Old 09-25-2003, 12:55 AM
164QV's Avatar
164QV 164QV is offline
Chromodoras
So, I got me a really cheap set of Chromodoras for my Junior. ($70) They are a bit beat up, but with some paint I think they will turn out really nice. Now, I think these are REALLY light - could they be magnesium? How can you tell a magnesium wheel from a aluminium wheel?
Jørgen
[URL=www.cuoresportivo.dk] [COLOR=darkred]www.CuoreSportivo.dk[/COLOR][/URL]
1969 1300GT Junior
1971 2000 Spider (racecar!)
1964 Vespa Gran Sport
Old 09-25-2003, 03:39 AM
67GTV's Avatar
67GTV 67GTV is offline
You could try to melt them!
Magnesium ignites (literally) at a much higher temperature and burns at 5000 degrees farenheit!
(sorry no help here)
Kai Schorr
105.36 : 1967 Giulia Sprint GT Veloce
Old 09-25-2003, 03:43 AM
164QV's Avatar
Kai, you're so funny! If I had 5 wheels, I guess I would've done that - but theres only 4! Does anyone here have an aluminium Chromodora wheel (with or without tire) they could weigh?
Jørgen
1969 1300GT Junior
Old 09-25-2003, 01:35 PM
gvisconty's Avatar
gvisconty gvisconty is offline
Try this
http://lists.kjsl.com/pipermail/beec...rch/022125.htm
Old 09-26-2003, 04:27 AM
164QV's Avatar
I did, the page doesnt work....
Jørgen
1969 1300GT Junior
Old 10-14-2003, 04:29 AM
fgc fgc is offline
Hi jorgen,
where did you get your wheels? I am looking for spare chromodoras. what design are the spokes? the 5 spoke stars?
I have a set of chromodoras on my 67 duetto. They are made of magnesium. I had some curbings on mine and I wanted the curbed rim repaired by welding new material on the rim and machining it back. I brought it to a rim repair shop and I told them it could be magnesium. They were apprehensive about welding mags because unless the welders have special equipment to weld mags, the whole wheel can go up in flames and it burns really hot and bright and I am told that a fire extinguishers is useless to put out the fire except I suppose flooding the thing with halon or whatever.
To cut a long story short, he filed some filing off a curbed damaged area onto a piece of paper and then put a light under the paper. after a few seconds, you could see the mag filing flash before your eyes even in the bright noon sun here in the tropics.
So I guess if your wheel is has some damaged, it doesn't hurt if you were to file a little to try this experiment... those with chemistry background can perhaps suggest a better solution?
Anyway, like you, I was looking for information about mag rims etc and I have attached one of the hyperlinks to this site which is quite fun and interesting to read.
http://www.sportcompactcarweb.com/te...cc_wheelguide/
Have fun
fgc
Old 10-14-2003, 01:12 PM
gvisconty's Avatar
oops
sorry about the bad link. I can't find the original now, but this site :
http://www.welding-advisers.com/Mate...ification.html
Says :
"One can readily distinguish between light alloys like aluminum and magnesium with a simple test, but you should use the help of a chemist. Aluminum is attacked by caustic soda (NaOH), which is a dangerous material, and also by alkaline solutions, while magnesium is not. Conversely magnesium is attacked rapidly by usual inorganic acids (excluding hydrofluoric and chromic acid), while aluminum is not attacked by acids like nitric and sulfuric. Also aluminum density is about twice that of magnesium. "
This site says that "Magnesium is white and will not polish":
http://www.englishcustompolishing.co...aluminum1.html
Old 10-15-2003, 02:50 AM
67GTV's Avatar
Originally posted by fgc
...the whole wheel can go up in flames and it burns really hot and bright and I am told that a fire extinguishers is useless to put out the fire except I suppose flooding the thing with halon or whatever.
I have seen magnesium burn and I doubt that even halon could extinguish it. A friend of mine was in the Navy. He told me that the fighter jets have magnesium brakes. When they overheat and catch fire due to a rough landing, the crew strips what they can and then dumps the plane in the ocean!
