Any difference in exhaust pipes by year? - Alfa Romeo Bulletin Board & Forums
 5Likes
post #1 of 29 (permalink) Old 06-02-2019, 11:33 AM Thread Starter
Rogue Leader's Avatar
My pipes while not leaking are REALLY rotten around the joints. On ebay someone has a nice downpipe and also cat and the pipe behind the cat for a 94-95 164L. It LOOKS the same as on my 91 S, is it the same? I figure if I buy those I can then just build the rest with a vibrant resonator and Borla muffler and get to the sound I want on this car.
Rogue Leader is online now
post #2 of 29 (permalink) Old 06-02-2019, 01:48 PM
Alfisto Steve's Avatar
I would have to see the listing to see what you are talking about as there isn't a 164L model in 94-95. I only see a 91-93 164L set of downpipes and cat on ebay.
94-95 models 164LS/Q have 24v engines with SS headers (will not fit 12v engines), larger down pipes than 164S, different cat, different center muffler.
That being said if they are selling the complete 24v two downpipes, cat and center muffler you could cut your front flanges off your S downpipes and the 24v ones and weld S flanges on 24v pipes.
Now if they are selling 91-93 164L down pipes, cat and center muffler you could use that set up on 164S but down pipes and cat smaller diameter. You have to use L cat with L center muffler and L down pipes.
Lakeland, Florida
Virginia Beach, Virginia
My Maintenance Sticky:
Alfisto Steve is offline
post #3 of 29 (permalink) Old 06-02-2019, 02:54 PM
Alfissimo Int.'s Avatar
I see the ones on ebay. Nothing you want. Cat is aftermarket which typically don't work well. Flex pipes look ok.
I have downpipes and a S cat if interested USED and it good condition. You can build from cat back.
Let me know?
BTW no such thing as a 94-95 164L. Either LS/Super or Q/QV 24V.
1991-1993 164B/L has one style exhaust
1991-1993 164S has two different styles, one is early which sits lower, and later which sits higher due to different flex pipes.
1994-1995(98')164LS/Super and Q/QV have same exhaust system but with different tail ends.
Jason Minos
New: +1 619-209-0715
e-mail:admin at alfissimo.com
San Diego, CA
1989 Spider Quad. Gone
2010 Touareg TDI
Alfissimo Int. is offline
post #4 of 29 (permalink) Old 06-02-2019, 06:12 PM Thread Starter
Yeah these are what I'm talking about:
https://www.ebay.com/itm/exhaust-3-0...L/264305109959
https://www.ebay.com/itm/exhaust-3-0...l/264305112547
Was hoping to offer the guy 200 bucks for everything and hope for the best since that stuffs been up there for a long time. Just went with what was in the ad.
But yeah I took a look under my car again today and noticed the part by the cat is significantly different. My manifolds are ok I think but from there on there is nothing salvageable, the flanges are all held together by rust, if you were to try and take them apart they would crumble.
Replacing a catalytic converter in NY is a pain in the ***. Technically installing a used one is illegal. No shop will touch it, so what I'd need to do is remove my rotten exhaust, install this, and then head to the shop with no pipe/muffler. Was hoping to get something I could go to the shop with for them to install but it looks like it would need to be brand new. Need to talk to the guys doing my exhaust to see whats most cost effective.
post #5 of 29 (permalink) Old 06-03-2019, 03:52 AM
Those are from a 1991 164L. In addition to using them on an S it would be nice to have the front mounting bracket for the cat from the 164L as it is different from the larger 164S cat mounting system. The 164S uses spring mounting system instead of the two rubber rings.
Also as you can see the L cat has single outlet whereas the 164S has dual.
The L uses two copper gaskets for cat. Front one hard to find. The S uses two in front and two in rear also hard to find.
Longer downpipes are for 91-93 164B/L whereas shorter ones w/fatter flex pipes are for 164S.
gasket info:
164B/L/S manifold to heads copper gaskets {not shown) are 60506636
164B/L/S down pipe gaskets 60510306 Centerline TH416
164S front cat gaskets 82473214 2 each
164S rear cat gaskets L/H 82473321 R/H steel ring 82420455
164B/L frt cat gsk 60510307 one-piece copper
164 B/L rear cat gasket copper 60510816
164B/L/S/LS/Q rear muffler gasket 82407174 large steel ring
Lakeland, Florida
post #6 of 29 (permalink) Old 06-03-2019, 06:33 AM
Alfa 164S front down pipes and gaskets.
