Left (driver's side) Headlamp Relay - Page 2 - Alfa Romeo Bulletin Board & Forums
 1Likes
post #16 of 19 (permalink) Old 01-11-2019, 11:01 PM
kuseetha's Avatar
Originally Posted by Alfisto Steve View Post
Point of info there aren't any headlight relays behind headlights on 94-95 models anyway.
Remember different models have different configurations.
Hi Steve,
What is the AMP rating of I49 low beam relay? Is it 30A? My relay has the cover missing and no way to find out. For '96 24V.
Current:: '96 Alfa Romeo 164 Super V6 24V || '93 Alfa Romeo 33 1.5IE || '74 Holden HQ SS || '87 Oldsmobile Custom Cruiser 5.0 V8 || '72 Volkswagen Beetle || '97 Nissan Sunny 2.0D
kuseetha is offline
post #17 of 19 (permalink) Old 01-12-2019, 07:20 AM
Alfisto Steve's Avatar
Originally Posted by kuseetha View Post
Hi Steve,
It is same 20A relay as I50 hi-beam just below it in fuse box. Also the same relay as I12 front window and I13 rear window relays in top row.
It should have MP symbol with B047 7686773 20A printed on cover of those other 3 similar relays. AR# is 60800552.
Virginia Beach, VA
My Maintenance Sticky:
Alfisto Steve is offline
post #18 of 19 (permalink) Old 01-14-2019, 12:13 AM
kuseetha's Avatar
Thumbs up
Thank you very much Steve
kuseetha is offline
post #19 of 19 (permalink) Old 01-14-2019, 12:30 PM
IRONBLOCK's Avatar
Many cars on the road now have blindingly bright white headlights. In self defence I finally broke down, bought and installed a set of 'Sylvania silverstar ultra 9004 SU/2 NIP' off eBay for $24. I have not driven the car at night since they were installed but they both work. Apparently they have a reputation for not being long lasting headlight bulbs. Maybe they will only last 240 hours of use or something like that. When I remove the old Sylvania's, one had a date code of March 1996! Perhaps that explains why they seemed so dim...I saved the old bulbs just incase it needs a spare.
When changing the right front bulb, I noticed that the grey plastic had some evidence of discoloration. It looks like the female connector has been slightly overheated. Would this indicate a bad ground or a bad connection? When I had the engine and transmission out for its 130K service, all grounds were cleaned and a coating of dielectric grease or Vaseline was applied. Hopefully that will take care of any issue. It appears, or something else seems to have cured an issue with the radio antenna, which would consume a fuse each time it went up or down but now seems to work as designed.
Mark
IRONBLOCK is offline
