Exhaust Pipe Flange Gasket - Interchange Info - Alfa Romeo Bulletin Board & Forums
 3Likes
  • 1 Post By RedAlfasgoFast
  • 1 Post By Alfisto Steve
  • 1 Post By richardbradford
post #1 of 7 (permalink) Old 07-30-2019, 06:34 PM Thread Starter
Cool Exhaust Pipe Flange Gasket - Interchange Info
Just spent a frustrating couple of days trying to source an exhaust pipe flange gasket for my Alfa 164L exhaust system. This is the gasket that fits between the rear pipe that exits the catalytic converter and connects with the flange on the center exhaust pipe and muffler assembly.
After ordering a new flange gasket from Alfa Parts in Berkeley (at the eye-watering price of $35.00 for one) and having it get lost in the mail, out of frustration I went to CarQuest Auto Parts (also known as Advance Auto Parts in some places). The CarQuest parts book shows a Bosal #256-203 as the gasket. I had them order a Bosal one and it turned out to be the wrong size - it was too small to fit the exhaust flange bolt layout on my Alfa. It probably fits the flanges on 164S models which have two pipes exiting the rear of the catalytic converter. This afternoon I returned the Bosal gasket and took the actual exhaust pipe and flange with me.
After a few minutes of looking at the exhaust flange gaskets CarQuest had on the shelf, we found a Victor Reinz gasket #7135 which fit perfectly. [This gasket is also known as a Mahle #7135.] I bought two of them for $1.99 each so I would have a spare. As I was paying, I jokingly told the parts man that it sure looked like a small block Chevy exhaust gasket to me. When I got home I "googled" the Victor Reinz #7135 gasket to see what it fit, and sure enough, it turns out our Alfa's use the small block Chevy exhaust gasket! This is the gasket used on all the exhaust heat risers for the Chevy 305ci and 350ci V8 engines made from 1965 to 1985. It was installed on every Chevy model that used those V8's (Blazers, Corvettes, Impalas, El Caminos, Chevelles, etc.)
Online prices for these gaskets are all over the place, from a low of $1.60 each on CARID.com, to a high of $8.88 at WalMart.com. O'Reilly's Auto Parts has them $1.99 each too, which matches what I paid at CarQuest Auto Parts. Sure beats $35.00.
Luigim likes this.
RedAlfasgoFast is offline
post #2 of 7 (permalink) Old 07-31-2019, 02:52 AM
Alfisto Steve's Avatar
Alfa 164 exhaust gasket info
Good to know, thanks.
I recently got two of those Bosal 256-203 gaskets for my 164S cat outlet. Other one for a spare. Other 164S cat rear outlet pipe uses a metal ring 60805075 ss now by 82420455. Lucky I already had OEM spare of that ring.
Here are some 164 OEM exhaust gasket parts numbers:
164B/L/S exhaust manifold gasket at heads 6ea 60506636
164B/L/S front down pipe 2ea 60510306 Centerline TH416
164B/L frt cat 60510307 COPPER TWO HOLER
164S frt cat 2ea 82473214
164B/L rear cat 60510816 copper Victor Reinz or Mahle gasket #7135
164S rear cat metal ring 82420455 for L/H pipe and 82473321 gasket Bosal #256-203 for R/H pipe flange
164B/L/S/LS/Q rear muffler inlet pipe ring 82407147, also for 164LS/Q center muffler to Cat outlet.
Luigim likes this.
Virginia Beach, VA
My Maintenance Sticky:
Alfisto Steve is offline
post #3 of 7 (permalink) Old 07-31-2019, 03:55 AM
If it the same as on a 3.0 24v UK spec 164 super, I use Autogem CEG111 gasket rings - they cost about 3 and work as well as any other.
The packet lists other vehicles as BMW 524 TD 1983+, Saab 900 turbo 1978+ and Volvo 760 GLE saloon 1988+, among others.
Other reference part numbers include: GEX446008, SBG5, 374770441 and TS-410199
Hope that helps.
Luigim likes this.
richardbradford is online now
post #4 of 7 (permalink) Old 07-31-2019, 07:59 AM
Hope that helps.
I guess this is the ring you are referencing correct? 164B/L/S/LS/Q rear muffler inlet pipe ring 82407147, also for 164LS/Q center muffler to Cat outlet.
Virginia Beach, VA
post #5 of 7 (permalink) Old 07-31-2019, 03:56 PM
That's the one. Did I understand the query correctly?
post #6 of 7 (permalink) Old 08-17-2019, 07:31 AM
beeton's Avatar
For my 164 ls (95) exhaust manifolds to flex pipes, Walker part, around $3-5. I will dig up the number BUT alternate versions may be tight i/d and not sit on the flange properly.
beeton is online now
post #7 of 7 (permalink) Old 08-30-2019, 12:46 PM
JEC
I just used one for a 1986 Volkswagen Cabriolet, perfect fit. There were various VW/Audi fitments that came up as a cross ref for the three bolt flange gasket when I googled the Alfa number.
JEC is offline
