What did you do Alfa related today? - Page 946 - Alfa Romeo Bulletin Board & Forums
 1002Likes
post #14176 of 14377 (permalink) Old 07-19-2019, 07:41 AM
I found that the last code stayed in the system after I fixed the issue. In my case it was the temperature sensor in the rad. After I replaced the sensor the car ran perfectly, but the code still came up when I did the gas pedal test.
Kim Boydell is offline
post #14177 of 14377 (permalink) Old 07-19-2019, 11:08 AM
therealguy419's Avatar
So decided to recharge the ac as heat index will in around 110F today and tomorrow. Recharged my crown vic ac then did the alfas ac. Needle showed it needed to be filled did fill it and then it started to run a little rough when the ac compressor was on, when turning off ac it returned back to normal. I am thinking I might have a bad AC Compressor and it was not getting that cold.
therealguy419 is offline
post #14178 of 14377 (permalink) Old 07-19-2019, 01:28 PM
Roadtrip's Avatar
It sounds like you were using the disposable cheapo fill gauges on the refrigerant bottle? If so, you could be overcharging the system which will degrade cooling and put tremendous strain on the compressor.
John Stewart
74 Spider
91 164S
Roadtrip is offline
post #14179 of 14377 (permalink) Old 07-19-2019, 04:32 PM Thread Starter
Alfisto Steve's Avatar
Well ML took the Jeep Grand Cherokee (JGC) today to do her thing. I took BB1 with no a/c to P-N-P to get parts for JGC as we had a R/R passenger window regulator drop the window down couple inches in the heat of the day yesterday. Something just decided to break while we were in the store shopping. As I slid the window back up something fell into the inner door cavity. This heat wave has not been our friend on either car.
Even though it was super ambient hot today and then with no a/c but windows down BB1 sang the sweet song of an Alfa Busso V6 whine via a dual tip Ansa.
Expect Neville's care package soon so next week maybe we can get a/c serviced again after I can get that fire damaged high pressure a/c hose replaced.
horsewidower likes this.
Lakeland, Florida
Virginia Beach, Virginia
My Maintenance Sticky:
Alfisto Steve is offline
post #14180 of 14377 (permalink) Old 07-20-2019, 06:08 AM
Luigim's Avatar
Originally Posted by Alfisto Steve View Post
/snip
\snip
Paul Simon could have added this verse to America.
counting the cars on the new jersey turnpike
They've all come to look for America.....
sorry could not resist
164LS 1994
Luigim is offline
post #14181 of 14377 (permalink) Old 07-20-2019, 09:41 AM
Spent many hours yesterday cleaning off 28 years of oil and grime from the front (radiator) side of the engine. Started out trying to use some Simple Green cleaner in a spray bottle and a rag, but that wasn't working. Next I went to a brass wire brush, a rag, an old tooth brush, and liberal amounts of paint thinner for the brushes. That worked good.
Also removed the old rubber bushings from the A/C compressor mount and the dog bone engine mount using the propane torch method (off the car of course and out in the backyard). Worked well, but sure makes a lot of smoke from the burning rubber. Today I will finish off cleaning the front of the engine and rebuilding the mounts.
Mike D.
RedAlfasgoFast is offline
post #14182 of 14377 (permalink) Old 07-20-2019, 12:47 PM
Using a can of A/C Pro showed that the system was empty so I started filling it just a little bit then Compressor started to struggle. Charles did say that the ac did leak.
post #14183 of 14377 (permalink) Old 07-20-2019, 04:42 PM
Rogue Leader's Avatar
SO it was 105 degrees here today I figured what better time to work on pulling the passenger side axle.
I didn't last more than 20 minutes. Then I had a problem with my quickjacks, so I got the car down on stands, fixed them, and got it back up and called it a day. Brutal out there.
Rogue Leader is offline
post #14184 of 14377 (permalink) Old 07-20-2019, 06:49 PM Thread Starter
Took the day off from Alfa related and stayed cool out of this brutal heat wave. Watching new 2018 First Man movie about Neil Armstrong on HBO.
