Cracked steering box? Now what?! - Alfa Romeo Bulletin Board & Forums
post #1 of 4 (permalink) Old 02-24-2017, 06:36 PM Thread Starter
DualCarbSpider's Avatar
Exclamation Cracked steering box? Now what?!
So... the other day I noticed that when moving the steering wheel the steering box moves around, not much but enough to be noticeable.
I was not very worried until the moment I googled for a replacement and found out that the currently available online stores are charging a premium for this part. I am not saying they are charging too much but costing upwards of 700 (almost $900) it is definitely not cheap!
As I understand, after 40 years of abuse, most cars have now faced this issue, is everyone buying a replacement or is there a more cost effective alternative that will not break the bank?!
DualCarbSpider is offline
post #2 of 4 (permalink) Old 02-24-2017, 06:41 PM
USTA BE AN AD-MIN
ossodiseppia's Avatar
A competent welder can fix it.
I went this route:
http://www.alfaholics.com/parts/105-...burman-type-3/
ossodiseppia is offline
post #3 of 4 (permalink) Old 02-24-2017, 07:26 PM
horsewidower's Avatar
I had a fabricator familiar with fixing broken Motorsports aluminum castings weld one of mine. If I recall, it cost around $75
STILL learning.
But wait there's more: View my 164LS thread:
horsewidower is offline
post #4 of 4 (permalink) Old 02-24-2017, 09:00 PM
kengta's Avatar
some cracked steering boxes will be found with multiple cracks with some around bolt holes. so there also may be some machine work needed after welding. If you can find a shop familiar with auto racing casting repair would be best. Other wise clean well. maybe bake out grease. find a competent welder. the material is likely easy weldable alloy A356.
search this forum for other ideas and consider adding a reinforcement.
fwiw
ken
Ken Geiger, Toronto
1965 GTA, RHD, Stradale
ex- 1965 GTA, RHD, Corsa, Trans/Am 66-72
1970 Giulia Super (CDN Spec)
1976 1600 GTj (Italian Spec)
2000 Catalina 320, Hull #765 Northern Dream
2001 BMW Z3 3.0i
kengta is offline
Replace with
