Old 10-18-2009, 02:36 PM
GTV6 more camber?
My car is quite lowered and has around 3 degrees negative camber. I'd like to get it to around 1 or 1.5 degrees. The problem is if i shorten the spacer on the lower arm any more the arm will be touching the body. Is the anyway to achieve this without raising it again?
