Transmission Fluid for '92 164s 3.0 12v - Alfa Romeo Bulletin Board & Forums
 2Likes
  • 1 Post By Remelo
  • 1 Post By IRONBLOCK
post #1 of 14 (permalink) Old 10-17-2018, 09:41 PM Thread Starter
First, let's make thins clear. I own a '92 164s 3.0 12v with a manual transmission.
I have been very confused by the type of fluid that is supposed to go in the MANUAL transmission. I just did my first trans fluid change and I did it with Castrol Dexron VI ATF, which is which is compatible with II which is what the factory service manual says to use for the manual trans. It seemed odd, but that's what the manual specified so I bought it. When I drained the fluid that came with the car when I bought it, it was a thicker gear oil.
What is the right choice to make and is it safe to use what I used.
I know I seem naive, but I just want to make sure I didn't mess it up big time.
Thanks for the comments and help -Remelo
1992 164s Portland Oregon, Ryan Wesel
Remelo is offline
post #2 of 14 (permalink) Old 10-18-2018, 01:42 PM
Alfisto Steve's Avatar
I use ATF A/T fluid in my 164 5-speed manual transaxles. ATF VI full- synthetic is backward compatible according to my research:
https://www.valvoline.com/our-produc.../dexron-vi-atf
OBTW my 164B 5-speed I bought new in 91 came with gear oil which I changed at 130k to ATF II when input shaft ball bearing failed. I replaced it with 164S overload version roller bearing. Was still going strong with ATF at 210k when I sold it.
Virginia Beach, VA
My Maintenance Sticky:
Alfisto Steve is offline
post #3 of 14 (permalink) Old 10-18-2018, 04:17 PM
pinino's Avatar
My 1992 164S came to me with 47k with AFT (brand unknown). At 52k I changed to Royal Purple synthetic (=Dextron II), but didn't like it, feeling a little "edginess" going into 2nd. At 65k I carefully flushed out the AFT, used a Valvoline 75-90 GL5 as a transition oil for a week, then changed to Motul 300 75-90 ester. This, so far, I like the best for my climate (Northeast).
white '92 164 S (71K)
pinino is offline
post #4 of 14 (permalink) Old 10-18-2018, 08:41 PM
Alfissimo Int.'s Avatar
Either ATF or Gear Oil. I prefer gear oil. If ATF in there and you want to use Gear oil. Drain it as best as possible and throw in gear oil. ATF used in US only, Gear oil for the rest of the world. Either or.
Jason Minos
New: +1 619-209-0715
e-mail:admin at alfissimo.com
San Diego, CA
1989 Spider Quad. Gone
2010 Touareg TDI
2017 Giulia Ti Sport Q4, Trofeo, Leather package(red), 19X8, 19X9.
Alfissimo Int. is offline
post #5 of 14 (permalink) Old 10-21-2018, 03:16 PM Thread Starter
Thanks for the clarification, I have a US spec car. I will most likely run ATF for a couple thousand miles and then change it out for gear oil.
Alfissimo Int. likes this.
Remelo is offline
post #6 of 14 (permalink) Old 10-22-2018, 08:10 AM
IRONBLOCK's Avatar
Remelo, I've had a 1992, 164-S since it was new. The local dealer (PSA) changed the trans fluid to 90 weight gear lube at the 36K service and it was very difficult to shift when cold. Within a week I changed it back to Redline MTL 75W80 that I previously installed at ~20K miles. It now has over 130K miles and the transmission shifted beautifully until the TOB came apart.
I can vouch for Redline; could not stand the dealer installed gear lube as it would have surely ruined the synchros in short order with our cooler weather.
Mark
IRONBLOCK is offline
post #7 of 14 (permalink) Old 10-22-2018, 11:03 AM
I use Motul Gear 300 75W-90 (full synthetic)and it shifts well in all weather. We get cold here too. <40˚F in day in winter. Depends on what gear lube you use. I recommend Motul. Box is spec'd for mineral oil though. So you can choose between the 300 or the motul mineral oil 75W-90. Both are stellar. Redline is another option as well.
