"S" cams in std motor? - Alfa Romeo Bulletin Board & Forums
 2Likes
  • 1 Post By andylarry
  • 1 Post By Alfissimo Int.
post #1 of 8 (permalink) Old 05-04-2019, 06:20 PM Thread Starter
alfettaGTAm's Avatar
Has anyone tried "S" cams in a standard 164 motor?
I have bought a donor 164 "S" (QV here in NZ) and my son was wondering about putting the cams in his 164 base. Is there any point without upping the compression? Alternatively, the engine might be okay (despite having done 377kms), what's this engine like fitted to a base model gearbox?
Cheers
Kerry
Christchurch, NZ.
Christchurch, NZ.
Alfetta GT twinspark project, Alfasud Ti, 3x164s, 4x156s, 147, 166, plus parts cars.
alfettaGTAm is offline
post #2 of 8 (permalink) Old 05-04-2019, 06:59 PM
S cams open up the top end at the expense of low end torque, as you might expect. The S cams allow higher compression by doing this.
In my not so humble opinion the S version was a paper tiger to impress journalists. The actual performance difference between S and L tunes was really effected by a 10% shorter final drive in the transmission.
If your son enjoys high rpm driving then by all means fit the S cams. The compression ratio is only relevant at below 4,000 rpm where the L needs the lower compression to avoid knocking.
1991 Alfa Romeo 164L 5 spd
Michael Smith is online now
post #3 of 8 (permalink) Old 05-04-2019, 09:46 PM
Alfistaa's Avatar
I wouldn't bother. Most likely cams are worn out at 377km. If still decide to do it, move the valve lifters with the cams. They wear together and must be kept together.
Alfistaa is offline
post #4 of 8 (permalink) Old 05-05-2019, 05:56 AM
Alfisto Steve's Avatar
I have a S engine in my L w/AT and it goes pretty good. Car came to me that way but has stock L air flow meter, ECU and exhaust system. Can't say for sure it has S pistons or cams but it goes pretty good.
Now my S with lower final gear ratio tranny goes good, too.
That being said my 164B w/5sp had spunk, too with taller final drive ratio.
Virginia Beach, VA
My Maintenance Sticky:
Alfisto Steve is offline
post #5 of 8 (permalink) Old 05-05-2019, 06:06 AM
The L has a better final drive ratio to suit the engine torque curve and fitting the S engine with that final drive ratio would produce a better drive, for European conditions.
post #6 of 8 (permalink) Old 05-05-2019, 08:11 AM
Years ago I had a 91 L in which I installed new "S" cams, a Speed Factory eprom which raised the rpm limit to 7200, and deleted the center muffler and added a Stebro rear can. There was a small loss of low end power and a noticeable gain of mid-high and high rpm power. It would obtain 101 mph in third gear and I saw a verified 156mph on a flat road with maybe a few more mph to go. I ran the engine with those mods for about 150k miles before I sold it to fellow who was building a Lancia rally car replica and just wanted the engine and trans.
Michael Smith likes this.
ALFA ANDY
andylarry is offline
post #7 of 8 (permalink) Old 05-05-2019, 09:34 AM
Rogue Leader's Avatar
Originally Posted by andylarry View Post
..... before I sold it to fellow who was building a Lancia rally car replica and just wanted the engine and trans.
If I ever wrecked my 164S this would be my next project. Strip it down and build a Stratos.
Rogue Leader is online now
post #8 of 8 (permalink) Old 05-06-2019, 11:25 AM
Alfissimo Int.'s Avatar
Cheers
Kerry
Christchurch, NZ.
Don't bother. The L cams and motor I think are better. If you want to open it up a bit, get a chip to bring it up to 200hp. Use the QV exhaust system, basically flex pipes back, use updated version if you can that sit up higher under car. If you don't have to have a CAT use the early 164 non-cat silencer front, add bung to front of unit for O2 sensor and that should be plenty of fun.
I like the L set up better.
Jason Minos
New: +1 619-209-0715
e-mail:admin at alfissimo.com
San Diego, CA
1989 Spider Quad. Gone
2010 Touareg TDI
2017 Giulia Ti Sport Q4, Trofeo, Leather package(red), 19X8, 19X9.
Alfissimo Int. is offline
Similar Threads
How to choose different intake and exhaust cams? 180OUT Engine Repair, Diagnostics & Rebuilding 160 02-17-2018 07:34 PM
Alfa 164 A/C Heater Blower Motor info Alfisto Steve 164 & 168 (1991-1995) 110 04-30-2017 08:48 AM
For Sale: 164 rebuilt motor w/ S cams and pistons, 25K mi faitalfa Alfa Romeo Parts For Sale & Wanted 12 12-15-2015 08:02 AM
NEW: Great, Lengthy Oil Discussion from Ferrari Chat Ish-Man Alfa Romeo Topics Not Covered Elsewhere 6 12-15-2008 08:57 AM
