Brake Line Disassembly - Alfa Romeo Bulletin Board & Forums
post #1 of 2 (permalink) Old 03-20-2017, 07:30 AM Thread Starter
Any trick to getting the brake lines apart when you get to the acorn nut type fittings? I canít get the nut/fitting to spin on the brake line and end up twisting the brake line. I have tried PB Blaster and a few other penetrant type liquids but no luck. I know these are 50 year old lines and I plan on replacing them but would like to take the lines out whole so I can replicate them properly. Thank you.
Nobody can look at a Giulia and not smile.
Mach1 is offline
post #2 of 2 (permalink) Old 03-20-2017, 07:37 AM
nealric's Avatar
Just cut the lines at the fitting with a hacksaw or pipe cutter. Cutting off a centimeter or two at the end won't make the lines any more difficult to replicate.
1986 Spider Veloce Turbo
nealric is offline
