What did you do Alfa related today? - Page 926 - Alfa Romeo Bulletin Board & Forums
 1009Likes
post #13876 of 14390 (permalink) Old 04-11-2019, 05:16 PM
goats's Avatar
yep ok
Originally Posted by beeton View Post
When placed in the correct spot (this is sitting towards the front for reference), putting it downwards would have put it over the subframe and I did not see much clearance between the two in anycase. This is angled enough to have it flow downwards and I intend to use an intermediate piece to control flow into a container, rather than having it splash around.
I angled mine down from the front side, nearly straight down. It clears the subframe by 1/2 inch and I just put a bucket underneath and let er drain. No more coolant on the floor from taking that rad hose off!!!
goats is offline
post #13877 of 14390 (permalink) Old 04-11-2019, 05:46 PM
beeton's Avatar
I did not have the rad in and thought the clearance would be a tad tight. Your placement might be a bit beter but either beats having coolant splash around and dripping on an otherwise clean floor.
goats likes this.
beeton is offline
post #13878 of 14390 (permalink) Old 04-11-2019, 08:57 PM
I've been installing these drains on my 164s for over 15 years. I install them toward the passenger side and pointing slightly forward so I can reach down from above on my 12V and operate the valve. It is so much easier to drain coolant.
goats and Rogue Leader like this.
Richard2 is offline
post #13879 of 14390 (permalink) Old 04-12-2019, 12:48 PM
therealguy419's Avatar
Looked under my car to check exhaust hanger donut condition, 1 of the 2 rear donuts are broken and other is stretched out quite a bit. Ordered 2 new ones from alfissimo.
therealguy419 is offline
post #13880 of 14390 (permalink) Old 04-15-2019, 01:07 PM
Del
Not Alfa related, but our condolences to those in France, esp Paris, at the very sad sight of the icon of Paris Notre Dame cathedral burning, suffering massive damage. Having visited it several times ourselves, and being students of cathedral design, we have always marveled at the classic Gothic design and the unmistakable beauty of the Rose windows. At least, it is thankfully apparent that no lives were lost, and thus far, it is assumed that it was not a political act as was the Trade Towers in New York.
Gothic cathedrals are marvelous structures, to say nothing of their social relevance to many people, esp for their time of creation. Unfortunately, many cathedrals and castles have had their wooden roofs burn (it seems to be a given) through the centuries, and the present day authorities have always been reluctant to install fire suppression equipment, altering these historic icons of human creativity. Hopefully, it will be rebuilt, with a metal roof and adequate fire fighting systems. Will take many decades I suspect.
Again, our condolences.
oz3litre likes this.
Del
Seattle
1989 Milano, Shankle Sport
1991 164S, stock
1994 164LS (~Q)
1972 Morgan 27
previously owned since 1964:
Del is offline
post #13881 of 14390 (permalink) Old 04-15-2019, 01:13 PM Thread Starter
Alfisto Steve's Avatar
My oldest daughter and I visited Paris in 1986 and visited the cathedral and counted the gargoyles.
Lakeland, Florida
Virginia Beach, Virginia
My Maintenance Sticky:
Alfisto Steve is offline
post #13882 of 14390 (permalink) Old 04-16-2019, 02:29 PM
beeton's Avatar
95 LS auto.....
Put the metal line back in (between left and right hoses, fresh drain tap installed) and tightened up, filled with about 4 liters only to find a leak at the braze!! Darn. Should have checked the braze first. Drain it again, made much easier with the tap this time, cleaned up and started to braze again...ran out of Oxy...drove to the hardware store to buy more Oxy...brazed again, TESTED AND TESTED, installed cooling system, rad, all connectors, air box and started. Fired right up but the engine light stayed on. Shut engine off after it warmed to around 140 to check connections, one was loose (white and black connector, running over the brake lines). Now, cranks but no start. I checked for codes and came up with a 1255. Was idling fairly smooth and responded to gas pedal so I don't believe it is a timing issue but you never know.
I will check again tomorrow morning as I have to get my lawn tractor ready and reached my frustration level but hopefully, cleaning all connections will help.
beeton is offline
post #13883 of 14390 (permalink) Old 04-17-2019, 09:00 AM
beeton's Avatar
Cheese-balls. Checked and cleaned all connections under and right of the airbox this morning to deal with the code 1255. Put it all back in, started the car up and it fired right up. Noticed the idle was high (just under 2k). Shut off and did a code read... 1221. Bad me, the air flow connector had not clicked into position. Tightened that up and then NO start. Removed and replaced the battery lead and tried another code search to find a 1214 (engine temp sensor). Having some trouble finding the correct connector for that. The temp sensor is off of the thermostat housing, I believe but where is that connector located along the harness AND will this cause a no start? Thanks all.
beeton is offline
post #13884 of 14390 (permalink) Old 04-17-2019, 09:05 AM
goats's Avatar
put your fuel pressure gauge in line with the rail while you troubleshoot. Trust me, it adds a TON of information. I recall the gauge sensor is in the tstat housing easy to see but the motronic sensor is hidden underneath the rad hose on top of the tstat housing. I recall its a blue? connector? Been years since I;ve looked......
goats is offline
post #13885 of 14390 (permalink) Old 04-17-2019, 09:08 AM Thread Starter
Yes cold no start with Bosch coolant temp sensor disconnected. It is well hidden under area where top radiator hose connects to thermostat. It is at a same 45 degree angle like hose to thermostat. It is not temp gauge sender next to timing belt cover.
Lakeland, Florida
post #13886 of 14390 (permalink) Old 04-17-2019, 09:11 AM
VabeneGTV's Avatar
Checked the idle jets on the Alfetta sedan, ordered 1 size up to hopefully correct a slight stumble on acceleration, and drove the 4C to work for the first time after winter hibernation.
Cars ruined my life! 😱
VabeneGTV is offline
post #13887 of 14390 (permalink) Old 04-17-2019, 09:13 AM
beeton's Avatar
So, this is not the sensor running off of the lower rad (above the 90 degree hose) and connected up near the drivers side of the rad? Sorry, but I am a bit confused by the description.
beeton is offline
post #13888 of 14390 (permalink) Old 04-17-2019, 09:27 AM Thread Starter
NO, it is hidden in mid-thermostat housing at 45 degrees under where top hose hooks to thermostat
Sent from my VS501 using Tapatalk
Lakeland, Florida
post #13889 of 14390 (permalink) Old 04-17-2019, 10:25 AM
I took my baby (S2 Spider) into the shop to remount transmission tower boots, adjust idle and a general inspection.
Hopefully nothing else is found.
Kim Boydell is offline
post #13890 of 14390 (permalink) Old 04-17-2019, 10:35 AM
beeton's Avatar
O.K. so temp sender is connected at t stat housing, seems to be a single connector, under the 2 connectors just above on the top of the t stat housing. I am trying to follow the line downwards to find the other (hoping that it is a dirty connector near the air breather area as that is where I had been working) but apart from a single wire connector under the alternator, cant seem to follow any further. Time to dig through the electrical diagrams. I have started twice, no problem but still code 1214.
beeton is offline
