Hose with a hole - gas spray - Alfa Romeo Bulletin Board & Forums
post #1 of 27 (permalink) Old 11-22-2017, 09:19 AM Thread Starter
I noticed a gas smell in the cabin so figured something was leaking under the hood or somewhere. Sure enough, a hose has developed a pin hole right below or under the clamp, and is spraying a little premium gasserooni. Is this hose easy enough to replace? The one with the blue writing on it.
jckevin is offline
post #2 of 27 (permalink) Old 11-22-2017, 09:24 AM
goats's Avatar
Not exactly easy but not too much trouble. The current hose above in the photo has the wrong kind of clamp for fuel injection. Make sure you buy the correct High pressure fuel injection hose. Its not cheap and I don't recall if its 6.5 or 7 mm EDIT top hose says 7.9mm? . Buy proper fuel injection hose clamps for both DO NOT drive the car until you get it fixed unless you like car fire.
EDIT -- that hose is not far enough up on the barb, no wonder its leaking EDIT it looks like the return hose not the supply side and the hose also looks very short. I think its replacement time for that
goats is offline
post #3 of 27 (permalink) Old 11-22-2017, 09:44 AM Thread Starter
I wonder if i can push it higher and clamp ... then drive to the Alfa place. I drove it to and from work yesterday LOL. Leaking like a sieve the whole time.
jckevin is offline
post #4 of 27 (permalink) Old 11-22-2017, 11:46 AM
DO NOT try to drive with a fuel leak. The consequences can be fatal. Not probably but how lucky do you want to be?
If the hose is actually leaking between the inner liner and the hard line I agree you can back off the clamp, push the hose all the way onto the hard line and clamp above the bulb in the hard line. The bulb is there to prevent the hose from creeping before it begins leaking. If the clamp works loose the hose should leak before it moves far enough to actually disconnect. In your situation you're just a very lucky man. That hose is not far off falling off entirely, then you'd see some fireworks!
If the hose is actually leaking do not attempt to drive the car, tow it and inform the tow truck driver of the hazard.
1991 Alfa Romeo 164L 5 spd
Michael Smith is offline
post #5 of 27 (permalink) Old 11-22-2017, 12:06 PM Thread Starter
Ha ... I know I'm fortunate. I wouldn't have driven it had I known of the leak. However, I've always loved fireworks.
jckevin is offline
post #6 of 27 (permalink) Old 11-22-2017, 12:49 PM
Alfisto Steve's Avatar
Leaking hose with wrong style clamp is 40-50 psi fuel pressure hose that is hooked to inlet of fuel damper incorrectly.
Also looks like there isn't any clamp on gas return hose attached to bottom of fuel pressure regulator does not even have a clamp on it
From what I can see in pix it looks like wrong clamps on short hose going between fuel rails, too or at least on end closet toe front head.
Also check short hose and clamps between fuel rails on front of engine for wrong clamps and damaged hose ends.
Virginia Beach, VA
My Maintenance Sticky:
Alfisto Steve is offline
post #7 of 27 (permalink) Old 11-22-2017, 12:52 PM Thread Starter
Appreciate the input. But ****...
Will get 'er fixed obviously.
jckevin is offline
post #8 of 27 (permalink) Old 11-22-2017, 01:12 PM
Here is an example of correct fuel injection system hose clamps no worm gears to cut into rubber.
http://www.alfabb.com/bb/forums/6780769-post8.html
Hose should be SAE30R9 7.5mm ID but 7.9mm ID (5/16") will work if correctly size/designed clamps are used.
Virginia Beach, VA
post #9 of 27 (permalink) Old 11-22-2017, 01:27 PM Thread Starter
Excellent, excellent. Happy Thanksgiving.
jckevin is offline
post #10 of 27 (permalink) Old 11-22-2017, 01:45 PM
I'm running these pinch clamps from McMaster Carr and they seem to hold up fine. https://www.mcmaster.com/#52545k53/=1adclwl
And the fuel line from Centerline https://www.centerlinealfa.com/catalog/fuel-line-75-mm
If you're in a bind, I think I have some length of hose and clamps in the trunk of my 164 in Bothell.
Scott Catlin
1993 Alfa Romeo 164S
scatlin is offline
post #11 of 27 (permalink) Old 11-22-2017, 01:46 PM Thread Starter
Scatlin, that would be amazing. I'm in Kirkland. You around over the next 4 days?
jckevin is offline
post #12 of 27 (permalink) Old 11-22-2017, 01:48 PM
goats's Avatar
the bottom of the FPR looks like an original Oetiker clamp. ALL clamps for all fuel lines need to be either original Oetiker or proper FI clamps as steve posted
goats is offline
post #13 of 27 (permalink) Old 11-22-2017, 01:50 PM
I'm gone tomorrow, but back in the area Friday. Let me look in the car and confirm what I have and I'll PM you my contact info.
Scott Catlin
scatlin is offline
post #14 of 27 (permalink) Old 11-22-2017, 01:57 PM Thread Starter
Thanks all.
jckevin is offline
post #15 of 27 (permalink) Old 11-22-2017, 02:22 PM
Although correct clamps are preferred it actually isn't essential. The leak resistance is provided by the liner compound, the burst strength is provided by fibre reinforcement (as for tires) and the external cover is well up to withstanding a bit of penetration by screw type clamps. Remember that the portion of the hose under the clamp is not subject to any line pressure unless the clamp backs off. In that event the pressure leaks out the open end of the hose rather than inducing a rupture in the hose itself.
I do recommend double clamping the hoses though. Until I did that mine seeped fuel chronically. Not enough to wet the hoses but enough to create that unpleasant aroma. The seepage occurred when the engine was very cold and stopped as the coolant heated up.
Correct clamps equalize the pressure around the hard pipe. Worm types have to be overtightened to ensure enough pressure is exerted all around the hard pipe. Double clamping with one clamp offset from the other helps with this deficiency of worm type clamps.
Those worm type clamps are really useless for any automotive function involving restraint of pressure. Euro style spring clips are preferred, if you have the nifty instal/removal tool. Otherwise the pad type band clamps pictured in the link are definitely preferred for sealing pressurized connections, if you have them to hand.
Here's a good explanation of the three common types of high pressure fuel hose clamps in common use. You can see the worm drive is the least desirable. I have them on my car!
