Old 11-12-2003, 11:07 PM
aeroengineerguy aeroengineerguy is offline
Question W&D or Shankle
My GTV has IAP sport springs on it and they are way too soft and high. I've heard a lot of good things about Ward and Deane and Shankle. Which is harder? If any one could tell me the spring rates that would be great.
Jason
Old 11-12-2003, 11:36 PM
Roadtrip's Avatar
Roadtrip Roadtrip is offline
Jason - Check:
http://alfa.denovich.org/Alfa/SpringRates
John Stewart
74 Spider
Old 11-13-2003, 06:52 AM
emr5503 emr5503 is offline
Springs
Ward & Dean springs are: Front-1200 lbs/ ", Rear = 200 lbs/ ". Race springs are shorter with smaller wire diameter, square on both ends, same rates.
Old 11-13-2003, 09:56 AM
Thanks John and emr5503
Just out of curiosity, what do most people use on race cars?
Old 11-13-2003, 10:14 AM
italcarguy's Avatar
italcarguy italcarguy is offline
Super Moderator
Super Moderator
most people use ward and deane springs. i have a set on my car as well as fabrizio, they work great! a lot of people have been getting them made, i have started to make a few myself. if i were to put springs on my street car, i'd go with the shankle sport or super sport. you can get springs made with different spring rates, not just 1200 and 200, that's just the most common set up for a race car. also, not all springs are flat ended, they also come in "pig tailed". i don't know the exact spring rates on the shankle stuff, but that chart on the link above should help you.
Old 11-13-2003, 10:32 AM
GTV4EVR's Avatar
GTV4EVR GTV4EVR is offline
Anthony,
Do you feel the W&D are too stiff for the road, or is there another reason?
Ken Lee
Oakville, ON
1973 GTV 2000 - Blanche (or this one I hope)
Old 11-13-2003, 10:47 AM
italcarguy's Avatar
Super Moderator
Super Moderator
Originally posted by GTV4EVR
Anthony,
to be honest, i have never heard of someone putting ward and deane springs on a street alfa. i am sure he can make them with spring rates that will be good for street. i might see him next weekend. if i do, i'll ask him.
Old 11-13-2003, 10:56 AM
GTV4EVR's Avatar
His "Street" springs have the same spring rates as his race springs just taller. In the last email I exchanged with him, he said he was going fishing until the 22nd.
Ken Lee
Oakville, ON
Old 11-13-2003, 01:35 PM
Thanks everyone
IAP says that their "performance springs" are 1300 in the front and 600 in the back. So shankles are softer unless I have harder ones made? BTW how much does a set of standard shankle and W&D springs cost?
Jason
Old 11-13-2003, 01:47 PM
GTV4EVR's Avatar
So the IAP springs are stiffer than the W&D ?
Ward & Deane springs cost $390., but I can't remember if that is the race or street spring. The race are $40 more than the street.
Ken Lee
Oakville, ON
Old 11-13-2003, 01:56 PM
Ken
I think they are measured in different units. lb/ft and N/m etc.
I cant find anything that has all of the springs in the same units. And most of the time the sources don't even tell you the units they use. The link that Roadtrip put up has been the most helpful so far, but as for the "red" springs, both IAP and shankles are red . . .
Jason
Old 11-13-2003, 02:39 PM
I also purchased Alan's rear sway bar which is thicker than the std. This is for a 1750 street car which is probably why IAP's rear springs are stiffer. Alan makes this bar for IAP. I double checked the rates with him Monday, as he was leaving for his fishing trip.
Old 11-13-2003, 03:29 PM
GTV4EVR's Avatar
Have you installed them yet? Mine is a GTV 2000, and I am thinkinf about getting the springs, rear sway bar and adjustable control arms from Alan, but Anthony has me a little concerned the set up might be too stiff for the street. What shocks are you using?
Thanks....
Ken Lee
Oakville, ON
  #14 (permalink)
Old 11-14-2003, 06:43 AM
Car is at the shop waiting for a friend's GTA jr race car to get off the lift. He's also running Alan's street springs since he had them. He may change them later.
I'm going to use red Konis (since I have them), all poly bushes, 4:10 LSD & adjustable A arms. When I get around to rebuilding the engine (beginning to smoke at 34,000 mi.) it will get a GTA head with Wes' pump & cams & a GTA (14 lb.) steel fly wheel.
  #15 (permalink)
Old 11-14-2003, 10:06 AM
GTV4EVR's Avatar
Is the 4:10 LSD a simple swap with the 4:56? I assume it is from a late spider? Do you just exchange the diff, or swap the entire axle? Where can you find a GTA head? My short term plans are the suspension next spring (and have the transmission rebuilt). Then over time, redo the interior, the body and the engine.
Ken Lee
Oakville, ON