Hope jet stream dips south as predicted next week I need to work on Jeep Grand and would like to work on BB1. Once Neville's care parts pac arrives weather permitting I will try to get BB1 ready fpr a/c service.
Lakeland, Florida
post #14185 of 14377 (permalink) Old 07-20-2019, 06:58 PM
pinino's Avatar
That's correct, fault codes don't get automatically cleared from the ecu after the cause of the fault is repaired. You need to do one of the following to remove the fault from the ecu's memory:
1) disconnect the ecu for at least 30 seconds (= disconnecting the battery)
2) start the car 60 times in succession with source of the fault corrected
Even using the Alfa Tester (= Fiat-Lancia Tester) with MA4A cartridge it is not possible to remove the fault from memory.
white '92 164 S (71K)
pinino is offline
post #14186 of 14377 (permalink) Old 07-21-2019, 04:51 AM
beeton's Avatar
A bit of Alfa time over the last few days between outdoor work and indoor painting. A short drive in my "little Red microwave" and I really think I should get that a/c repaired. Drilled a new hole to revise the rear hanger mount on the Magna Flo muffler. The resonator and pipes I built up distorted slightly and the rear system had to be displaced 1 cm rearwards for the flanges to line up tightly. Repaired all of the sagging heat shields, large washer-sized plates cut out of clean sheet metal and painted over once installed.
I still need to either have an alignment to straighten the wheel or loosen and re position the column slightly, one or 2 teeth, to the right side.
I have this strange sunroof issue in that at speed, I cannot close the roof completely. Either the wind guard is stiff (doesn't seem so) or the roof is slightly distorted. I have to push up on the front section with one finger as I push the close button....not advisable at speed or during sudden rain.
On another note, browsing through the 2019 Sotheby auction list shows many, many older Alfas and one lonely 164 (sold for $1200.). The 164 era cars are going through the same "oh, that cousin" reaction as the Biturbo-era Maserati cars. The dealers push the history and new stuff but don't mention those periods. As Biturbo's crumble, they are slowly becoming more popular with a racer version selling for +/- $35k and basic models for $4k. Slowly, cleaner 164's may start to increase. Keep yours running.
beeton is offline
post #14187 of 14377 (permalink) Old 07-21-2019, 06:29 AM
For a car thats "unloved" every car guy I tell about that I am restoring one responds "oh man I love those". I think nice ones will appreciate somewhat some day. I mean not like big money but a respectable $15k range.
post #14188 of 14377 (permalink) Old 07-21-2019, 07:32 AM
beeton's Avatar
Yes. When I go for drives and stop for gas, I usually get one person mentioning "nice Alfa". Consider that a basic Alfa in decent shape usually costs less than an old Honda. The Achilles heel is not reliability but the cost of basic parts and that cost results in many "hack" jobs that shorten the life of the car.
I recall, in my Biturbo era, removing a piece of plumbing and finding that the p.o. had used 2 old O rings instead of one new one. We are talking about $2 items, not expensive at all.
If I can afford original parts, I will use them but the cost factor can get crazy considering that a running model can be had for less than the sums of some key "original" components. Show me an aftermarket Timing belt tension-er bearing (they must be used in a million trucks somewhere in India), a compatible tensioner (maybe an Audi version as they seem to be similar?), shock struts that aren't insanely expensive and I would be a happy lad.
Rogue Leader likes this.
beeton is offline
post #14189 of 14377 (permalink) Old 07-21-2019, 10:22 AM
Roadtrip's Avatar
Necessity is the mother of invention . . . on the hyd tensioner bearing, since they're still obtainable (albeit expensive), there's not much call to come up with something different. If they go extinct, then I'm sure a new carrier center could be easily fabricated for a slightly different inner race size.
John Stewart
74 Spider
91 164S
Roadtrip is offline
post #14190 of 14377 (permalink) Old 07-22-2019, 04:55 PM
Temp was 100 degrees here. So I decided to paint the intake plenum and cam covers with black wrinkle coat paint. Turned out great. I have learned that this paint works best on hot days. This evening when it cools down a bit I will install the new water pump and maybe the new timing belt on my 164s resurrection project. Need to get this car reassembled in time for Concorso Italiano in August.
