Old 10-30-2006, 05:17 PM
New Front Rotors ('77 Spider)
I am having problems with my front brakes so I'm replacing the Rotors and calipers.
I had a hard time pulling the rotor off. I ended up using a wheel puller to pull the rotoro and hub off. When I did this the inside wheel bearing and seal stayed on the spindle. My question is, can I still replace the hub assembly properly as is or do I need to go and get a bearing puller, pull the inner bearing & seal; reseat the bearing & seal; and reinstall the hub assembly?
Pat
Old 10-30-2006, 05:47 PM
ghnl's Avatar
The bearing & seal should be installed in the hub then the assembly re-installed. Otherwise the seal is unlikely to be properly positioned.
Might be a good time to replace bearings anyway. Before you throw out the old parts see this thread: http://www.alfabb.com/bb/forums/suspension-brakes-wheels-tires/32529-new-front-wheel-bearing-issues.html
- - Eric
don't read this
~ 1984 Spider Veloce ~
Mebane, North Carolina
Old 10-30-2006, 06:06 PM
Thanks Eric.
i guess I'll need to get a bearing puller anyway.
I'll probaly do that.
Pat
