04-15-2008, 08:47 AM
Shocks and springs for Spider
Hello, need to replace shocks on my 85 Spider. Was wondering peoples experience with yellow or red Konis. I have Bilsteins on my Alfetta and they are too firm. Driven a Spider with the red classic konis and they seem very nice. Anyone have experience with the yellows? Also I am thinking of changing the springs so it doesn't sit higher in the front, but I don't want an overly firm ride. Does anyone sell the european springs? I don't know if I want a higher rate spring? thanks
04-15-2008, 12:18 PM
George Schweikle
Ezra,
You could cut a coil off of your front springs to lower the car. This will raise the spring rate somewhat, but nowhere near the 1200 Lb/in of commercially available (front) sport springs. Having said that, there are a lot of satisfied users of these springs. One of the claims is greatly reduced bottoming and nose dive under braking. I'm considering changing to stiffer springs for my '91 Spider for these reasons.
George Schweikle
1976 Spider (Dedicated Autocrosser)
Scuderia Non Originale
04-16-2008, 07:52 PM
I have Koni Yellows and IAP sport springs and like them. The Red's are more of a replacement shock for the stock springs IMO. I have a S-4 Spider which is a bit heavier then the older Spider's
04-23-2008, 01:42 PM
Don't mean to hijack the thread... How much lower do the iap springs sit? can you expand on ride harshness over stock? Thanks, Steve
04-23-2008, 03:29 PM
The fronts sat to low IMO. I shimmed mine up about a 1/2 to 3/4". The ride is like it is on rails.
I get some flack for posting another picture of my Spider but for you I will.
This is how it looks with IAP springs (with the front shimmed) and 205/50/15 tires.
04-23-2008, 05:41 PM
Murray, Thanks. that's exactly what I am looking for. I too have the quad top. Does it ride harsh at all without the top on? Is this exactly how it sits in the rear out of the box? Thanks again, Pretty car. Steve
04-23-2008, 07:10 PM
My pleasure Steve,
Really can't tell any difference in the ride with the top on or off...........
The IAP springs out of the box has low stance with the front lower than the rear. With the front shimmed the stance is almost level. The rear stance in the pictures is how they look out of the box.
IMO the IAP springs lower the front too much I was banging the pan guard all the time on dips, driveway approaches and speed bumps scared the c*** out of me.
After shimming the front up I don't have any problems.
04-23-2008, 07:42 PM
Spacers? We don't need no Stinking Spacers, Well maybe.
Murray, I'm waiting for a clean garage and a bit warmer weather, it is still in the 20's here at night and supposed to snow tonight. ARGHHHHHHH. I want to drive with the top down.
Anyhow... Do you have any pictures of the spacers you used in the front? Even a good description would be appreciated. I SHALL be taking the suspension apart shortly and I'd like to know what I might need to use for spacers. I've seen pictures of the C shaped aluminum ones that other users have commented turn to dust over time. Are these the style that you used to adjust the suspension height or did you manufacture, or have manufactured, something different for that purpose?
Thanks David
1967 Mustang fastback perpetually under construction?
1984 Alfa Spider
1984 Volvo 244 GLT now being gutted for project parts
1999 Taurus (gets me to work and back)
1974 Chevy 3/4 ton hauls the leftovers away
04-23-2008, 07:49 PM
Hi David,
That sucks about the weather.
I didn't put the shims in but I will be switching the wheels out in a couple of days so I try to see what they used for you.
04-24-2008, 10:01 AM
Thank you Murray. I'll look forward to any clues you may be able to shed.
David
1984 Alfa Spider
05-15-2008, 05:44 PM
see me post regarding IAP springs:
IAP springs finally installed
1992 alfa romeo spider veloce, 15k miles
2000 saab 9-3 coupe, 18k miles
05-15-2008, 07:31 PM
David
Hi David,
Sorry it took so long to get back with you.............I forgot. Well anyway I looked the other day but I could not see the shims their under the rubber seat.
05-19-2008, 05:14 PM
Oh this is the perfect thread for me to ask my question!
I have the IAP springs and Koni reds.. My car bounces all over the place, how do I make it feel more dead or neutral?
If Murray's description of handling like rails, then mine would be handling like a super ball...
Ed
Other cars include: 1976 Lancia Scorpion
2007 BMW Z4 M Coupe
05-19-2008, 07:54 PM
Thanks for looking Murray. I now have the both the front and rear suspensions disassembled and lying about all over the garage. The spacers on mine were not to badly corroded and I can see what they look like. For many reasons it will I have decided to reassemble the car with the original spacers for now. I imagine that later on in the summer or early fall I will be leveling the car and making a final aspect adjustment which may require new or different thickness shims. At that time I will most likely turn them on my little lathe. For now I will be happy just to get it all put together and hopefully usable prior to June 3. After that it will be a couple months before I will be able to do much work of a heavy nature.
Thanks again for looking under the car and I'll add my 2 cents worth about spring and shock feel after I'm back on the road.
David
1984 Alfa Spider
05-20-2008, 07:17 AM
Ed
Have you tried increasing the dampening rate on the Konis? Sounds like your call is all spring and no shock.
62 Giulia Sprint
65 Giulia Spider Veloces (two)
88 Milano 3.0 L
91 Ducati 900 S/S
06 Ducati Paul Smart 1000
