Old 11-02-2009, 02:32 AM
AntonyR's Avatar
Send a message via AIM to AntonyR Send a message via Yahoo to AntonyR
Suspension setup with Shankle/Koni Reds in a Spider
Hello,
I have a spirited street only driven '87 Quad with Shankle bars front and rear, Koni Reds, and stock springs. The Konis are not changed from their original setting. Does anyone have a similar setup who had tried different shock settings that can share their findings? Would changing from Koni factory settings improve things in my case?
'67 Duetto (R-I-P)
'86 Graduate (in the garage, waiting its turn)
'87 Quadrifoglio (current money pit)
Old 11-02-2009, 02:04 PM
Depends on how you drive. Shankle bars are a bit stiff with stock springs. Rear bar especially.
But the key question is: what's wrong with your current set-up? how does it drive (oversteer/understeer). And how do you use it? street? AX? TT?
When you get what you want, how will you recognize it?
Robert
Old 11-02-2009, 02:24 PM
AntonyR's Avatar
I wouldnt say that there's anything wrong with it, I was just seeing if there was anyone with a similar setup, with similar driving habits, that found that changing the original setting was a noticeable improvement or not. I suppose the question should have been, Is it all personal preference, or should something be changed, coming from your experience, as opposed to my lack of experience? If the answer is that there is no correct or better setting, only personal preference, I understand. I just wanted to try for an easy answer, instead of trying every setting in the hopes of finding something I like better.
'67 Duetto (R-I-P)
Old 11-02-2009, 02:48 PM
Tifosi's Avatar
Darth Slacker
How do you mean 'improve things'?
I understand you want a bit of sporty street scratching, but in what area do you feel it's lacking, or rather where an improvment over what you have is needed?
Does it plow when you go into a turn, or does it get partway in and want to turn around backwards on you? (if neither, then it's more a case of you not pushing enough, and therefore don't really need to change anything as you're not using what you've got to it's fullest potential anyway)
Robert isn't really off in his line of question, as no one will be able to make suggestions without actually knowing specifically how things act vs how you might like them to act.
Really. It could be something so simple as an air pressure adjustment, tire compound change, or even removing the spare tire rather than even getting into fiddly bits like shock damping, spring rates and ARB changes. (just because you 'can' make adjustments doesn't mean you 'should' make adjustments IOW )
FWIW, Koni reds only allow for adjustment of rebound damping, so the compression is always going to feel the same and the changes will only be on how fast or slow (within the range of adjustment) things re-expand (or expand upon unloading) which in turn is directly relevant to the spring rates you're working with.
Darren
as hosted by
Greg Gordon's HI Performance Store
Old 11-02-2009, 03:44 PM
AntonyR's Avatar
I think that pretty much sums up things. I might as well just leave it alone then. Since I haven't noticed anything obviously wrong as far as the handling, either it's fine, or I don't drive it hard enough to have to be concerned about changing stuff. I'll pay more attention, the next time I do a bank job...
'67 Duetto (R-I-P)
Old 11-02-2009, 04:45 PM
One thing you might try is to soften the rear shocks to the minimum. Most of the 105's are so light in the rear that they do not need much from the shocks. Later models are generally heavier cars 'thou. Fronts at mid setting is common, even with stiffer front springs. Many even swap to Koni yellow (sport) at mid setting for the fronts, but that goes with the generally lower ride that 'sporty' springs come with.
Robert
Old 11-02-2009, 07:09 PM
AntonyR's Avatar
Robert
So since it's an '87(later model) with stock springs, do you think it might be worth leaving the rear shocks alone and maybe try setting the front to the mid setting, just to see if it handles any different for me? -Actually I don't know what the factory setting is.. If you mentioned softening the rears, does that mean that they come set to mid already?
'67 Duetto (R-I-P)
Old 11-02-2009, 07:44 PM
msiert's Avatar
Darkside Member
Set the rears to full soft and the fronts to 3/4 to full stiff.
Murray
1991 Black Spider
The "Black Spider" project
Street Video
Track Video
Old 11-02-2009, 08:10 PM
AntonyR's Avatar
Is this helpful info, or mis-information to forward the black Alfas are fastest agenda?
'67 Duetto (R-I-P)
Old 11-02-2009, 08:29 PM
msiert's Avatar
Darkside Member
Well Black Alfa's are the fastest ones!!!
Suspension setups are a very personal thing what feels right to one person may be all wrong for the next.
I've been through a number of shock setups with the IAP sport springs I have. The first was Koni Reds all the way around but after reading "The British vs the Yank's" in the motorsports section I felt like the Koni Reds were not a very good match with the 1,200 lb front springs so I up graded to Koni Yellows but felt the rear was too stiff so this Spring I bought a used set of the stock Speca rear shocks and now the rear feels more planted.
Koni Reds (set to full soft) are considered replacement shocks for the stock Speca shocks. Wish I never sold the Koni Reds rear shocks I didn't want to spend the money for a new set so I pick up the used Speca's for $40 and am very happy with them.
Murray
1991 Black Spider
Street Video
Track Video