You can purchase a small magnesium block at REI to play around with the stuff.
http://www.rei.com/online/store/Prod...ory_rn=4500638
Kai Schorr
Old 10-15-2003, 11:13 AM
emr5503 emr5503 is offline
"Mag. is white and will not polish"
Horse hockey.
I've got mag wheels on my 1750, Bobsy SR3 & Royale FF. All polish very nicely, thank you.
Old 10-15-2003, 11:28 AM
John M's Avatar
John M John M is offline
Alfa Poor in KY
For what its worth and I am not for sure....its my understanding that none were solid magnesium. They were all a magnesium/aluminum alloy. From the my old chemistry days, I remember that solid magnesium is highly volatile in air. To the point its explosive. The older ones (60s...early 70s) did have a much higher content of magnesium than ones from like the 80s. I think its safe to say, the lighter the wheel, the more magnesium it has...providing dimensions are equivalent. Be careful when shopping for true cromodoras to ensure that there is no deterioration around the center. The heavy mag content cromos are known to rot in the centers.....even to the point where big chucks come out of the center. This I know for sure as I have seen cromodora wheels that it has happened to.
Best Regards,
John M
1978 AR Spider Veloce 2000....the first and still here
1978 AR Spider Veloce 2000...its slow black & rusty but complete and original!
Old 10-16-2003, 01:32 PM
gvisconty's Avatar
emr5503, what they say on that page is is that alloys with more than 20% magnesium are white and will not polish. Either the people at englishcustompolishing.com are full of it, or your "mag" wheels are made from less than 20% magnesium.
I had a Navy friend that said they used (pure) magnesium to destroy sensitive data in computers in case they needed to abandon them. They would rig up magnesuim (powder?) on top of the computer hard drives, so if they needed to get out quick, they would ignite the magnesium and run. Burning magnesium is really difficult to put out.
Old 10-16-2003, 02:54 PM
Mag.
They once had a Lotus 11 or Elva burn to the ground at the 6 Hr race at Marlboro. Was said it had a Mag. body. They couldn't put it out, but it sure was bright for awhile.
Old 11-04-2003, 11:08 PM
nino1969's Avatar
nino1969 nino1969 is offline
Hi Jorgen,
As I know Cromodora wheels are magnesium. (if you have the original old items and not the reproduction which are made of aluminium).
I have weight a Cromodora wheel and if I remember well its weight is about 5 and a half kilos!!
You can also ask my best man TAKIS who wears them on his 1750 GTV.
“Alfa Romeo is not merely a maker of automobiles : it truly is something more than a conventionally built car. It is a kind of affliction, an enthusiasm for a means of transport. It is a way of living, a very special way of perceiving the motor vehicle. What it is resists definition. Its elements are like those irrational character traits of the human spirit which cannot be explained in logical terms. They are sensations, passions, things that have much more to do with man’s heart than with his brain”.
Orazio Satta
gt1300junior, '67
gt1600junior, '73
giulia 1300 ti, '67
giulia sprint gt, '64 (needs heavy resto)
  #14 (permalink)
Old 11-05-2003, 12:29 AM
164QV's Avatar
It most definitely says "chromodora" on my wheels, but I believe they were made in both magnesium and aluminum. I havent gotten the tires off yet, but when I do, I will put the wheels on a weight.
Attached a pic from the fire in California - apparently those werent magnesium wheels.....
Jørgen
1969 1300GT Junior
  #15 (permalink)
Old 11-05-2003, 01:33 AM
BigSwede's Avatar
BigSwede BigSwede is offline
67GTV: I'll add that piece of mahgnesium to the top ten list of what not have in your pocket in a car accident...
I wouldn't put on old magnesium wheels on my car, I've heard so many stories of old wheels shatteting the low weight isn't worth it..
Just above 5Kg? 14"? Doesn't sound like magnesium to me, some kind of alloy maybe with some magnesium content. 5Kg is ****loads of magnesium...
A light 15" modern rim weighs less then 5Kg.
Wasn't all non-steel wheels called "mags" a while back?
Mats Strandberg
