Vacuum leak at booster
I have a brand new brake booster in my 69 GTV and it seems to have a vacuum leak. The pedal doesn't change running or not. The car stops, but it takes a large amount of pedal pressure to do so. If I pinch off the vacuum line, the engine idles better, the hissing stops from the booster, and the pedal feels the same. Did my booster just die with less than 100 miles on it, or is it the check valve staying open? Anyone had this issue before?
Will
