Front sway bar fit problems - looking for options custom or delete? - Alfa Romeo Bulletin Board & Forums
 2Likes
post #1 of 19 (permalink) Old 12-04-2016, 11:24 AM Thread Starter
r-mm's Avatar
When I gave my car to the body shop the only metalwork left was the nose and front x-member below the radiator. I foolishly did not give the shop the actual swaybar to test fit and now find the x member is a few mm too high and too far aft as you can sort of see in this picture sighting down the p/s mount.
I am not great at visualizing the effects of suspension changes, nor am I necessarily fishing for an easy out but: is there a reasonable suspension setup that does away with the front swaybar? As of now I have stock springs, spacers removed, koni reds. It will be a weekend car and will not see the track.
Failing that, from searching the BB I gather that some have had custom sway bars made. One thought is to get the car on the road (which is still many months away) and then take it to someone who can fabricate accordingly.
Any thought appreciated. Its a lousy situation.
'73 GTV bare metal project
E30 Daily - '65 912 project in waiting
r-mm is offline
post #2 of 19 (permalink) Old 12-04-2016, 12:28 PM
Rear mounted swaybar
There's a rear mounted swaybar system, wich is not actually mounted in the rear, but uses the steeringbox and idler's mounting points. Far stronger than the standard front..
Racers use them.. they're out there. Daron at VC was going to do one a couple of years ago, but i haven't seen any appear on his website..
And I'm sure that front situation is fixable... it's only metal...
JCDK is offline
post #3 of 19 (permalink) Old 12-04-2016, 12:42 PM Thread Starter
r-mm's Avatar
Thanks, excellent lead.
Indeed only metal. I have a few years of metal massaging under my belt with this project but would like not to revisit it with the car painted and motor in place.
r-mm is offline
post #4 of 19 (permalink) Old 12-04-2016, 12:47 PM
I understand your concern, but I'm pretty sure this is fixable.
Do I understand correctly that the left bottom mounting point is too far to the front?
JCDK is offline
post #5 of 19 (permalink) Old 12-04-2016, 12:50 PM Thread Starter
r-mm's Avatar
I think the mounts are in the right place but the entirety of the X member that is below the radiator - which is a three layered sandwich of sheet metal - appears to be both too far aft and too high, meaning it occupies the same space that the sway bar does.
r-mm is offline
post #6 of 19 (permalink) Old 12-04-2016, 01:01 PM
Are you sure? Don't forget the rubber, or poly bushes the bar sits in... that put's it quite a bit to the rear so to say..
I'd do a dry mount without the links first to see if it's really that bad.
JCDK is offline
post #7 of 19 (permalink) Old 12-04-2016, 01:10 PM Thread Starter
r-mm's Avatar
This dowel is a few mm smaller diameter than the sway bar, you can see it hits the pinched drains on the sheet metal
r-mm is offline
post #8 of 19 (permalink) Old 12-04-2016, 01:17 PM
Yep, that's not good..
Here's what I meant.
1967 Alfa Romeo GTV Recent Ground Up Rebuild Large Picture Page
JCDK is offline
post #9 of 19 (permalink) Old 12-04-2016, 01:18 PM Thread Starter
r-mm's Avatar
Thanks, I found a few threads here discussing either fabricating from parts: Sway Bars and Parts
Or buying buying from BB members who have/do make them.
r-mm is offline
post #10 of 19 (permalink) Old 12-04-2016, 01:24 PM
That's great stuff! You'll -unwillingly- end up with a far better system ;-)
Pls keep us informed, might join you!
Good luck!
JCDK is offline
post #11 of 19 (permalink) Old 12-04-2016, 01:27 PM Thread Starter
r-mm's Avatar
Silver linings! I most certainly will.
JCDK likes this.
r-mm is offline
post #12 of 19 (permalink) Old 12-05-2016, 12:08 AM
PSk
Or get a bent sway bar made, ie. it is bent in a U shape in between the mounts ...
Or hit the pinched drains with a hammer until they just clear ...
JCDK likes this.
'71 1750 Series 2 GTV:
PSk is offline
post #13 of 19 (permalink) Old 03-08-2017, 12:04 PM
Any updates on this?
JC de Koeijer
Giulia street rod, '65 Giulia 1600Ti, 74 Spider Veloce, '05 GT.
JCDK is offline
post #14 of 19 (permalink) Old 03-09-2017, 04:51 AM Thread Starter
r-mm's Avatar
Nope. I'm focused on getting the car on the road, but am looking forward to the challenge of solving this and potentially improving the sway bar setup while I do. Will share findings with you all along the way. I never heard back from the BB members I contacted who posted on this subject in the past.
r-mm is offline
post #15 of 19 (permalink) Old 03-09-2017, 06:38 AM
Norseman50's Avatar
As painful as it might seem, you may need to return to the body shop with sway bar in hand and have them re-do some of their work, or at least offer their recommendations on how to correct the situation.
Norseman50 is online now
