Hi to all,
I had this brake poblem for quite some time now, and finally I decided to do something about it! I first asked around in the alfa club I intend to join as soon as I get cash, but the main answer was that the brake system needs to be bled correctly!!!
Then I spoke to some mechanics who then said that they must first have a look at the car to give it a diagnosis??? I took the car to reputable brake and clutch people, and they came up with an answer I was not going to accept.
They told me I need to overhaul my booster and the vacuum pipe, then I need to overhaul the rear calipers as well!!! And it came to a hefty amount, i got my Guili out there asap!!!
The thing is, the car does brake, but the first push of the go slow pedal sees the thing fall right to the floor, then on a second attempt the car brakes fine, not perfect, but it gets me to a stop! I know the brake booster is tip top because it came off my dad's gtv 2.0, when I installed the booster from his GTV, the car braked perfect for a day, then it went back to the 2 stomp method. I am now going to get a rear caliper kit, and then get some brake people to do an overhaul on the rear calipers then im going to tell them to bleed the system, then I pray the woes are over!!!
Will keep the posts coming!!!