Lakeland, Florida
post #7 of 29 (permalink) Old 06-03-2019, 06:42 AM
Yup those. Aftermarket CAT and flex pipes look ok.
Jason Minos
San Diego, CA
2010 Touareg TDI
post #8 of 29 (permalink) Old 06-03-2019, 07:14 AM Thread Starter
Wow thanks for all the info and pics!
Very interesting, the listings changed overnight. I am 100% sure yesterday both said 1994-1995.
So the question now is, lets say I get these for $200, are they worth getting over having something made even from the manifolds back. The mounting on mine to the car is pretty rotten and horrifying too, so I'd need to replace that as well. In that case a custom piece with mounting may be preferable, especially if these gaskets are NLA. The L pipes look a little smaller?
I can't believe how many little things are different between the L and the S despite them having basically the same engine. How did these guys ever make a profit?
So whats the better route?
post #9 of 29 (permalink) Old 06-03-2019, 09:51 AM
pinino's Avatar
If you go this route I have a front mounting bracket for cat (B or L) that's listed on AlfaBB classifieds. It's in solid condition.
white '92 164 S (71K)
pinino is offline
post #10 of 29 (permalink) Old 06-03-2019, 11:33 AM
I could supply the two new L cat front 60510307 and rear 60510816 copper gaskets.
NOTE: the center L muffler (not shown) with one outlet to match L cat is different from the 164S. The S ctr muffler has two inlets. All the B/L/S/LS/Q ctr ones have same rear outlet flared with steel sealing ring.
Is your S center muffler bad, too?
Lakeland, Florida
post #11 of 29 (permalink) Old 06-03-2019, 11:45 AM
If your front S downpipes, and cat are bad those 164L ebay ones maybe the way to go. but you will need L center muffler to match cat. LS/Q center muffler does not match L cat.
I have the front end single inlet flange with about 12" from a L center muffler.
I also do have a new 164B/L center muffler being held in reserve for my 164L that maybe you could twist my arm to let it go.
Note the current "center" muffler listed on ebay in picture is NOT really a center one. It is really a B/L Ansa AR8107 rear muffler according to picture. It would work on your 164S but has single outlet.
Lakeland, Florida
post #12 of 29 (permalink) Old 06-03-2019, 12:43 PM
jc96's Avatar
if your'e interested, get me part numbers for what you need and I'll go see Eddy. You have my email. ciao, chris
Rogue Leader likes this.
Maintaining my tenuous strain on reality.
89 164 2l Twin Spark, 2011 Tonka Dump
Recently added: an 89 75 (Milano) 1.6 litre w/44K on the klok.
Past loves:
79 Alfetta GTV w/Spica, my 1st Alfa
An 88 Graduate. Not really love but interesting nonetheless.
A 68 BMW 1602 - man do I regret letting that one go!
79 Scirroco, ex plowed into an illegally parked house with it...
jc96 is offline
post #13 of 29 (permalink) Old 06-03-2019, 12:44 PM Thread Starter
Everything is bad.
I mean its functional and not leaking now, but its on borrowed time. Every joint is pure rot and not coming apart without cutting and never going back together. Even the joints at the manifolds, but my hope is at least the manifold studs can be salvaged, otherwise I will need to replace those too which I'm sure would be a nightmare. Thats why I'm almost thinking since I really need to replace all of it, maybe custom from the manifolds on is the way to go. 2 into 1 aftermarket cat, vibrant resonator in stock location, and then the Borla boomer muffler. My only issue then is I need a knockout from a rear bumper like the passenger side to stick into the notch in the drivers side as the tips won't line up.
post #14 of 29 (permalink) Old 06-03-2019, 01:19 PM
When you make up your mind let us know.
Manifold studs will come out with heat and if sheared off you can weld a steel rod/bolt onto them and use torch to heat manifold so you can extract them. we have done lots of them.
Lakeland, Florida
post #15 of 29 (permalink) Old 06-03-2019, 02:02 PM Thread Starter
Good to know. I think I am going to hold off until I can get the car to the exhaust shop and show them since everything from the cat back will need to be custom anyway, see what they think. Also same regarding NY and its stupid restrictive emissions laws that make doing this an added pain.
