What did you do Alfa related today? - Page 694 - Alfa Romeo Bulletin Board & Forums
 984Likes
post #10396 of 14314 (permalink) Old 03-08-2017, 02:36 AM Thread Starter
Alfisto Steve's Avatar
I use regular 87 rated gasoline with 10% corn oil added in my S unless I plan a roadtrip in the summertime.
Our choices here are 87 and 91.
https://en.wikipedia.org/wiki/Octane_rating
Virginia Beach, VA
My Maintenance Sticky:
Alfisto Steve is offline
post #10397 of 14314 (permalink) Old 03-08-2017, 04:58 AM
oz3litre's Avatar
We use 98 RON in all our Alfas, except the diesel of course. The 92 in Australia is crap and I wouldn't put it in any decent car. The 95 is kind of pointless in my opinion because 98 runs cleaner, performs better and is more economical. In fact I have heard they are thinking about dropping 95. Your standard ULP in Europe and US is probably better quality than ours. My brother won't even use ours in his lawnmower.
Current Alfas
2010 159 ti 1750 TBI sedan (red).
2004 GT 3.2 V6 (Stromboli Grey).
2008 159 TI Sportwagon 2.4 JTDM (Stromboli Grey).
1987 75 3 litre (red). My first 75 and now my son's.
2000 156 2 litre Twin Spark, ( Cosmos Blu metallic), my daughter's car.
2000 156 Monza Twin Spark, (Cosmos Blue metallic), sonís girlfiendís car.
1999 GTV 3 litre 24 valve V6, metallic black, (sonís new car).
Non Alfa
1988 Range Rover Classic Highline 3.9 V8
Past Alfas
1989 75 3 litre, written off by runaway van.
1990 75 3 litre Potenziata (black), now sold & living in Newcastle NSW.
1990 75 3 litre Potenziata (grey, sadly deceased due to fire).
1982 GTV 2 litre, red, (daughter's first Alfa)
2 x 1992 164s, (1 red, 1 grey).
2 x 1988 33s, (both red).
1985 GTV 2 litre, (white).
oz3litre is offline
post #10398 of 14314 (permalink) Old 03-08-2017, 05:42 AM Thread Starter
Your 98 must be our 91 see chart in this: https://en.wikipedia.org/wiki/Octane_rating
Virginia Beach, VA
post #10399 of 14314 (permalink) Old 03-08-2017, 06:59 AM
the lower the octane=the cleaner the fuel.why do folks get the idea the higher the # the cleaner.the higher the number=the more crap they put in it to retard ignition.
cowfy is offline
post #10400 of 14314 (permalink) Old 03-08-2017, 07:43 AM
All gasoline in NA is "clean". It is filtered several times to remove...dirt. Additives are needed in higher compression engines to prevent pre-ignition. Additives aren't there to make gasoline dirty. They are there to reduce deposits are a result of combustion and to prevent pre ignition.
Richard2 is offline
post #10401 of 14314 (permalink) Old 03-08-2017, 08:08 AM
goats's Avatar
Automatic 164 24V is a delight. Faster 0-60 than the manual trans, easier in stop-n-go SoCal traffic, and saved my bacon when I had broken left ankle. I loved that car.
goats is offline
post #10402 of 14314 (permalink) Old 03-08-2017, 08:48 AM
jc96's Avatar
no Oz, the insurance can be dropped if the car isn't being driven. I'm not aware that cars can be de-registered here. Just parked. Not that it matters since insurance for us is dirt cheap. Both Alfa's are about 500 euro per year. I've never seen a 75 in a junkyard here and 164's are very hard to find in them as well. Getting NOS parts is pretty easy tho. UR correct in that used low mileage ones are plentiful. Look thru subito.it for a sample!! ciao, chris
Maintaining my tenuous strain on reality.
89 164 2l Twin Spark, 2011 Tonka Dump
Recently added: an 89 75 (Milano) 1.6 litre w/44K on the klok.
Past loves:
79 Alfetta GTV w/Spica, my 1st Alfa
An 88 Graduate. Not really love but interesting nonetheless.
A 68 BMW 1602 - man do I regret letting that one go!
