10-29-2006, 01:30 PM
new front wheel bearing issues
has anyone else here had problems fitting new replacement front wheel bearings ( 73 GTV )
assuming everything was OK, i installed the bearings in the hubs. when i went to install the front disc, it would not go on. so i grabbed the second disc, and it went on no problem. i figured it was a software malfunction ( me ) and ordered a new one. before installation, i tried a trial fit - no go !!
I ordered one from a different supplier, and explained the problem. alas, the one i received was also too small . . . #*$@#** !!!!
from the usual suppliers, 3 out of 4 front inner bearings have been .001" smaller ID than the OD of the axle stub
the inner part of the front axle measures 1.181" OD
the ID of 3 of the bearings measures 1.180"
does anyone know of a bad batch from SKF ?
the first supplier i tried was Centerline. after i found the problem they suggested going straight to the manufacturer.
anyone know of a easy place to obtain one the correct size, first time ( without all the trial & error ) ??
Dionisios di Fiflos
73 GTV - 81 GTV-6 *R.I.P.* - Jetta vr6 - Honda Hawk GT - Yamaha FZ6 - Yamaha SRX 250
10-29-2006, 03:28 PM
If you have the original bearings (the one that did fit), take them to a bearing supply store. You can find them in any medium to large city - look in the Yellow Pages. They'll measure the old bearing and find you one that fits. (Better buy two...)
10-29-2006, 06:41 PM
HaHaHaHaHaHaHa !!! that's a good one
i never foresaw the problem, and old ones were long gone by the time i tried installing the hubs/discs.
i do have the ones that are the wrong size i suppose tomorrow i should disassemble the side that did go together, and measure the bearing that does fit !
Centerline did give me the manufacturer's part#, but if there are poor tolerance ones out there, this might be of limited use.
Dionisios di Fiflos
10-29-2006, 07:00 PM
Now don't be sarcastic.
You will find that SKF premium, #30206 J2/Q (inner, Large bearing)
and #32303 J2(outer small bearing) will do real fine.
The rear wheel bearings are SKF BR88107 CRC
These are the generic bearing #'s, my originals were FAG, I prefer the SKF
Don't forget the grease seals!
TTFN Elio
10-29-2006, 07:02 PM
Trained Professional
Dumb question but is there a nick or burr in the spindle preventing the bearing from going on? Will the bearing from the side that went together fit on the side that won't go together?
Series 1 Euro 1750 GTV
Series 2 USA 1750 GTV
Series 3 Spider Veloce
10-29-2006, 08:36 PM
You will find that SKF premium, #30206 J2/Q (inner, Large bearing) will do real fine
Elio,
the sarcasm was NOT meant to be mean ( hence the smilies ) no offense meant to Eric . it just struck me funny, since i thought the same thing when i found the first bad bearing !
i have a SKF BR30206 sitting next to me as i type this. labeled "AR SPI 55-94 IN FRT WHEEL BRG ". it does not fit it does NOT say "premium". . . do they make two different versions ?
the new grease seal is sitting prominently on my workbench, waiting impatiently to be reinstalled after a proper sized bearing . . .
papajam,
a burr was my second thought ( installer error the first ), but the axle shaft is OK. so i pulled out the dial calipers and measured the interference at multiple points !!
dont forget, i tried installing the bad bearing (already in the hub) on the car first. when it did not fit, i grabbed the other hub, and that one fit snug and proper !
so it appears i now have only one 1 of 4 bearings that will actually fit both axles properly
first thing tomorrow, i will pull off the installed side and DOUBLE check that this bearing works on both axle stubs.
i find it hard to believe that the car went together from the factory with an oversized axle !! that would just suck, since i went through the trouble of stripping, derusting, and re-coating all the suspension components . . .
Dionisios di Fiflos
10-30-2006, 07:59 AM
Well, at least I said IF you have the old ones...
I never throw away old parts until I'm sure I don't need them. (and even then it is often with great reluctance)
10-30-2006, 01:12 PM
bearing update
Well it does appear that one axle shaft was thicker than the other. But i still have some bearings that do not fit over the smaller OD axle.
on carefull examination, the thicker axle shaft had what looks like miniscule corrosion pitting. it does not look like galling.
after light filing of the pitting, i was able to get the SKF bearing to snugly fit only when aligned exactly right.
the smaller OD axle is perfectly machined smooth.
Does anyone think this slight hand filing will pose problems
eric,
i too, hold onto old parts. often long after replacements have been installed. you should see all the old bicycle parts i have stowed away ! i use the excuse : "there is still a little life left in this, i'll hold onto it as a spare . . . "
the old ( possibly VERY old ) bearings were so greasy, smelly, and overall nasty, that i was impulsed to get them as far away from me as possible
Dionisios di Fiflos
10-30-2006, 01:14 PM
I have several posts on my experiences with this specific problem. Have had at least three occurences in the last few years. The old bearings slide on & off, the new (from Alfa vendors, who have always been cooperative) do not. Have gone to the local bearing house where the "new" bearings are checked out and meet published specifications, so we're dealing with fractional thousandths here. My solution has been to use a crocus tape and "shoe shine" the spindle over 360 degrees, testing regularly, until the bearing just slides on/off.
So Dion, you aren't going nuts; this is a real, frustrating, but easily fixable problem.
Good Luck
Wil Painter
10-30-2006, 04:00 PM
Originally Posted by Wil Painter
So Dion, you aren't going nuts...
Wait a minute. We don't know that. All we know is the spindles on his Alfa are slightly different sizes!
10-30-2006, 04:08 PM
as eric pointed out, some might say its already too late.
maybe its an alfa ownership thing . . .
Dionisios di Fiflos
11-03-2006, 04:39 PM
Guys...when you say the bearing should slide on and off, does that mean all the way to the base of the axle spindle or just to the end of the taper? I just had a bear of a time removing an old one even though there was no sign of galling or corrosion once it was removed.
Also, here's my dumb question for the day (wife says you mean minute don't you babe  )...what's the black string (looks like suture material)around base of axle soindle and how does it work?
Bill Ryan
1982 Spider Veloce
Rock is dead so long live rock!
11-03-2006, 05:25 PM
Bill:
It should slide without force (but nice & snug) past the taper to the base of the spindle.
I'll take a shot at the black string you're describing as being a part of the seal that was beat up and left behind when you had to force the bearing off, as the forced removal typically destroys the seal. Or, if you had a failing bearing, the wobble pushed out a bit of the seal and the rotation wrapped it around the spindle and made it appear like a piece of string. Any other thoughts out there?
Wil
11-03-2006, 11:34 PM
like Wil, my first thought was a remnant of the seal.
or, perhaps it is just a piece of string that got wrapped around the axle from road debris.
once, i had a plastic grocery bag wrap around the rear brake on a motorcycle while on the road ( i first thought i had missed it ). when i applied the brake, nothing happened
once the plastic melted/burned up, the brake force returned. i pulled over and found black plastic "string" wrapped all over the rear brake/hub/sprocket (i think the brake got a little 'warm')
anyway . . . there was no original purpose for a string to be there.
Dionisios di Fiflos
08-07-2007, 09:56 AM
Back from the dead...
I'm going thru this right now... What is Corcus tape?
-Raffi
