Old 12-10-2006, 07:03 PM
BattleBug's Avatar
Bad Master Cylinder?
Good News: I just rebuilt my brake system with new pads, rotors, braided lines, speedbleeders, and I even rebuilt the calipers.
Bad News: One week, one sore calf, and two gallons of fluid later, I still have air bubbles in the rear brake lines. I tried elevating the rear end, tapping on the calipers, and even the fabled "2x4" trick. Nothing helps to get the air out and firm up the pedal. I tried all permutations of bleeding sequences...nothing mattered.
I'm perplexed. I think the MC piston seal for the rear circuit has gone south. Puzzling because I had no issues with the MC beforehand. Anyone?
TIA
Paul
'86 Spider Graduate
Old 12-10-2006, 09:15 PM
'fabled 2x4 trick'?
Old 12-10-2006, 09:26 PM
BattleBug's Avatar
Yeah...it's where you take a 2x4 and beat the ever living $hizzle out of the car for its transgressions against humanity. Actually, the hypothesis was that if the brake pedal was held down overnight with a 2x4 it would help to re-expand the seals in the MC. It didn't help.
Paul
'86 Spider Graduate
Old 12-11-2006, 03:49 PM
Alfajay's Avatar
Getting a dual brake circuit to bleed
BattleBug:
Yea, I had the same problem 6 mo or so back. I did all the tricks you describe - also changed the MC, the pressure regulator, consulted the BB, etc.
In the end, I gave up and took it to my local repair shop. They said "oh, it is impossible for one person to bleed brakes - one guy has to work the pedal while the another works the bleed screws". Sure enough, they got a firm pedal after bleeding it their way.
Now before you all respond "BS!, I've done it solo many times", let me add that I too have successfully done it solo. Sure, put a tube from the bleeder into a partially filled bottle, bleed one front + one rear together, close the bleed screw with the tube still submerged in fluid, ... Yea, that technique has worked many times in the past for me. But for some reason, it didn't 6 mo ago. Has the composition of brake fluid changed? Some byproduct of global warming? Phase of the moon?
I recently popped for a set of "speedbleeders" for my next project. Haven't tried them yet, but am hoping they address this issue. Can anyone comment?
'63 Guilia spider
Old 12-11-2006, 04:07 PM
Gubi's Avatar
Speed bleeders are freakin' awesome. They make one man bleeding a piece of cake. Do a search for more opinions.
Here's my experience with the Spider: I had a lot of trouble getting a firm pedal until I bled the two right calipers at the same time, then the two left. This is what is specified in the service manual. This didn't really make sense to me because looking at the system layout (mine's a '91) it really shouldn't matter, but it definitely worked better for me than doing one at a time. Your mileage may vary.
Doing two at a time is obviously much, much easier with the speed bleeders.
1991 Spider
1987 Milano Gold
Old 12-11-2006, 05:30 PM
Tifosi's Avatar
Darth Slacker
Speed bleeders = kitties rectum (just being able to do the clutch slave alone is worth the price of admission)
They'll work when doing it solo or with a pressure bleeder, though it's doubtful a vacuum bleeder would have enough gumption to allow them to function.
Reversionary type bleeding/feeding/filling would be totally out of the question.
Darren
as hosted by
Greg Gordon's HI Performance Store
Old 12-20-2006, 06:53 AM
What size, where to get the auto-bleeders for '85 Spider? I've seen some at Advance Auto, but never quite grasped the right size...
Mike
Old 12-20-2006, 08:08 AM
Alfajay's Avatar
Source for "speed bleeders"
mrutkaus:
Centerline carries them. They are about $10 apiece.
'63 Guilia spider
Old 12-20-2006, 08:38 AM
lowmileage's Avatar
ReAlfisted 3/06
Thumbs up 2 words
Motive bleeder - just make sure it's attached correctly to the master before pumping ( as me how I know but at least it wasn't the Alfa )
http://www.motiveproducts.com/
Loud pipes save lives.
Ride hard or stay home - but, then again, the Alfa stays garaged when it rains.
1973 GTV - bought 3/06 (intend to keep forever)
1969 GTV, #AR1530021 - sold 10/72 (guess didn't intend to keep forever)
Current project: '69 Corvette bought in '73, DD '73 - '80, in storage 1989-2002, now apart (#1 on the Bucket list)
Last finished project: '75 Honda 750 bought new, DD '75 - '79 - in storage 26 years (1984 - 6/09) - an EZ resto
Favorite weapon: Browning A-Bolt .300 WM with 200 grain handloaded Noslers & a Leopold 2x7 or my Benjamin 312 with open sights.
Old 12-28-2006, 01:35 AM
elite38868's Avatar
Send a message via AIM to elite38868
I had a similar problem with my mom's 164. Even after the brake MC was replaced. I gave up and took it to the local shop who had a fluid pump and pumped brake fluid through the open bleed screw and into fluid tank of the car. Reverse bleeding it's called. It seems to be working fine ever since.
[B][U]Sean[/U][/B]
Alfa Romeo Association - Tour Director
[URL=http://www.alfabb.com/bb/forums/164-168-1991-1995/120368-back-black.html][COLOR=Black]92' 164S - Black[/COLOR][/URL]
07' Ford Fusion Q4
[url]www.alfaromeoassociation.org[/url]
Old 01-07-2007, 07:35 PM
BattleBug's Avatar
Partial Solution...
Indeed, my MC was bad...scored piston, "ridged" bore and collapsed seals. R&R'd it before the h-days and all is (almost) well. Now if I could only stop...
Paul
'86 Spider Graduate
