Old 01-15-2007, 01:32 PM
CarlosSpider's Avatar
Question nuts size?
Hello.
I need an unusual information about an Alfa Spider.
I am dismantling the suspension and I want to use new bolts.
Is there anybody who knows which is the nominal diameter (size) an pitch (I suppose that it is a fine thread pitch) for the nuts marked in red? (upper wishbone to the body an to the control arm).
These are the only ones in the car and I am not close to it.
Thanks in advance
Carlos
Alfa Spider Veloce 2.0
Old 01-15-2007, 04:27 PM
#1 is a 10X1X50
#16 is a 10X1
#12 is 16X1.5X74
#15 is a 16X1.5
Numbers 1 and 12 are special bolts that are not threaded all the way. Either reuse the old ones or order replacements from Alfa. You may be able to source #1, but #12 will be difficult.
Old 01-15-2007, 04:56 PM
Thanks a lot.
#12 is 12X1.5X74 I assume that is 16x1.5x74
Bolts are very difficult to get. I was thinking in reuse bolts and use new "nylon nuts" (I donīt know the name "autoblocantes in spanish", nuts with a nylon insert) in the required grade.
Also, the nuts are not usual. This pitch is fine and the normal is the coarse thread.
Carlos
Old 01-15-2007, 05:11 PM
Zunige's Avatar
In the Spider's Nest
Send a message via ICQ to Zunige
Posted by CarlosSpider
...(I donīt know the name "autoblocantes in spanish", nuts with a nylon insert)...
Carlos,
These are called "locknuts", or if you want to be more descriptive you could say "nylon insert locknuts".
Saludos,
Enrique
Enrique
Spider 74, 84 & 87
164 91S, 93L & 95Q
Milano 88 Verde
Co-chairman 2011 AROC-USA Convention:
Alfas in the Bluegrass, Lexington, KY, USA
Old 01-15-2007, 06:50 PM
Originally Posted by CarlosSpider View Post
Thanks a lot.
#12 is 12X1.5X74 I assume that is 16x1.5x74.
Yes, I am sorry for the typo. I corrected it.
Replacing the nuts is a good idea. That is what I did.
