No brakes ...!!!! Help...!!!! - Alfa Romeo Bulletin Board & Forums
 1Likes
  • 1 Post By Alfajay
post #1 of 6 (permalink) Old 02-24-2017, 08:15 PM Thread Starter
Tom Frasca's Avatar
1964 Sprint GT Dunlop Brakes.... ... rebuilt front calipers and pads...no leaks anywhere.... bled LR, RR, LF, all good ...at the LF ...keep getting small amounts of air bubbles...any thoughts ...all connections are sound.... Pedal felt okay, went to drive today pedal goes to floor ......nothing else was touched ....brakes were okay prior to rebuild sent fronts out to be rebuilt as one of the piston pad retainers was shot.....STRANGE...!!!
Tom Frasca is offline
post #2 of 6 (permalink) Old 02-28-2017, 06:20 AM
nealric's Avatar
Sounds like there must be a leak somewhere.
nealric is offline
post #3 of 6 (permalink) Old 02-28-2017, 06:36 AM
Sfizio's Avatar
Check for leaks with soapy water. Especially check where electrical connector for brake light attaches to master cylinder.
Sfizio is offline
post #4 of 6 (permalink) Old 02-28-2017, 05:07 PM Thread Starter
Tom Frasca's Avatar
No leaks at all think I am going to replace the master..
post #5 of 6 (permalink) Old 02-28-2017, 05:42 PM
Alfajay's Avatar
...think I am going to replace the master..
I think that would be prudent. You didn't tell us the history of the MC, but I'm guessing that a) it's old and b) it's a Dunlop.
I prefer the ATE type cylinders, as they don't have a check valve at the front (which might be what failed on your car). See: http://classicalfa.com/products/BR07...ERVO-CARS.html These will fit a car that was plumbed for the Dunlop type MC with a little re-bending of the rigid lines.
Tom Frasca likes this.
'63 Guilia spider
Alfajay is offline
post #6 of 6 (permalink) Old 03-11-2017, 07:31 PM Thread Starter
Tom Frasca's Avatar
I prefer the ATE type cylinders, as they don't have a check valve at the front (which might be what failed on your car). See: BR073 SINGLE CIRCUIT BRAKE MASTER CYLINDER - LHD NON SERVO CARS - Classic Alfa These will fit a car that was plumbed for the Dunlop type MC with a little re-bending of the rigid lines.
Ordered the master I need some miscellaneous parts for the rear brake assy (the metal cover to be specific, springs which I believe Alfaholics have and the rubber boots. I could make the cover .... and match screws but would rather have originals..
