08-25-2006, 05:05 AM
Getting rid of booster
Has anyone switched over their car to a boosterless setup??
I am getting tired of replacing the booster on my 77 Alfetta. I have put 4 used boosters on this car and they all have gone bad. I really don't want to spend the cash on a new one if I can get rid of it. My 78 X1/9 had no booster from the factory and it stopped great with very little pedal effort.
What would be the piston size/stroke of a replacement master cyl. that would have good stopping power without the booster? AND where can I source the stuff to do it?
Any help with info would be appreciated.
Paul
The meek shall inherit the rear view mirror.
Alfas owned/own!
81 GTV-6
83 GTV-6
86 GTV-6
87 Milano Gold
88 Milano Verde
91 164S
77 Alfetta sedan
79 Alfetta GTV(smooshed and ground up)
08-26-2006, 02:08 PM
C'mon... throw a dog a bone!
Alfas owned/own!
81 GTV-6
83 GTV-6
86 GTV-6
87 Milano Gold
88 Milano Verde
91 164S
77 Alfetta sedan
08-26-2006, 03:45 PM
i run my car without a boster when...
i have my 4 piston calipers on my car. with the boster brakes are way to touchy. i will give my car a try without the boster today, on reg, brakes, will post later.it should be ok, on reg. brakes, just a little more pressure on the pedal, but more feeling.
08-26-2006, 04:44 PM
Trained Professional
Simply disconnecting the booster vacuum hose will result in brake pedal effort that is way too high. Too high to be driven safely, IMO. The booster would have to be removed and an appropriately sized master cylinder be fitted to some kind of bracket. Never did it before but perhaps one could just gut the booster?
I guess the real question is why have five boosters gone bad. Master cylinder leaking fluid into the booster? Bad vacuum hose check valve? Bad used boosters? I think I'd try to determine the root cause for the booster failures rather than address the symptom by binning the booster.
Series 1 Euro 1750 GTV
Series 2 USA 1750 GTV
Series 3 Spider Veloce
08-26-2006, 06:08 PM
If I remember correctly old 105 series cars without booster had a 3/4" or 20mm MC and those with booster had either a 7/8" or 22mm MC. I am not sure but Alfetta calipers may have similar piston diameters on the wheel cylinders.
I agree with papajam that a 22mm MC without booster requires too much pressure for normal usage, though it will do in an emergency. For a road car I would try to fix the problem, namely replace booster and MC at the same time with new items. On a racecar dumping the weight of the booster is nice.
08-26-2006, 06:25 PM
Correct.
The floor pedal 105s however have hydraulically actuated boosters (if equipped) while the hanging pedal versions are mechanical. Completely different pedal feel/effort with a disconnected booster. Disconnecting a floor pedal booster will increase pedal effort some 10%. But disconnecting a hanging pedal booster will more than double the pedal effort.
08-27-2006, 10:53 AM
I'm using boosters from cars that have been sitting in fields for 20 years. They were free and they were shady to begin with. In my opinion the easiest thing would be to get rid if the booster and master that I have and make the appropriate mounts and linkage. I guess that at this time I need to know if anyone has done the math to figure out what diameter MC I would need to make enough pressure w/out the booster to make the pedal not so hard. I liked the way my X stopped and that it had a bit of a hard pedal. The brakes were really easy to regulate. That little sucker stopped on a dime.
Do You thingk that the 23mm mc that performatek has would be large enough??
More thought and opinions welcome.
I'm going out to the garage and take one of the bad ones apart and see what is failing.
Paul
Alfas owned/own!
81 GTV-6
83 GTV-6
86 GTV-6
87 Milano Gold
88 Milano Verde
91 164S
77 Alfetta sedan
08-27-2006, 12:49 PM
I think it's too large. All things being equal, the larger the diameter of the M/C, the higher the pedal effort. You need to go smaller than the stock 22mm M/C (at the expense of a bit of pedal travel). Alfa chose a 20mm M/C for their non-boosted ATE equipped cars.
