tire problem - Alfa Romeo Bulletin Board & Forums
post #1 of 7 (permalink) Old 02-09-2017, 09:03 PM Thread Starter
lotuseleven's Avatar
tire problem
My GTV has developed a persistent shake at speeds above around 35 mph, noticeable through the steering wheel. after looking at bearings and other suspension parts, I looked at the front tires. in the attached pic, is this tread separation or something else? I swapped the fronts, which both showed this damage, for the rears, which were better. I still feel some vibration, but not nearly as bad. new set of dunlops on the way from tirerack, but I'm curious about what caused this damage. any ideas?
Stan Swanson, Eerie Erie, Colorado, '67 GTV (daily driver), '71 GTV (Kyle's), '91 164 (snow car), '56 Lotus 11(gone to Oz), '59 Cadillac M+M Hearse, '74 MGB
lotuseleven is offline
post #2 of 7 (permalink) Old 02-09-2017, 09:34 PM
Gubi's Avatar
Wow: those look defective. How old are they? There should be a date code on the side.
1991 Spider
Gubi is offline
post #3 of 7 (permalink) Old 02-10-2017, 07:58 AM Thread Starter
date code is 0509, so Feb '09. tires are Dunlop Dirizza Z1, 195-55-15, they all show some degree of this damage, although the two that were on the front wheels were worse. tires never over-inflated, typically run them at around 24psi (much more and they get pretty harsh and start loosing grip).
post #4 of 7 (permalink) Old 02-10-2017, 09:01 AM
Gordon Raymond's Avatar
The cracking in the sypes is typical of aged-rubber-syndrome, cause by heat, ozone or both.
Gordon Raymond
Now:
Gordon Raymond is offline
post #5 of 7 (permalink) Old 02-10-2017, 04:32 PM Thread Starter
or possible cold-related? this is from a TireRack tech article,
"If ambient temperatures drop to near- or below-freezing, driving or rolling a vehicle equipped with summer performance tires risks the possibility of tread compound cracking. Tread compound cracking is a permanent condition that requires the tires to be replaced. The other condition that can be caused by running summer performance tires in cold temperatures is the possibility of chipping away the edges of the tread blocks."
these are summer performance tires, and I usually don't drive them in winter because they are awful in snow. This winter I drove on them a lot more than usual after a catastrophic engine failure in my snow vehicle.
here's link to complete article, http://www.tirerack.com/tires/tirete...jsp?techid=273
post #6 of 7 (permalink) Old 02-10-2017, 04:48 PM
I DIDN'T know that! Good to learn. Thanks.
Gordon Raymond
Now:
post #7 of 7 (permalink) Old 02-12-2017, 01:23 PM
divotandtralee's Avatar
The "alligatoring" inside the tread is enough for me to say these tires have been toast for a long time.. Did you know these are basically street legal track tires? That alone tells me they aren't expected to give the same life and service of a tire designed for the street. Tire life is issued by the mfr based on many parameters. They don't use extremes to environment or usage to set their warranties nor would one expect this type of compound to deliver the results you would expect of a street tire. Guys run a season on a set of tires and throw them away regardless of whether they are warented much longer. Personally, if you autocross or race, these might be something i would change into at the event otherwise your car will perform better on more conventional stock profiles and you will enjoy the driver feedback better. AFWIW, ever hear about Burman boxes cracking and the PITA that can be. Chalk it up to tires that load it beyond it's tolerances.
divotandtralee is offline
