Old 06-15-2008, 10:01 AM
sprint750's Avatar
sprint750 sprint750 is offline
Brake booster Non-return valve
Hello,
I am currently rebuilding the brake system on one of my my early 105 ('67 Super, single circuit with hydraulic brake booster).
I was just wondering about the non return valve, screwed on the inlet manifold.
The valve is definitely stucked open. You can blow throught in both directions.
I've been using this vehicle as a daily driver for 7 years now and never noticed any problem, brakewise.
Could somebody explain what is the task of this non return valve and if there is any risk if this item is not working properly.
Any input will be appreciated
Regards
Sébastien
[B]- Giulia Super: '66 Grigio Grafito + '67 Grigio Grafito + ' 67 Amaranto (Italian import)
- GT 1300 Junior '70 Bluette [/B] (mistake: 2 doors only...)
Old 06-15-2008, 02:14 PM
rafael rafael is offline
This valve is allows air to move away from the brake booster. The result is that you get a certain level of under pressure in the booster, so that you have assisted brakes.
If this valve is not working then the brake assistance is related to the under pressure in the intake manifold. This under pressure depends on the revs of the engine. If the engine stalls, then there is no under pressure, hence no brake assistance.
However, even without brake assistance you should be able to brake, you simply have to press the brake pedal harder.
________________________________________________________
156 2.0 TS 2000 | spider 2.0i 1992 | GTV 2000 1971 (being rebuild)
Old 06-15-2008, 02:27 PM
Gubi's Avatar
Gubi Gubi is offline
Those valves are usually pretty simple internally. I bet if you give it a good cleaning with intake cleaner you can get it working properly.
1991 Spider
1987 Milano Gold
Old 06-15-2008, 03:14 PM
101/105guy's Avatar
101/105guy 101/105guy is offline
Also, note that if you have a backfire in #4 cyl. it might destroy the booster!!
Old 06-15-2008, 03:53 PM
sprint750's Avatar
Thank you all for the inputs.
I finally managed to have the valve working, with lot of WD40 and air pressure.
A carefull inspection revealed that the ball inside the valve seems to be deeply scored by sitting so long on the valve seat. Seems that I'm going to replace the item anyway...
because even if expensive (35€/50$) , it is nothing compared to brake booster prices. (Mine is new...but coming out from 20 year+ of dry storage)
Regards
Sébastien
Old 06-15-2008, 04:07 PM
papajam's Avatar
papajam papajam is offline
Not mention a weak mixture in cylinder #4 (which could result in a backfire to the booster, burned piston, burned valve, high coolant temp, etc, etc.)
Series 1 Euro 1750 GTV
Series 2 US 1750 GTV
Series 3 Spider Veloce
Old 06-18-2008, 09:26 AM
Anfanuts's Avatar
Anfanuts Anfanuts is offline
Certified Oldschooler
Replacement
Centerline sells a replacement for this manifold screw-in type CV. They do not have a Series 1 banjo-type check valve. I am fiddling with retrofitting the screwed CV into a banjo fitting now for the earlier cars.
Anfanuts; Ph.A., B.S.A.
Now
- '69 1750 Spider Veloce (pictures)(and more) 10562.1480323 (since '75 for that early mid-life crisis!);
- '88 Bayliner, 305 CI Cvy (for those really hot days!)
Gone - '69 1750 Berlina (wish I still had)
Old 06-30-2008, 01:49 PM
davbert davbert is offline
anyone know what size and thread pitch it is? i want to find a bolt to plug up my manifold.
thanks
db
