Old 08-31-2006, 05:38 AM
Rich's Avatar
Hand Brake Rubber Boot
Hi,
Anyone know where I can buy two of the hand brake cable rubber boot like this one.
Rich
Old 08-31-2006, 05:42 AM
Rich's Avatar
oops, this is the picture.
Thanks again
Old 08-31-2006, 07:59 AM
I just sold a couple of them to Milano Spares in Melbourne. Give them a call and speak to Marc. Thay ain't cheap, but the two I sold them were apparently the last two available from Alfa Romeo anywhere in the world.
Axeman74
Old 08-31-2006, 08:26 AM
papajam's Avatar
Trained Professional
I may have a couple of new ones left. I'll check over the weekend.
Series 1 Euro 1750 GTV
Series 2 USA 1750 GTV
Series 3 Spider Veloce
Old 08-31-2006, 07:21 PM
The hole in the axle tube does not look good. Easy thing for a fatigue crack to propogate and fail. Already looks like a horizontal crack towad the right.
Robert
Old 09-02-2006, 07:03 AM
papajam's Avatar
Had a poke around this AM but if I do have them, unfortunately I couldn't find them. I'll keep an eye out for them though.
Sorry.
Old 09-02-2006, 09:05 AM
Rich's Avatar
Hi Robert
Hole!What hole? I will have a look in the morning.
Thank you Jim.
Thank you Axeman I will call Milano Spares on Monday and I will let you know Jim if they have them.
Thanks guys
Rich
Old 09-02-2006, 11:34 AM
In the photo above, there appears to be a triangular hole with a bent lower lip to the right and below the tail end of your red arrow!
Camera angle is tricky though. Looking closely it could also be a bracket welded on the tube, with the shadow of the bracket looking like a hole.
Robert
Old 09-02-2006, 11:40 AM
Robert
That's the spot where the limit strap wraps around.
Old 09-03-2006, 06:40 AM
Rich's Avatar
Hi,
No hole, no cracks, it must have been the camera angle or shadow. Mind you, it had a lot of diff oil all over it due to worn seals, not mention all the soil stuck to the oil, I had to sweep every five minutes. By the time I took the brakes, spring, shock and diff out, I had enough soil for a pot plant
Check out the diff oil sprayed under the body. Also included is my first, home made Alfa tool for extracting the axles.
Old 09-03-2006, 11:56 AM
Alex's Avatar
Highwood Alfa in the UK has the part that you're looking for.
Alex.
Old 09-07-2006, 06:02 AM
Rich's Avatar
I called Milano, sold out of rubber boots. They have ordered some from the the UK. $10 to $15 Aus. two more weeks to arrive
Thank you for your help
Rich
Old 09-15-2006, 04:42 AM
mullet's Avatar
Rich can you give me a description as to how your puller works , i think i get the picture but an explanation from someone who has done the job would be great. I have a leaky rear axel seal and have to pull the axel my self .As i havet done this before any help would be great .
  #14 (permalink)
Old 09-15-2006, 06:49 AM
Rich's Avatar
Hi Mullet,
With a hammer i just tapped the end bet that sticks upwards a few time and voila it came out. Just be care full putting it back in, it is hard to explain so i will include some pictures that will help you when you put it back in. See at the end you have to lift the axle so goes through the lip at the end. If you want more close up picture let me know.
Rich
  #15 (permalink)
Old 09-15-2006, 08:01 AM
mullet's Avatar
Thanks Rich i thought as much that that was the idea . Nothing else to look out for ,tips and tricks . Any must replace while the axle is out?
