By spacers, I assume you mean between the spring pan and the lower a-arm. A 10mm spacer will give you close to an inch of ride height change, but not 2 inches. Are you sure the springs are properly seated on their rubber perches, and that the perches themselves are seated in the chassis and spring pan respectively?
Erik
