Old 09-11-2006, 07:52 AM
Unhappy 146 Ti Problem - stuck brake piston
Hi,
After any advice anyone can offer.
I came to change the rear pads and discs on my 146.
Got as far as dismantling the calipers and removing the old pads and discs. However try as I might I could not push back the piston which presses the pads to the disc.
I've done this job on other cars and realise it sometimes takes a bit of force to push back as your pushing against brake pressure. This piston however seems to be stuck fast.
The handbrake was off and there was no pressure on the brake pedal.
Am I missing something, anyone got any advice?
Old 09-11-2006, 11:02 AM
You are indeed missing something; you need to wind the piston in. You will never just push it in as it is on a thread for the handbrake system to take up brake wear. Use some grips on the 'cross' m/c into the end of the piston.
Old 09-12-2006, 03:22 AM
Ahh so simple really !
Old 09-12-2006, 03:43 AM
Last question
Sorry, one more question - I should have asked, does it wind in clockwise or anti ?
Old 09-12-2006, 03:51 AM
Alfisto Steve's Avatar
Turn piston clockwise and apply slight pressure to piston face as you rotate piston. I use a C-clamp and tighten slightly as I rotate piston with water pump pliers or curved jaw vise grip pliers.
Virginia Beach, VA
s.patchin@aroc-usa.org
http://www.aroc-usa.org/
Daily drivers: USA models 91 "Bianco" 164B 5-speed - ALFISTO, 91 Argento aka "Quik Silver" (daughter's) 164B w/AT 1QUIK AG
Winter Sleepers: 93 "Rosso" 164L 5-speed; 91 "Old Blue" 164L w/AT
Rescue projects: Newbie 91 164L "Black Beauty"
Organ Donor 91 Old Nero 164L
SOLD 91 Argento 164L w/AT aka "Quik Silver 2"