Then again, if you're going to remove the booster, fab a bracket and mount the M/C pushrod directly to the brake pedal, the stock 22mm will work with only a moderate increase in pedal pressure over the boosted version.
08-27-2006, 08:01 PM
boost
gt 601, What do the brakes feel like now? My spider had a bad booster which I replaced, and I think I liked the brake feel better before replacement!
Paul
76 Spider
71 Spider & many parts
67 BSA
08-28-2006, 04:01 PM
Ahhh I see.... I wil try this and see if it works. I would think that the pedal would feel the same with a bad booster as it would feel with no booster because the rod goes straight through. Right??
I took one of the boosters apart yesterday and the diaphragm was split at the edge of it.I may have resigned myself to just go ahead and buying a new one if I can't get through to ATE.
Paul
Alfas owned/own!
81 GTV-6
83 GTV-6
86 GTV-6
87 Milano Gold
88 Milano Verde
91 164S
77 Alfetta sedan
10-30-2006, 01:17 PM
This is sort of on topic, I have a bad booster in my 69 GTV, I pulled it apart, replaced all the seals and it still leaks fluid from under the small diaphram. Is this the nature of the creature or do I need a new booster? How much work is it to change over to a single circut system from an earier car (John Norman's suggestion). I'd even be game to ditch the whole power brakes and run unassisted like my other car if that were easy to do.
Will
10-30-2006, 03:19 PM
Are you saying that the master cylinder is leaking into the booster? If it is I would replace the master cylinder before it too ruins the diaphram. When I took mine (the bad one) apart it had a bit of brake fluid in it which didn't help the rot factor. They were all just too old to re-use. I ended up just buying a new one from DiFatta. It is a joy to drive now with a good booster. It also idles better w/out a great big vac leak.
Alfas owned/own!
81 GTV-6
83 GTV-6
86 GTV-6
87 Milano Gold
88 Milano Verde
91 164S
77 Alfetta sedan
10-30-2006, 05:00 PM
Although many Alfisti consider a variety of fluid leaks from a variety of locations to be somewhat normal, a leaking booster is not one of them.
I see a few options;
1)Determine exactly where the booster is leaking and fix it.
2)Install the good booster in the front brake circuit and leave the rears unboosted.
3)Bypass both boosters.
4)Buy a new/used booster.
5)Switching a tandem brake circuit to a single circuit is, IMO, NOT an option!
10-30-2006, 08:08 PM
Will,
boosters don't use fluid. only air in vacuum, derived from the intake manifold.
if brake fluid is leaking from the booster, then your master cylinder needs rebuilding/replacing. sounds like fluid is leaking out the back of the master cylinder and into the booster.
do you notice white smoke out the exhaust during strong deceleration ? fluid in the booster can be sucked through the vacuum line and into the intake manifold of course this could be fun, in a James Bond sort of way . . .
Dionisios di Fiflos
73 GTV - 81 GTV-6 *R.I.P.* - Jetta vr6 - Honda Hawk GT - Yamaha FZ6 - Yamaha SRX 250
10-30-2006, 09:19 PM
Will:
I'm running the '69 dual MC in an unboosted system in a vintage race car, with an adjustable proportioning valve in the rear circuit. Works great for that application, but then coming into a tight corner after a long straight naturally tends to boost my braking foot  so I can't judge what it would be like in a street application. I do like the firm, linear pedal feel on the track, and it seems fine in the pits.
All components of my system are new, hard pipe, steel braid hose, AN fittings, and a resleeved/rebuilt MC, so nothing leaks.
I know the '69 system was problematic for many, but I'm with Jim, I would not disable the dual circuit. Locate the leak and fix it, with or without boost. Osso has a great thread in this section of the BB on repairing the 69 MC, including the sleeving option. I would start there, as it is the heart of your system, and the source of many of the 69's issues.
Osso used Karps, I used White Post for the MC refurbishment. Jim (Papajam) occasionally does this service as well; you could do no better if he'll take on your project.
Wil