Jason Minos
San Diego, CA
2010 Touareg TDI
post #8 of 14 (permalink) Old 06-17-2019, 09:01 AM
Rogue Leader's Avatar
I have a couple bottles of Redline 75w90 that I plan on using to do mine. About how many quarts are needed to refill the transmission? What port are you using to fill it?
Rogue Leader is offline
post #9 of 14 (permalink) Old 06-17-2019, 10:20 AM
It takes 2 quarts. On the 12v models I remove hex plug or allen head plug from tranny case located near clutch release pivot arm upper bushing and use a A/T long thin funnel. You can remove reverse light switch or even the 1-2 gear switch (S model) or even the hidden dip stick on differential top but much harder to get to and get a funnel in these three choices.
Virginia Beach, VA
post #10 of 14 (permalink) Old 06-17-2019, 10:33 AM
Del
Two qts, and at either the Allen wrench plug under the slave cylinder, if you can get it out (I cannot in my 91S), or the reverse gear back up light sensor located further to the left (car left) and back at the top of the gear case (this location is what I use). I use a long skinny hose and a funnel.
Is the 75W-90 the NS or regular? Richard Jemison strongly recommend using the NS version. I do use it in my 94LS to quiet the gear noise down a little (it's a 1995 Q transmission, and the the gears, esp 3rd, were a little noisy on partial throttle), and it seems to work just fine (so far).
My 91S has Royal Purple ATF in it, which works ok, but don't know how it will work when the temps drop low next winter. When I had the clutch replaced in that car a couple of years ago, Carlo put in Kendall ATF (as he usually does I guess), but the transmission was pretty darn balky and stiff when the temperature was in the 30s and 40s until the fluid warmed a little. Didn't like that, and don't remember it being that way before.
I had been running the Redline 75W-90NS for a short while before the clutch change, and when he asked me what was in the transmission, and I told him, he was not all that happy with the gear oil, telling me that Alfa had said not to use gear oil because it was too stiff when cold, not getting to all the bearings quickly enough. I mentioned that the rest of the world seemed to use gear oil, and he didn't say anything. We changed the subject. So... I do not know.
Del
Seattle
1989 Milano, Shankle Sport
1991 164S, stock
1994 164LS (~Q)
1972 Morgan 27
previously owned since 1964:
Del is offline
post #11 of 14 (permalink) Old 06-17-2019, 01:20 PM
not sure if its NS. I know I have some bottles of 75w90 and 75w140 I used to use in my old race car (was the only stuff that would keep the transmission from blowing up). They are a few years old but i have no other use for them (new race car has a Kaaz clutched diff which needs specific fluid). NS is only different in that it lacks friction modifiers to allow for some slipperiness, which is helpful for very old transmissions, far older than our cars. Apparently it would work with my Kaaz diff as well as it says its good for racing type clutched diffs.
I noticed the reverse gear sensor and figured that may be a good spot. I do have a funnel with a flexible tip which may help. Also everything is removed right now so it should all be easy to get to.
post #12 of 14 (permalink) Old 06-17-2019, 04:03 PM
I think NS but of course I don't use redline products. I used Motul Gear 300 (75W-90) in my box.
Jason Minos
San Diego, CA
2010 Touareg TDI
post #13 of 14 (permalink) Old 07-01-2019, 11:14 AM
Anyone know what size the Allen for the drain plug is. Of course anything I have near that size has walked away from my tool box, so I want to just buy the size I need to get the job done instead of tearing my shed apart (assuming they are even there... ugh)
post #14 of 14 (permalink) Old 07-01-2019, 04:16 PM
Both ATF and Gear oil are correct. I prefer gear. Motul Gear 300 75W-90.
Jason Minos
San Diego, CA
2010 Touareg TDI
