didn't make much difference. Granted, it may be deficient in working fluid now, or whatever, but still... the fluid pressures were within the correct working range according to the gauges when the shop finished the conversion to 134a, and yet, not a whole lot of improvement. Still pretty weak in comparison.
Will have to take another look I guess.
Del
Seattle
1991 164S, stock
1994 164LS (~Q)
1972 Morgan 27
Del is offline
post #7 of 11 (permalink) Old 08-20-2019, 02:27 PM
Alfissimo Int.'s Avatar
Larger parallel flow (like the units I have) are the biggest help with these systems. Little larger and better at removing heat. I was getting around 24F-37F out of the vents depending on ambient temps/humidity with R134a. Everything was stock otherwise. Insulation on hoses and making sure there is no air leaks in venting, you will be fine. If you have tint the better. I did not like tint so I don't have it on any car even though it helps.
Jason Minos
New: +1 619-209-0715
e-mail:admin at alfissimo.com
San Diego, CA
1989 Spider Quad. Gone
2010 Touareg TDI
Alfissimo Int. is online now
post #8 of 11 (permalink) Old 08-20-2019, 03:43 PM
Del
With the a/c system in our 91S, with a newer parallel condenser, all insulation in decent shape, working fluid pressures adequate, etc, converted over to 134a by a competent shop, we get about 45-50F at the vents. That's in Seattle, lol. Hate to think what it would do in Phoenix.
Del
Seattle
1991 164S, stock
1994 164LS (~Q)
1972 Morgan 27
Del is offline
post #9 of 11 (permalink) Old 08-20-2019, 06:18 PM
No 25+ year old car does well in phx that is Italian. The 164 was hot unless I was moving consistently. Even then it was hot with no tint, old car, blazing hot temps. There is something to say for new technology, my giulia was nice and cool in phx last time I was there.
Jason Minos
San Diego, CA
2010 Touareg TDI
post #10 of 11 (permalink) Old 08-20-2019, 07:37 PM
Del
Our LS was faultless in the hot SW whenever we drove there.
Oh, and the 91S does have the electric valve installed in the heater line as well. That helps a little.
Del
Seattle
1991 164S, stock
1994 164LS (~Q)
1972 Morgan 27
Del is offline
post #11 of 11 (permalink) Old 08-21-2019, 06:24 AM
Rogue Leader's Avatar
If theres one thing that works right on my 164 its the AC. In fact when I was talking to the guys at Alfa Auto Clinic they remarked "oh yeah your uncles car was the one with the super cold AC". Not sure what changes were made if any, but I'm not complaining.
Rogue Leader is online now