79 Scirroco, ex plowed into an illegally parked house with it...
jc96 is offline
post #10403 of 14314 (permalink) Old 03-08-2017, 09:58 AM
oz3litre's Avatar
So where are all the 75s then Chris? They sold a huge number of them. I was always confused about how the system worked over there. People were never able to explain it clearly to us. We paid a lot more for the insurance on our Volvo over there than we do on our cars here and it was not comprehensive, (covering both parties for damage), either. Has it become cheaper in the last few years, or do you get a good deal having lived there so long?
Current Alfas
Non Alfa
Past Alfas
oz3litre is offline
post #10404 of 14314 (permalink) Old 03-08-2017, 10:00 AM
Del
We use 91 in the 91S, otherwise it can knock slightly up a hill, but can use either 91 or 89 in the LS because that engine has knock sensors to change the settings. We use either 87 or 89 in the Milano, mostly 89 because it too will knock when going up a hill with the 87. On the level, no problem with 87, but of course, the Seattle area has many hills, some steep.
It is interesting that the required octane level at high altitudes, as in the Rockies, is a little lower because of the lower air density, In many areas, 89 is the highest octane available, and works just fine in the 91S.
Basically, all US supplied gasoline is "clean enough" regardless of additives which are similar to Techron or the like, etc, for keeping the level of deposits down both in the fuel system and during combustion, as Richard mentions. They do not degrade performance, but in the long run better ensure optimum performance from the engine. Using a higher octane level than recommended by the car manufacturer, without altering the programming of the ignition system, etc, however, does not increase the engine performance in almost all cases.
Del
Seattle
1989 Milano, Shankle Sport
1991 164S, stock
1994 164LS (~Q)
1972 Morgan 27
previously owned since 1964:
Del is offline
post #10405 of 14314 (permalink) Old 03-08-2017, 10:16 AM
horsewidower's Avatar
I hope to experience this soon. Jim G is sending me the final couple of tools I need.
goats likes this.
But wait there's more: View my 164LS thread, now parts car status:
You didn't...oh yes I did II. 1995 164LS 5 speed, awesome when it runs!!!
Musings on shop related items:
horsewidower is online now
post #10406 of 14314 (permalink) Old 03-08-2017, 10:19 AM
There went an hour of my day!
Spitfire likes this.
post #10407 of 14314 (permalink) Old 03-08-2017, 10:36 AM
Veronica Mangan's Avatar
Well, this was only 12V, and it didn't perform all that well, but it had been sitting, and was not shifting smoothly. Indoor work for the next several days, as weather is still extremely soggy. Will enjoy reading what the rest of y'all are doing with your cars!
VM
Veronica Mangan is offline
post #10408 of 14314 (permalink) Old 03-08-2017, 10:41 AM
jc96's Avatar
Hopefully it was an enjoyable hour!! IDK Oz. The rates go down every year on the anniversary of the policy and the 75 is gonna drop significantly this summer I think. It might be next summer but I really don't pay notice as it is so cheap to start with. We don't have any special insurance - for example limited mileage or anything weird. Just liability and roadside assist/towing on the 164 that is good Europewide. Similar to AAA in the USA. Couldn't tell you what drives the rates - pun intended - as we've been with the company, Allianze for years and have no claims. They're out of Germany and big into investments and retirement planning as well tho we don't utilize them for anything but car ins. ciao, chris
Past loves:
jc96 is offline
post #10409 of 14314 (permalink) Old 03-08-2017, 12:08 PM Thread Starter
Scrounged parts for Non-BB4 today.
http://www.alfabb.com/bb/forums/7496449-post36.html
http://www.alfabb.com/bb/forums/7496465-post37.html
http://www.alfabb.com/bb/forums/7496553-post38.html
Virginia Beach, VA
post #10410 of 14314 (permalink) Old 03-08-2017, 03:59 PM
My black 164S lives temporarily in Canada. I went up today to pick up grand kids from school. The black cars tan really bad. No get up and go, missing, but a couple miles in 2nd gear at 4000rpm seemed to fix it right up. ?
Richard2 is offline
